Old 06-29-2007, 03:49 AM   #106
steve gs
steve gs's Avatar
Oddometer: 375
Originally Posted by Klay
fun from the bike all out of proportion to what it cost.
at least until gasoline is no longer available.
My larger bikes sit while I tour around on this pup.
A bike (as would be all MT rigs) that would be in tune with the times as the "resource wars" continue and perhaps escalate. It's fuel useage is not even a factor in it's operation. Even my 350 and 650 are at 60+ but the 200 gets the nod because of it's fit and utility. Also, a great bike for slipping in and out of those impromptu campsites.
steve gs screwed with this post 06-29-2007 at 03:55 AM
steve gs is offline   Reply With Quote
Old 06-29-2007, 12:15 PM   #107
killer dual sports
Oddometer: 3
Dr200se Carb Settings
Hi to all, just got a 96 dr200se. It had the infamous carb problems, previous owner installed a carb kit and never set it up right. I don't have a service manual yet. So, does anyone know what the float settings, should be? also any idea what to set the mixture screw to as a baseline?? Previous owner took to mixture screw out for carb cleaning. Just trying to get it running acceptable for this upcoming weekend. Thanks for your time.
killer dual sports is offline   Reply With Quote
Old 06-29-2007, 12:35 PM   #108
steve gs
steve gs's Avatar
Oddometer: 375
KDS;
With the carb inverted the flange to top of float but not the metal tongue is .51 +/- .04" or 13mm +/- 1 mm. By mixture screw I assume you are talking the pilot screw and that setting is to be learned by turning in prior to removal. Are you going to go with the extended version, that is available from www.kientech.com. Jesse is a great guy and could also help you with a spec setting if you need one.
Specs quoted per the '97 Suzuki DR200SE service manual.
Welcome aboard.
Also check out the Minimalist Tourer (250cc and under) thread for more on the DR200SE and other bikes.
Old 06-29-2007, 10:14 PM   #109
killer dual sports
Oddometer: 3
Right on, thanks for the quick response!! I did call Keintech, to see about the extended pilot screw, I am only about 2hrs from his shop. Jessie said, usually anywhere from 1 to 1 1/2 turns is a good place for the pilot screw.
I hope to get her dialed in sometime this weekend. Cool little bike, I can see where it would be more practical/ and comfortable, then my Honda XL600R.
Seems to pull me up my hill, 250lbs at 40mph very easily, Even with a messed up carb. Definately do-able, way cooler than a scooter. Thanks again Inmates...... I'll check back with a status report.
Old 06-29-2007, 10:29 PM   #110
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,601
This is very true. I've spent my life stealth camping, so I instinctively look for places to camp as I am riding. When I'm on the 200, I see them all over as I travel. It'll go almost anywhere I can push a bicycle.
Even though I'm over the hill and usually stay in motels now, I really appreciate all the extra camping options. I found the perfect stealth camp outside of Wahpeton, North Dakota. It was about half a mile down a field road to a grove of trees and brush that you could tell used to be a homestead, although the buildings were long gone. It was totally isolated and secure. That was a lot of fun. I just pushed the 200 into the trees and found a place to pitch the tent. My timing was perfect...I got the tent set up about 15 minutes before sundown, then darkness falls and your chances of being seen go way down. (it was a pretty good thicket anyway) I don't start a fire or anything and leave no trace.
Old 07-02-2007, 10:50 AM   #111
K44rll
K44rll's Avatar
Oddometer: 271
Jap spec DF200 & Djebel200
Recently visited Japan & saw these DF200's also a picture of my friends Djebel200's...
K44rll is offline   Reply With Quote
Old 07-02-2007, 10:51 AM   #112
K44rll
K44rll's Avatar
Oddometer: 271
DF200 Orange
Old 07-02-2007, 10:52 AM   #113
K44rll
K44rll's Avatar
Oddometer: 271
DF200 Camo
Old 07-02-2007, 10:53 AM   #114
K44rll
K44rll's Avatar
Oddometer: 271
Djebel200
Old 07-02-2007, 10:54 AM   #115
K44rll
K44rll's Avatar
Oddometer: 271
Trio of Djebel200's, left hand is the earlier model with square headlight guard
Old 07-02-2007, 11:17 AM   #116
Python423
TnAdvRiders.com
Python423's Avatar
Oddometer: 1,273
I like that rack on that bike. Wonder if we could import it from Japan?
Python423 is offline   Reply With Quote
Old 07-02-2007, 01:39 PM   #117
K44rll
K44rll's Avatar
Oddometer: 271
Close up of front & rear racks....
Old 07-02-2007, 01:40 PM   #118
K44rll
K44rll's Avatar
Oddometer: 271
Rear rack..
Old 07-02-2007, 07:45 PM   #119
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,601
I really like those front racks with the round headlights. I ought to try to fabricate a rack like that.
I've lusted over the Japanese-spec small Suzukis on the Japanese website. We're really deprived here in the states.
Old 07-02-2007, 11:57 PM   #120
ozadvntr
Planning that trip, again
ozadvntr's Avatar
Oddometer: 1,174
I got one of the AG style DF's from an Importer here in Brisbane for under
A$2K, a great bike for the Father in Law on his Farm. The guy had purchased about 15 Djebels and a couple of the DF's. They also have an Oil Cooler from memory.
Mick
ozadvntr is offline   Reply With Quote
Times are GMT -7.   It's 12:47 PM.
