Old 03-03-2013, 05:49 PM   #6436
ozgnp
Half/fast
ozgnp's Avatar
Oddometer: 15
Need a chain guard
Just picked up an '04 dr200, great shape but missing the chain guard.
Anyone know of a source, or should I just bite the bullet and go to
$usuki?
ozgnp is offline   Reply With Quote
Old 03-03-2013, 07:26 PM   #6437
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,306
$usuki?
Ebay is the most likely place to find one.Then the stealership.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 03-03-2013, 09:40 PM   #6438
Goon310
Goon310's Avatar
Oddometer: 52
Got my carb re-jetted and FMF pipe on.
I can now start the bike without using prime, or choke.
Hold throttle open a tiny bit and hit start, BAM!
Fires right up.
Renthal CR high bend bars fit great, too!
Can't ride yet because I ordered the wrong flippin' size inner tube.
But the new one should be here pretty soon.
Kientech rules.
Goon310 is offline   Reply With Quote
Old 03-04-2013, 12:24 AM   #6439
Solas5
Solas5's Avatar
Oddometer: 14
What size of jets did you go with?
Solas5 is offline   Reply With Quote
Old 03-04-2013, 01:22 PM   #6440
Goon310
Goon310's Avatar
Oddometer: 52
I uh...
Forgot! LOL
I just bought the kit from Kientech, it's a little leaner pilot, adjustable needle, and an adjustable fuel screw. I haven't played with the needle position but I did fiddle with the fuel screw a tiny bit and it runs great.
It's been sitting in the shed all night and I'm going to see if it will start today after work without using the choke or prime like it did yesterday.
I imagine it will.
Old 03-04-2013, 08:38 PM   #6441
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 10,955
I have a DR200 and an F650GS an '07 and I think it's a perfect combination. Lucky for me I don't have to get permission from a wife to buy a bike.
Ladybug0048 is offline   Reply With Quote
Old 03-05-2013, 07:37 AM   #6442
Wallrat
Wallrat's Avatar
Oddometer: 625
Originally Posted by Goon310 View Post
I uh...
I imagine it will.
If the ambient temperature is fairly warm then that's fine but if it's cooler out, say below 60-70F or so, you're probably a bit rich on the pilot. The choke is on there to fatten up the mixture on cold starts. If you jet to bypass this feature then you're running rich the rest of the time that the bike isn't cold.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 03-05-2013, 08:20 AM   #6443
Goon310
Goon310's Avatar
Oddometer: 52
I haven't ridden the bike yet to play with it any.
I started it yesterday after work and let it idle for a bit before I changed the oil.
It started right up with no issues. It was about 65F in my area yesterday?
My new rear tube comes Wednesday so I'll get that one and go for a test ride. It'll probably pop on decel, and I'll take care of it.
I was mainly just noting the difference in how it used to be, had to sit with the choke on, or even ride a bit with the choke to get it to warm up.
I bought the jet kit after it took me half an hour to feel the bike was warmed up, only to have it stall if I didn't rev the piss out of it all the time.
I've also removed the airbox lid along with the fm exhaust.
Old 03-06-2013, 05:05 AM   #6444
kafkamars
Oddometer: 40
Eh? bearings
soooo, do the rear wheel bearings face open side in or out? thanks.
kafkamars is offline   Reply With Quote
Old 03-06-2013, 08:04 AM   #6445
Wallrat
Wallrat's Avatar
Oddometer: 625
Open side always faces in to limit dirt intrusion.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Old 03-06-2013, 08:41 AM   #6446
bross
Where we riding to?
bross's Avatar
Oddometer: 4,530
Or you can just buy dual sealed bearings.
bross is online now   Reply With Quote
Old 03-06-2013, 02:26 PM   #6447
bradluke0
Oddometer: 204
New (to me) DR200
Hi all ! I just went out and bought a 2005 DR200 , gonna use it as an extra bike for guests and to play around here on the property . The previous owner could not find the owners manual and I cannot find one anywhere online . Anyone know where I can get one ? Also , the petcock has reserve , on and prime . What is prime used for , if I run out of gas ? Also , is the garage going to flood with gas if the float sticks in the carb? thx guys looking forward to seeing what this bike can do !
bradluke0 is offline   Reply With Quote
Old 03-06-2013, 02:44 PM   #6448
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,049
Reserve and On are controlled by vacuum. They're only really on when the engine is running. Prime lets fuel run into the float bowl regardless of whether the engine is running.
windigo
Old 03-06-2013, 03:19 PM   #6449
bradluke0
Oddometer: 204
Hi all ! Thx for the info , that makes sense now that i think about it . I think all of my street bikes had vacuum operated petcocks , just no prime setting . Whats kinda funny is my son and I each have a ktm 450 in the garage but I'm really stoked about this bike . By reading a lot of the posts on here I see alot of other people love their DR too ! thx again for the info
Old 03-06-2013, 07:45 PM   #6450
Goon310
Goon310's Avatar
Oddometer: 52
Got my Kenda K270 on.
I dig it.
Went for a short putt-putt.
Bike is LOUD but sounds good.
Hesitation between 2nd and 3rd, full throttle and slow acceleration.
Turns out my flippin' choke was out half way when I first started - but did not ride - the bike after jet kit install.
So, this weekend will get the carb set up proper.
Times are GMT -7.   It's 04:13 PM.
