Old 06-25-2013, 11:19 AM   #6856
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 101,323
Originally Posted by MacWord View Post
Just got a 2000 DR200 with 5800 miles. It runs well, and seems to have plenty of pep. No oil on the spark plug, no oiliness in the exhaust. No smoke.
But in testing the compression, I'm only getting 90 pounds. I'm fairly certain the gauge is accurate. Am I missing something in the process here?
I don't have an answer to your question. But if it's running well, why think about it?
windigo
Old 06-25-2013, 05:01 PM   #6857
mykdee
Oddometer: 107
Just spoke to the owners of Seat Concepts, they just released their seat kits for the DR200 again! Also I asked about a rear rack for our bike, and they do not have one, BUT they did say if there is enough of us interested in buying one they would consider building one! So please post on this forum if you are interested, they said they would keep an eye on this sight for interest!
seatconcepts.com
mykdee is offline   Reply With Quote
Old 06-25-2013, 05:14 PM   #6858
bross
Where we riding to?
bross's Avatar
Oddometer: 4,519
A few pics of a DR doing what a DR does best...
Old 06-25-2013, 06:12 PM   #6859
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,206
So installed these hand guards which are made in the USA.
Cycra Probends
They have taken some abuse, and done well.
But I noticed that the front brake line was rubbing between the front blinker, and the probends on the trail. The outer brake would leave little rubber bits as the front wheel dropped and rose. I decided to armor the brake line with this stuff:
It seemed to work okay, but didn't really seem ideal. Over the winter, Racetech did the front forks, so the front end dive was noticeably less.
Come spring, we went 2000 miles of dirt. Poor little bike came home and had worn through the front brake sheath. Decided to replace it before I broke it. The stainless Galfer was cheaper than the OEM brake line.
Since the new line is about 1/2 the diameter of the OEM, looks like rubbing shouldn't be an issue. (PS don't use the Galfer supplied bolts..they appear to be coarse thread vs fine thread).
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito screwed with this post 06-25-2013 at 07:03 PM
Dorito is offline   Reply With Quote
Old 06-25-2013, 07:58 PM   #6860
mykdee
Oddometer: 107
Picked up a new set of brak busters and installed them today. Also removed wheels to have new tires installed tomorrow. Much more difficult then my KX250!
I think I need more room to work on my bike!
Old 06-26-2013, 01:26 PM   #6861
northsouth15
Oddometer: 206
Originally Posted by JayGoldstein View Post
Tires.
I wanted a tire biased towards pavement riding. Based on reviews on the web and cost I chose the Kenda K761 (which is rated as 80% street & 20% dirt): 90/90-21 front and 120/80-18 rear. I run them at at 27 psi. front and 30 psi rear.
how is the turn in with the wider tire compared to the OEM bridgestones?
one thing I like about the dr200 is that it literally "falls" into turns...making it very easy to ride
I ran a 120 instead of a 110 on a Ninja 600R and had to muscle the thing into turns (where it was unstable)
I'm also looking for a good street tire so I can run supermoto days and hunker around long beach
northsouth15 is offline   Reply With Quote
Old 06-26-2013, 02:58 PM   #6862
JayGoldstein
Oddometer: 64
I didn't notice any difference. The increased leverage provided by the wider Moose Racing handlebar may have cancelled out any effect of the K761's greater mass.
Jay
2009 DR200SE: ManRacks rack, ScreensForBikes windshield, Wolfman tail bag, 16T sprocket, Kenda K761 tires, Moose Racing CR-HI handlebar, Renthal MX grips, Polisport fender.
JayGoldstein is offline   Reply With Quote
Old 06-26-2013, 07:15 PM   #6863
mykdee
Oddometer: 107
Got the tires installed today, went with Shinko 244's. Also install an Acerbis supermoto front fender.
Here is before, I think it looks much better now.
mykdee screwed with this post 06-27-2013 at 08:14 AM
Old 06-27-2013, 07:14 AM   #6864
jeffcneal
Oddometer: 35
Fender question
mykdee:
How much drilling and cutting is required on the front fender?
thanks,
Jeff
jeffcneal is offline   Reply With Quote
Old 06-27-2013, 08:10 AM   #6865
mykdee
Oddometer: 107
Originally Posted by jeffcneal View Post
mykdee:
thanks,
Jeff
I just drilled the 4 mounting holes and it went right on. No cutting required!
Old 06-27-2013, 08:29 AM   #6866
jeffcneal
Oddometer: 35
Great! Thank you sir. Drilling's fine, but my artistic talent is rather lacking.
thanks,
Jeff
Old 06-27-2013, 10:01 AM   #6867
JayGoldstein
Oddometer: 64
Will the Acerbis fender will keep water, mud, etc. off of the engine. It's hard to tell from the three-quarter view how far back the fender extends. Can you post a side-view?
Jay
Old 06-27-2013, 01:29 PM   #6868
bross
Where we riding to?
bross's Avatar
Oddometer: 4,519
Footpegs
Has anyone found wider foot pegs to fit the DR200? I bought some for my DR650 a few years ago and looked for the DR200 but couldn't find any. My wife hopped on my 650 on the weekend and said she sure liked my wider foot pegs. I just searched on-line and eBay etc. but nothing available. Any ideas beside building my own which isn't an option, no welder.
Thanks.
Old 06-27-2013, 03:13 PM   #6869
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,206
I was going to try these out...but alas, you also need a welder..
Weld-on footpeg extensions to make footpegs 1/2" wider and longer.
I've also seen them in drill only versions..like here:
BlastOff Adventures
Old 06-27-2013, 04:54 PM   #6870
bross
Where we riding to?
bross's Avatar
Oddometer: 4,519
Just checked and Pivot Pegs make a set for the DR200. Not cheap ($169) but will be worth it.
Times are GMT -7.   It's 03:25 PM.
