03-13-2013, 11:48 AM
#15046 | |
Oddometer: 1,270
I was under the impression that this was the BST31 carb found on the DR250 rather than the BST33 for the dr350. However micing the output orifice of the carb I get 1.296". That is pretty dang close to the 1.299 which would be 33mm. So you might be right.
94 DR 350 SE |
03-13-2013, 02:15 PM
#15047 |
Oddometer: 131
I used to rip valve stems out left and right with no rimlock when dirt riding. It depends on air pressure and how/where you ride. You could also install a second rim lock opposite of the first to help with balancing.
03-13-2013, 03:37 PM
#15048 |
Oddometer: 26
Beautiful day to go riding.
After some issues this winter with my 97', I tested her out today. Cleaned the carb last night, brand new UNI air filter, new brake pads and fresh oil !
03-13-2013, 03:56 PM
#15049 | |
Oddometer: 98
As others have said its a drain screw (in about as good condition as the one I just replaced....the head gets messed up pretty easily. |
03-13-2013, 05:33 PM
#15050 | |
Cultural Attaché
Oddometer: 21
Looks a bit weird, but hey presto, no balancing issues and no slippage, even with really low pressures. It works for me - YMMV. |
03-13-2013, 06:48 PM
#15051 |
Mad Scientist
Oddometer: 3,202
That's an old drag-racing trick also.
03-13-2013, 08:16 PM
#15052 | |
Oddometer: 11
98 DR350SE 82 Maxim 750 |
03-14-2013, 03:56 AM
#15053 | |
Cultural Attaché
Oddometer: 21
The tyre should be thick enough at this point to be able to estimate this, and the inner tube shouldn't be this low inside the tyre to be near the screw anyway. The photo that Stretch67 posted above shows how it's done very well.....and if it works on dragsters, we should be OK! |
03-14-2013, 04:12 AM
#15054 | |
Cultural Attaché
Oddometer: 21
03-14-2013, 11:19 AM
#15055 |
Mad Scientist
Oddometer: 3,202
Having no experience with running screws into a tire bead, you can take this with a grain of salt, but I wouldn't drill into the bead of the tire. Drilling may break one of the strands of wire in the bead, which couldn't be a good thing. Just drill the rim, and then slowly run the screw into the bead, allowing the screw to gently work its way between the strands of wire in there without breaking any of them.
03-14-2013, 12:00 PM
#15056 | |
Oddometer: 11
03-14-2013, 12:15 PM
#15057 | |
Oddometer: 153
03-14-2013, 12:32 PM
#15058 |
almost gnarly
Oddometer: 1,484
Personally, I don't find the rim locks to be difficult to deal with, once you get used to them. At first I thought they were a pain, but having changed tires numerous times now, they don't bother me at all, and I don't seem to have to use a lot of weight to get the tires balanced. YMMV
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
03-14-2013, 01:43 PM
#15059 |
wandering the desert
Oddometer: 720
My bead locks caused a flat on the dr350 by rubbing a hole in the tube. So out they went.
I personally don't see why they exist... I rode 25 miles through rough terrain on a flat on my Terra 650 a few weeks ago and it has no bead locks. I didn't have my tool kit because i bought the bike the day before. But nothing bad happened, just had to go slow.
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
03-14-2013, 06:09 PM
#15060 |
Oddometer: 118
