Old 03-17-2013, 11:34 PM   #15076
Sateev
Oddometer: 118
Originally Posted by 2bold2getold View Post
From my experience,.... not sure all jets are the same, but the ones I've checked are sized as a % of a mm. so a 100 jet is equal to ~ .040" diameter. ... Then a 50 jet would be ~ .020" and a 40 jet would be ~ .016". I've got no problem running a correct size drill bit through jets to clean them or taking a small one and drilling it to the size I need, been doing it for years.
Jets may be nominally sized in % of 1mm, but they are classified by FLOW. And flow is affected by finish, which is why you don't want to drill jets to a particular size, or run any sharp tool through them. The surface finish of the hole has a very large effect on flow.
Just sayin'
Sateev is offline   Reply With Quote
Old 03-18-2013, 08:35 AM   #15077
DrKrisz
Oddometer: 4
Hy All!
I'm new here. I have 99' Dr 350.
DrKrisz is offline   Reply With Quote
Old 03-18-2013, 08:37 AM   #15078
DrKrisz
Oddometer: 4
2.
Old 03-18-2013, 09:09 AM   #15079
DrKrisz
Oddometer: 4
mail-attachment.googleusercontent.com/attachment/?ui=2&ik=e402c4ca3c&view=att&th=13b7b17252ea6a3e&attid=0.1&disp=inline&realattid=f_hagvxdxc0&safe=1&zw&saduie=AG9B_P-5jNLnDBu5j4yCTGABL2mE&sadet=1363619373397&sads=T1NlRD_8I_apijrOpAmj2JDcdKQ
Old 03-18-2013, 09:19 AM   #15080
original mcguiver
original mcguiver's Avatar
Oddometer: 30
Just sayin'
I have been working on "every" type of 2 wheel motorized vehicle since 1958. I totally agree with 2old2getold; you can drill jets with good results and I've been doing it for decades. Drilling a hole in brass is not rocket science (how do you think the manufactures do it?) When what your working on has no parts available it is the only way to go. You can even solder them closed and drill them for a smaller jet size. I had to do this on every Moped sold at high altitude or they wouldn't run well enough to pull the hat off your head. Never had a problem........Just sayin
A little experience disproves a hell of a lot of "theory"
original mcguiver is offline   Reply With Quote
Old 03-18-2013, 09:28 AM   #15081
2old2Bbold
was 2bold2getold
Oddometer: 1,698
Just sayin'
Yep, was expecting some feed back on this one. That's why I started with the disclaimer "FROM MY EXPERIENCE". And I have some, but of course that's subjective. If you don't like it don't do it.
2old2Bbold is offline   Reply With Quote
Old 03-18-2013, 11:24 AM   #15082
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
Originally Posted by DrKrisz View Post
Hy All!
Hi DrKrisz. Welcome to the DR350 forum.
Go here to learn about how to post pics
Go here to practice posting pics
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 03-18-2013, 11:29 AM   #15083
slartidbartfast
Oddometer: 4,863
I've successfully done the jet reaming and soldering/re-drilling thing a few times - but let's be honest, it's a bit of a bodge! Worse, unless you deface the original size marked on the jet, you run the risk of screwing up any subsequent owner's initial tuning attempts (or your own, depending on how bad your memory is.)
Old 03-18-2013, 11:50 AM   #15084
MrPulldown
MrPulldown's Avatar
Oddometer: 3,163
I am going to try firing up with no hoses other than the petcock vac and the fuel line attached to the carb. Will this cuase an issue if the vents and drains are jsut open?
Anyone know the stock jetting on a 90, DR250s.
MrPulldown is offline   Reply With Quote
Old 03-18-2013, 01:38 PM   #15085
2old2Bbold
was 2bold2getold
Oddometer: 1,698
I never do this kind of thing unless I really need/have to, (the exception is idle/slow jets, see no reason to buy a new one every time they get stopped up) and I remark the changed jet so as to not get them confused. BTW I live at ~ 640 ft but do a lot of riding in NM and CO between 6k and 13K ft. The "98 DR350SE is the only bike I've had that didn't need any rejetting. Some of the older bikes needed a size or two smaller main jet and a couple had to go quite a bit more ( KLX300 & XR650R) the KLR650 was close, but a little smaller main cleaned it up some, but this one runs clean and strong completely stock. I love it.
2old2Bbold screwed with this post 03-18-2013 at 04:11 PM
Old 03-18-2013, 03:49 PM   #15086
duncanbojangles
Oddometer: 30
Stuff for sale in the flea market
Hey guys, I forgot to mention I have a few things for sale in the flea market: http://www.advrider.com/forums/showt...php?p=20977537. I've got a stock tank (with locking cap and key) and stock muffler left (sorry, the carb sold already).
duncanbojangles is offline   Reply With Quote
Old 03-18-2013, 05:10 PM   #15087
markk900
markk900's Avatar
Oddometer: 445
Originally Posted by MrPulldown View Post
I am going to try firing up with no hoses other than the petcock vac and the fuel line attached to the carb. Will this cause an issue if the vents and drains are just open?
No issue I can think of on the first question.....
On the second question, from the clymer manual both DR250 and 350 Dual sport with CV carbs are BST33 (so maybe you did get the stock 250 carb)...
Main 132.5 (350 is 135)
Pilot 40 (350 is 37)
otherwise pretty much identical.
markk900 is offline   Reply With Quote
Old 03-18-2013, 06:27 PM   #15088
_CJ
Retrogrouch
_CJ's Avatar
Oddometer: 1,572
Finally got around to making myself a ghetto-fab rack. Built from scrap metal I had laying around. Next up will be a cutting board saddle bag combo.
Moto since 2011, DR350
MTB since 1991, Full-Rigid Steel 1x8
_CJ is offline   Reply With Quote
Old 03-18-2013, 06:59 PM   #15089
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,277
TEACH ME YOUR WAYS.
Anonawesome is offline   Reply With Quote
Old 03-18-2013, 07:22 PM   #15090
mustangwagz
mustangwagz's Avatar
Oddometer: 242
"Ghetto-Fab Rack" looks great man! Id rock that baby till ya couldnt No-Mo'!! i have done this kinda thing myself before with my old XT350 (R.I.P.) Sometimes, the racks you build are the best....why?...cuz YOU made them, they work for what you want, and usually WAY stronger! lol I'm thinking bout RedNecKing some Ammo Cans onto the side of mine!
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Times are GMT -7.   It's 04:16 PM.
