Old 03-12-2013, 05:16 AM   #15016
shank
Shank950
shank's Avatar
Oddometer: 823
Front head stud Nut whats the trick?
G,day
I want to drop the head and cylinder off the 350 while the engine is still in the frame.
What is the trick to getting access to the front of the engine, the head / cylinder stud/nut???
Shank
Vinny: What the fuck do you mean, replicas?
Sol: They look the shit, don't they? And nobody is gonna argue. And I've got some extra loud blanks, just in case.
Vinny: In... Oh, in case we have to deafen them to death?
shank is offline   Reply With Quote
Old 03-12-2013, 05:20 AM   #15017
markk900
markk900's Avatar
Oddometer: 445
Originally Posted by Greg Bender View Post
I placed great downward force on the screwdriver as I was turning it. The screwdriver slipped and drove directly into the flesh between my thumb and index finger.
After stopping the bleeding with shop rags and electrical tape, I ended up using a small vice grip tool to remove the bolt.
Whoever said that screwdrivers are the most dangerous tool in the shop wasn't kidding.
Yup yup yup...been there, done that....except I used duct tape....
After 35 years, finally bought an impact driver because I was tired of giving blood.....
markk900 is offline   Reply With Quote
Old 03-12-2013, 05:20 AM   #15018
Greg Bender
Oddometer: 1,170
Originally Posted by shank View Post
G,day
Shank
I've been able to access it with a combination wrench...though there isn't much room.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 03-12-2013, 05:25 AM   #15019
Greg Bender
Oddometer: 1,170
In my brilliance, I left the impact driver in the tool box :> :> :> :>
Old 03-12-2013, 06:50 AM   #15020
thump!
thump!'s Avatar
Oddometer: 1,363
G,day
Shank
12mm box end wrench
thump! is offline   Reply With Quote
Old 03-12-2013, 09:23 AM   #15021
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,243
Originally Posted by thump! View Post
12mm box end wrench
What he said.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 03-12-2013, 10:52 AM   #15022
MrPulldown
MrPulldown's Avatar
Oddometer: 3,163
Spring looks to be around the corner and it is time to start working on the bikes.
So I have a bastard child DR that I would like to get running. It was a 90DR350S. The PO crashed it and found a DR250S of the same year. Swapped out some busted stuff and then tried to swap out the motor. I think he bent/damaged the shift rod splined area of the 350 and did not think it was repairable.
SO what I have is a DR350 chassis with a 250 motor in it that I am trying to fire up. The PO said he could not get it running but didn't give any details. I figured out some electrical issues. The neutral swtich does not work. The Side stand safety switched is also damaged. Put the two together and no spark. Well there is one spark but not any more after the first. Bypassed the side stand safety and now I have spark. The wiring harness is all chopped up so it is hard to figure out what is what.
-Question: There are two wires hanging off the back near the battery (yellow circle). What are these for?? Look like they would go to the starter solinode (sp?). But this bike being a kicker doesn't have one fo those. The other two wires I know are for the battery.
-The neutral switch is a single wire connection. What is the other unused white connector in the white circle. It is a two wire jobbie.
-Carbs. The bastard bike came with a bin of parts including two CV carbs. I think they are the smaller ones used for the 250 as the engine side opening is smaller than the 350 pumper I have lying around to compare. I did not want to tear off my CV on my running bike to compare. One of the carbs is much freasher, but is msising the choke knob. Is there an easy way to swap them out?
-What is the screw on the bottom of the carb on the float bowl. (not pictured) Leads to a tube on the inside of the float bowl.
MrPulldown screwed with this post 03-12-2013 at 11:28 AM
MrPulldown is online now   Reply With Quote
Old 03-12-2013, 01:46 PM   #15023
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
When I fit a CV carb to replace my pumper, one of the float bowl screws was well stuck and the head of the screw was pretty wallered out. I took a Dremel tool to cut a slot for a flat tipped screw driver. Then, I held the carb in my left hand and the screw driver in my right hand. I placed great downward force on the screwdriver as I was turning it. The screwdriver slipped and drove directly into the flesh between my thumb and index finger.
Regards,
Gregory Bender
It's called a "line of fire" injury. Something we have ALL done at one time or another, most of us several times, some of us many times and will continue to do so periodically. In the work arena, a good employer will demand that employees simply NEVER place body parts in the line of fire from a hand tool. As a safety professional, I try to set a good example and since I made a personal policy of behaving the same way at home, I have not had any such injuries. Don't ask mee about how bad carb cleaner stings when it gets in your eyes however.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 03-12-2013, 01:52 PM   #15024
slartidbartfast
Oddometer: 4,863
Hold that sucker the wrong way or swing the hammer inaccurately and you can give just as much blood and maybe break a few bones for good measure. ...Unless you're talking about a powered impact driver, in which case you've only got concerns related to compressed air or electricity.
It's a (potentially) dangerous world out there, be adventurous but manage your risks.
Old 03-12-2013, 04:09 PM   #15025
markk900
markk900's Avatar
Oddometer: 445
Personally, I don't think a job is done right without a drop or two of my blood in or on it!
Kidding - normally pretty safe however one does make silly mistakes under the self-imposed pressure of trying to fix a problem....
Old 03-12-2013, 04:17 PM   #15026
markk900
markk900's Avatar
Oddometer: 445
Can't quite tell but I believe Light Green is for the Right side turn signal, so assume the other wire is for the Left side turn signal.
For the two wire hookup - can you see the color of the wires?
Can you read the code on the side of the carbs? That could help confirm what you have.
Old 03-12-2013, 04:52 PM   #15027
mustangwagz
mustangwagz's Avatar
Oddometer: 242
Regards,
Gregory Bender
Impact Driver, Dremel (as you stated) or my favorite is taking Vise-Grips, Bitting down on that stuck ole bitch, and giving it a little twist. Breaks em loose enough to take em out with the screw stick!
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Old 03-12-2013, 05:42 PM   #15028
markk900
markk900's Avatar
Oddometer: 445
Oh - the choke should be easy to move - carefully unscrew the plunger from the carb body (careful because the nut is made of plastic that will self destruct if you look at it sideways)....move to other carb, screw it back in.
Old 03-12-2013, 06:11 PM   #15029
MrPulldown
MrPulldown's Avatar
Oddometer: 3,163
That is it. Jsut grab the knob and start unscrewing. I will look into it tonight
Old 03-12-2013, 06:33 PM   #15030
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 726
Rim locks
Recently picked up a '99 and have been slowly going through it. Rebuilt the carb and suspension with some help from Jesse, added new bars, bark busters, grips and rear rack. Scored an Acerbis tank and got that all plumbed in. Also spent some time going over all the nuts, bolts and fluids.
During the test ride I found everything worked very well; she pulled hard all the way to redline, the brakes were better than I expected and the suspension felt pretty damn good. The only issue was the severely out of balance wheels. I R&R'd the front tire then static balanced it (took almost 3 oz!)- better but above 60 mph it was not pleasant.
The question for y'all is this: do you run without the rim lock, try to balance it out or just run it and not worry about the out of balance issue?
I will be using this for on pavement as well as some trail riding but my style is more "motoring along quietly" rather than jumping and roosting.
Are the rim locks even necessary for someone like me?
FireDog45 is offline   Reply With Quote
Times are GMT -7.   It's 12:33 AM.
