Old 02-17-2014, 01:00 PM   #7771
crashnzuk
2 wheel noob
Oddometer: 4
Hey guys, thought I'd check in. I just bought an '04 DR200SE. It is super clean with only 1,150 miles.
Travis..
crashnzuk is offline   Reply With Quote
Old 02-17-2014, 02:26 PM   #7772
BadDawg
BadDawg's Avatar
Oddometer: 56
Picture of plugged vacuum inlet on carb
The attached photo shows (at the end of the piece of pine straw) a rubber cap sealing the vacuum inlet of the carb on my 2007 DR200.
When you convert from the OEM vacuum petcock to the Yamaha manual one, you swap out the petcocks (no mods required), toss the vacuum line and plug (as done in photo) the vacuum inlet on carb. Thanks to Magestyk for helping me with posting the photo.
1982 Yamaha MJ50 Towny
1991 Honda NightHawk 750
2007 Suzuki DR200
BadDawg is offline   Reply With Quote
Old 02-17-2014, 02:44 PM   #7773
Magestyk
Bicycle NINJA
Magestyk's Avatar
Oddometer: 360
Thanks for showing where the plugs goes, BadDawg.
This is retarded question but I must ask anyways. Do I have to drain the Fuel tank, and unbolt/take it off to change the Petcock?
Or is it possible to do the change without doing that?
I'm gonna do this on my bike. I cleaned the Air Intake box twice in the last 2400 miles and I find a small amount of fuel on the bottom. From what I read that might be a sign of my Petcock is goin bad.
DR200
Magestyk is offline   Reply With Quote
Old 02-17-2014, 04:19 PM   #7774
BadDawg
BadDawg's Avatar
Oddometer: 56
I guess you could go two ways on this:
Approach #1 Remove tank. Remove the two side covers, then seat, then the two bolts on the tank. Drain most of the gas from the tank. (You can leave a little in the tank, probably the amount of "reserve" or less is okay.) With both hoses (gas and vacuum) detached, lift tank off. You can then lay it on its right side (so petcock side is higher) on a soft surface. Then the old petcock can be swapped with the new one. No spillage. [Note that most of the gas needs to be drained so that the gas level will be lower than the height of the gas cap when the tank is placed on its right side.]
Approach #2 Do not remove tank. In this case, you need to drain ALL the gas from the tank. Swap petcocks. Of course as soon as the old petcock is removed, you will have an open hole in the bottom of the tank through which any remaining gas will pour. Do this outside.
I took Approach #1.
2007 Suzuki DR200
Old 02-18-2014, 12:59 PM   #7775
Magestyk
Bicycle NINJA
Magestyk's Avatar
Oddometer: 360
Originally Posted by FishQuest View Post
Thanks for the input guys. Sounds like the 120 would just fit but like you said with the limited HP of the DR it may be better to stick with the 110.
Finally someone got a reply. I'm definitely gonna buy the Michelin T63 Dual Sport Rear Tire - 120/80-18 (Yours was 120/100-18) So I should be good to go with no problems.
http://tinyurl.com/n6l7t3j
Yeah, I'm gonna go with your #1 as well. Thanks again.
DR200
Old 02-18-2014, 02:10 PM   #7776
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,022
Travis..
Hey was that up near Pioneer?if so I was looking at it also,congrats nice bike!
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 02-18-2014, 02:31 PM   #7777
AJay112
ADV Debate Team
AJay112's Avatar
Oddometer: 2,166
Travis..
Congrats again on the purchase... man, these are neat bikes.
Okay, I'll go back to the KLR threads now. Have fun guys.
Taking it to life's manager.
AJay112 is offline   Reply With Quote
Old 02-18-2014, 05:14 PM   #7778
crashnzuk
2 wheel noob
Oddometer: 4
I'm not sure where pioneer is, though I did see several bikes listed there. This one was in Pine Grove, near Sutter Creek.
Travis..
Old 02-19-2014, 02:30 AM   #7779
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,473
Tire Choices
Here's the tire choices folks have listed to date on this thread. Klay does a pretty gosh darn good job of keeping page 1 updated for us, and the link is there too.
http://advrider.com/forums/showpost....postcount=6276
Originally Posted by Dorito View Post
So, I've combed the last 419 pages. Here are the 19 tires that are mentioned being used on the DR200.
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 02-20-2014, 01:35 PM   #7780
Evattman
Oddometer: 1
Sp 200
Well, this is the closest thread I could find that fit my bike. Last year I purchased a Suzuki sp 200 for 300 bucks. As Im sure everyone knows, the sp models came right before the dr's. I owned a 1997 DR 200 and besides a few plastic pieces and other small things, they are essentially the same. All I did to the sp 200 was clean the carb and added a few things to try and make it look less dated.lol
I also included a pick of an SP 125 that I picked up a few weeks ago for 100 bucks. I did have to replace all of the gaskets , clean the carb, and recover the seat. They both run pretty good considering Im not much of a tuning guy.
Evattman screwed with this post 02-20-2014 at 05:12 PM
Evattman is offline   Reply With Quote
Old 02-20-2014, 08:15 PM   #7781
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,022
Travis..
Yes that's where it was,Pine Grove,it looks like its clean and the price was right,dang Ill have to keep looking,congrats and enjoy!
Old 02-20-2014, 09:15 PM   #7782
ontargetnow
Mudslinger
Location: Mid Hudson River Valley of Communist N.Y. State
Oddometer: 75
Looks like I'll be owning one soon. ( again )
A friend of mine is going to sell a 2002 back to me after owning it for two years. It now has 2600 miles on her. Seems like a no brainer for $1000. I think I'll keep it and let others ride her as an introduction to the sport. It will compliment my TW 200 well, I think.
ontargetnow is offline   Reply With Quote
Old 02-21-2014, 08:32 AM   #7783
75monza
75monza's Avatar
Oddometer: 353
Thumb
Those 2 SPs look great to me. You did a good job.
2006 KTM 950 Adventure - Go Everywhere Bike
1993 Suzuki GSX1100G - Street Touring Shafty
2000 Suzuki DR200 - A Little Smaller
75monza is offline   Reply With Quote
Old 02-21-2014, 12:23 PM   #7784
packerbacker
packerbacker's Avatar
Oddometer: 213
noob checking in from wisconsin...just bought a clean 98 with low (1500) miles, this is also my first electric start/street legal bike - here is a quick cpl pics of how i got her home too. Yes, you can fit a dr200 in the back of a dodge caliber :)
packerbacker is offline   Reply With Quote
Old 02-21-2014, 01:19 PM   #7785
packerbacker
Oddometer: 213
I have seen a lot of peeps in this thread looking to upgrade their seat or make it more comfy and I haven't seen anyone mention fisher seats, nor was it listed on page 1 so I thought Id share
go pack go
Times are GMT -7.   It's 09:36 AM.
