Old 03-15-2013, 11:16 AM   #6481
bradluke0
Oddometer: 221
Hi all ! I would re-torque the head down with a torque wrench and see if that helps . If not , I would just deal with it ( small leak) or replace the head gasket ( big leak).
bradluke0 is offline   Reply With Quote
Old 03-15-2013, 11:54 AM   #6482
Goon310
Goon310's Avatar
Oddometer: 52
I'm going on a ride after work today, and will wipe the head off before leaving.
If there is a butt load of oil all over, I'll order a gasket and try and fix it.
If not, I'll torque everything down and put up with it.
The bike did sit for a long time before I got it, 6 or so years in a garage and was "cleaned up a bit" according to PO and rode a little then back into garage as he bought more bikes. So, I imagine whatever gasket was or is there probably dried up good deal and is just seeping a bit.
I'll report back with what I find after todays ride.
If I don't have too, I don't want to have to take it all apart.
Don't need another project bike with lots of down time.
They all become a project sooner or later
Goon310 is offline   Reply With Quote
Old 03-15-2013, 01:29 PM   #6483
ADVCoop
ADVCoop's Avatar
Oddometer: 792
We went for a ride Sunday and I noticed my wife's bikes squeaking a lot on bumps. So I ordered up all new swing-arm and linkage bearings. Started the tear down today. Some of the troubles I had today with rusty bolts, etc., are my fault. Lack of maintenance last year and neglect over two winters.
Stuck swingarm bolt. That took some persuading to get out:
Something's missing I just can't figure out what...Actually in the blurry pic you can see the linkage hanging. The swingarm had to come off to get to that top bolt.
Shock apart. Other than being mega dirty it seems ok. I wanted to take it out for awhile because the pre-load adjusters were rusted and wouldn't turn and it was set way too heavy for her.
2006 Husqvarna TE610 - 1982 Suzuki PE175 - 2009 Yamaha XT250 (wife's)
ADVCoop is offline   Reply With Quote
Old 03-15-2013, 01:38 PM   #6484
JayGoldstein
Oddometer: 68
Originally Posted by Ddgfarm View Post
I called Slipstreamer and they recommended this model too for the DR200.
I have a ScreensForBikes light tint screen. The last three photos in their DR200SE gallery are of my bike (www.screensforbikes.com/gallery/suzuki/dr-200-96-10/).
I opted for a smaller screen because I was concerned that something the size of the S-06 Spitfire might create too much resistance when riding into a strong headwind (something I have to contend with frequently here on the prairies). The ScreensForBikes screen fits well, helps to deflect wind and insects, and (IMHO) complements the looks of the bike.
Jay
2009 DR200SE: ManRacks rack, ScreensForBikes windshield, Wolfman tail bag, 16T sprocket, Kenda K761 tires, Moose Racing CR-HI handlebar, Renthal MX grips, Polisport fender.
JayGoldstein screwed with this post 03-15-2013 at 04:04 PM
JayGoldstein is offline   Reply With Quote
Old 03-15-2013, 05:40 PM   #6485
bradluke0
Oddometer: 221
Hi all ! Well crap , now my bike has developed an oil leak on the left rear corner of the engine , at the base gasket. So I decided to try and tighten the base nut on the stud . Tightened it some , still leaking . So I made a decision ....tighten down until it quits leaking or snap it off . Either way it will either stop leaking , not stop leaking or the stud will pop . Well the dang thing snapped off so I tore down the whole top end . The bore looks good , the piston looks good and the head looks good . It has 4000 miles on it so I will probably have the cylinder honed and new piston and rings installed . The source of the leak ? The base gasket was broken all the way across , just next to the stud .
Old 03-15-2013, 06:03 PM   #6486
Goon310
Goon310's Avatar
Oddometer: 52
No way!
Mine's got 4K on it too.
I didn't go on a ride tonight, had some other crap to deal with.
But I'm going to take a long ride tomorrow and see how much oil seeps.
If it's not a lot, I'll torque it down and put some Suzuki/Yamaha/Honda-"Bond" sealant around where I think it's leaking. If that doesn't fix it I'll buy a new gasket.
My oil site glass doesn't show a noticeable reduction of oil, so it's not like it's draining out and dripping all over the place.
Do you have the torque specs for the cylinder head?
I can't find them online and my owners manual is extremely basic.
Also, JayGoldstein, I dig that windshield, reminds me of a KTM 990 or something. Unique look.
Old 03-15-2013, 08:42 PM   #6487
bradluke0
Oddometer: 221
Hi all ! I do not have a service manual yet , ordered one on ebay last week . I should have it by next weekend . I will look up the torque specs when I get it . After cleaning up the head and cylinder I think I am just going to put it back together with new gaskets . The ring gap is very small .006 and .0065 inches and it doesn't change in the bore as I checked them at the bottom , middle and top . After cleaning up the piston it looks great , no scratches or anything on the skirts . Wisdom would probably dictate I use new piston , rings and fresh hone . Unless convinced otherwise I am going to cheap out . Bike will be ridden less than 1000 miles a year .
bradluke0 screwed with this post 03-16-2013 at 08:05 AM
Old 03-15-2013, 09:40 PM   #6488
Goon310
Goon310's Avatar
Oddometer: 52
Appreciated!
I figure I'll go for a ride and torque it down when its warm for now?
Old 03-16-2013, 05:45 AM   #6489
bradluke0
Oddometer: 221
Hi all ! Probably only torque when cold , with no specs it's hard to know how tight . Does anyone with a manual able to post the torque specs and maybe the few pages where the top end is assembled ? thx in advance for any info.......brad
Old 03-16-2013, 05:48 AM   #6490
ADVCoop
ADVCoop's Avatar
Oddometer: 792
Originally Posted by Goon310 View Post
No way!
Sorry the formatting will be weird but I copied/pasted this from my .pdf manual.
TIGHTENING TORQUE
ENGINE
ITEM Nm kgf-m lb-ft
Cylinder head cover bolt 10 1.0 7.0
Camshaft sprocket bolt 11 1.1 8.0
Cylinder head nut 8 mm Diam. 27 2.7 19.5
Cylinder head nut 6 mm Diam. 10 1.0 7.0
Cylinder base nut 10 1.0 7.0
Starter clutch securing bolt 25 2.5 18.0
Cam drive chain tension adjuster bolt 7 0.7 5.0
Generator rotor nut *80 8.0 58
Crankcase bolt 11 1.1 8.0
Primary drive gear nut 50 5.0 36.0
Clutch cover bolt and generator cover bolt 10 1.0 7.0
Starter motor lead wire connecting bolt 25 0.25 1.8
Starter motor mounting bolt 10 1.0 7.0
Clutch sleeve hub nut 50 5.0 36.0
Gearshift arm stopper 19 1.9 13.5
Engine oil drain plug 28 2.8 2.0
Oil filter cap nut and oil pump filter cap bolt 7 0.7 5.0
Engine sprocket bolt 25 2.5 18.0
Engine mounting bolt (Top side) 41 4.1 29.5
Engine mounting bolt (Front side) 88 8.8 63.5
Engine mounting bolt (Rear side) 10 1.0 7.0
Engine mounting bracket bolt 41 4.1 29.5
Exhaust pipe nut 23 2.3 16.5
Muffler connection bolt 23 2.3 16.5
Muffler mounting bolt (Front side) 23 2.3 16.5
Muffler mounting bolt (Rear side) 44 4.4 32.0
Old 03-16-2013, 08:25 AM   #6491
bross
Where we riding to?
bross's Avatar
Oddometer: 4,701
No way!
Baby powder is a great way to find a leak. Sometimes it's hard to pinpoint exactly where a leak is coming from on a bike because the oil gets blown up, back and everywhere away from the actual leak. Clean the engine really good, pressure washer if you're careful. Let dry, then sprinkle, shake, blow on the baby powder. Go for a short ride. The leak should be clearly evident in the baby powder. Good luck.
Old 03-16-2013, 03:22 PM   #6492
pozo
Oddometer: 7
"Can you post a pic of your Spitfire, and model # if possible? I would like to add one to mine :)"
I haven't gotten mine yet, but there is a picture on post 652 in this thread. It is the Spitfire S-06. Here is a link to the manufacturers web site: http://www.slipstreamer.com/Product/Sport/sport.html. I called Slipstreamer and they recommended this model too for the DR200.
Motorcycle Superstore and Amazon have them.
That's right. I got mine at Amazon for $70: http://goo.gl/QxRMu
pozo is offline   Reply With Quote
Old 03-16-2013, 04:38 PM   #6493
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,602
Idle Screw
When pounding around the single track, the idle screw tightens up. This of course makes the bike idle fast, which means stopping my trail ride to re-adjust the screw back to normal.
Anyone else have this problem? The fix?
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 03-16-2013, 05:20 PM   #6494
Goon310
Goon310's Avatar
Oddometer: 52
Hey all.
I think my leak is coming from the tapet adjusting cover?
I am not sure what the actual name is, I forget.
But it is the circular covers at both the front and rear on top of the engine.
They were both loose, and covered in oil.
I tightened them, and changed my oil to 20-50.
I will also try the baby powder trick, and I bought some RTW black sealant I will put once I find the leak. I will ride tomorrow and try and locate it, today it seemed as if it only came from those circular covers. Seeping, not a dripping leak, though.
Old 03-17-2013, 07:59 AM   #6495
Codyp1814
Oddometer: 11
Hey all.
You can be easily fooled on where it is exactly leaking. I had the same leak up around there and I thought first it the camshaft plug, then the front valve cap seal, then rear valve cap seal, so I just replaced all 3 seals. I still don't totally know which one it was.
http://www.powersportsplus.com/parts...EAD/parts.html
Buy #16 (comes with both front and rear seals) and #17 (cam plug).
2007 Suzuki DR200SE
2008 Kawasaki KLX140L
Codyp1814 is offline   Reply With Quote
Times are GMT -7.   It's 10:16 AM.
