01-16-2009, 10:43 AM
#1486 |
Oddometer: 136
My 350`s just been on a dyno to check jetting etc
23hp and 17.5ft lbs of torque Spec cv carb [with std jetting] and DEP silencer and a MT43 rear tyre 28,000mls I was hoping for 25hp but the silencer is holding it back slightly as its road legal |
01-16-2009, 11:23 AM
#1487 |
Oddometer: 532
straight cut
Cool thanks for the info. You said you ar running a MT43 rear tyre can you tell does this have any impact on the dyno results?
1994 DR350se |
01-16-2009, 11:52 AM
#1488 |
Oddometer: 136
Not much but does offer a better contact patch for the roller compared to a knobbly tyre
01-16-2009, 06:28 PM
#1489 |
Desert rider
Oddometer: 580
Thanks for your help
Thanks guys for your help. I appreciate the advice.
01-16-2009, 10:49 PM
#1490 |
Oddometer: 34
farkled dr350 pic test
01-16-2009, 11:02 PM
#1491 |
Oddometer: 34
pic test
Just tryin to see if the photobucket way of postin pics worked. Fixed this 94 se up at the end of the summer and took it on a 2900 mile trip from Wyoming to California up the coast and back through the Trinity mountains . Way cool bike, cruise at 70mph and 65 mpg with 16 41 sprockets. Offroad way better than the 1150 gs I has. Researched a bunch before I bought this bike with only 1500 on the clock. Just finished reading Mondo Enduro and the most impressive part was one 350 towing another 350 760 miles through Saudi Arabia. I need to find a big adventure for me and this bike. Greaqt forum this advrider. Good for winter bound cabins in the frozen wilds of Wyoming Scott
01-17-2009, 04:43 PM
#1492 |
Oddometer: 532
Great forum this advrider. Good for winter bound cabins in the frozen wilds of Wyoming
Good for the winter bound cabins up here in the great white north as well!! Nice looking bike, what is that strapped to the front of the skid plate? Maybe it is just the pic but it looks too small to be a tool container. A tire pump? How is the hard case mounted? The smaller one above the swing arm not the larger cases above the rear wheel. John p.s winter will not last for ever, winter will not last for ever, winter will not last for ever.....
1994 DR350se |
01-17-2009, 07:21 PM
#1493 |
Oddometer: 1,988
>"with 16 41 sprockets"
Whered'ya find the 16 tooth primary? I had heard they exist, but haven't located any available on the web. Nicely set up bike... |
01-17-2009, 10:17 PM
#1494 |
Oddometer: 34
The 16 tooths sprocket is the same as front sprocket for a drz400. They are listed for that bike from suppliers. The small cases are mounted to the passenger peg mounts and mounted as to break away instead of breaking my leg. Had soft bags there and I think I liked them better. The front tube is for hwy pegs and is conduit pipe mounted with U bolts with harley pegs at the ends. Corbin seat is sooooo nice. On that 2900 mi trip I had the stock seat with the wally world pad and truely almost had bleedings sores on my butt by the end. Had a KLR 650 I rode to Alaska and I like the DR better. That sixth gear makes a huge difference. They should have kept making this bike.
01-18-2009, 05:02 AM
#1495 | |
Oddometer: 116
KLR650 DR350 (sold) KLX250 "Obsolete doesn't mean a thing isn't any good--it just means they don't make it anymore" Von Dutch, May 1970 |
01-18-2009, 08:00 PM
#1496 |
Goin' Somewhere
Oddometer: 1,267
Nice DR350 ...
Is that a TCI rack ??? I"m curious to how you attached the GIVI side cases thanks
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - '09 DR650SE - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -- - '12 NC700X |
01-18-2009, 10:12 PM
#1497 |
Oddometer: 34
It is a tci rack. I ordered the givi mounting kit from happy trails and just had to weld two small brackets on each side. easy
01-19-2009, 03:18 AM
#1498 | |
Goin' Somewhere
Oddometer: 1,267
Can you post some additional pictures ?? Of the mounting plates you welded on the TCI rack, and with the bags on from the rear ?? What is the total width of your DR with the E21's mounted ?? Thanks ... , Larry
01-19-2009, 09:32 PM
#1499 |
Oddometer: 34
The width is 32 inches. I will try and get up some pics of the 2 plates I welded in for the givi mounts. Scott
01-21-2009, 05:25 AM
#1500 |
Oddometer: 10,906
The bike looks great! I'd recommend adding fork gaiters as the seals will not last long when exposed and you will most likely nick a fork tube that way as well:)
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038 Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703 |
