03-19-2013, 05:57 PM
#15106 | |
Oddometer: 50
Thanks for the suggestions. |
03-19-2013, 08:13 PM
#15107 |
Fool
Oddometer: 55
I recently bought a project from my buddy, it's a street legal '90 dr350. He bought it last year and road it for the season before buying a drz. He replaced the carb with a new tm33 and after riding it with the new carb for a few months we installed a keintech header and fmf muffler, while we were dialing in the jetting with the new pipe it was acting a bit weird and eventually stopped running well at all. Now it won't rev all the way out.
I have cleaned the carb very thoroughly several times and changed the main jet out from 127.5 to 142.5. It runs best with the 127.5, but it still won't rev all the way. I'm pretty sure something isn't right because it should run aruond a 140. Pilot is stock. The choke (enrichment) doesn't seem to have much impact on how it runs at all. the bike idles and runs great, even at WOT, until you get it revved up. I've been screwing with the carb so much with negligible impact I'm wondering if it could be cdi. Or could there be fuel leaking through somewhere making it run way rich? Any help would be great, sympathy is also appreciated. The video is with a 140 main jet, it took me about 200 kicks to get it fired up, when it was running right it would start after 2.. It's pretty loud, you might want to turn it down before watching. e28rusty screwed with this post 03-19-2013 at 08:19 PM |
03-20-2013, 05:12 AM
#15108 | |
Oddometer: 153
thump! screwed with this post 03-20-2013 at 06:20 AM |
03-20-2013, 09:36 AM
#15109 | |
almost gnarly
Oddometer: 1,484
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
03-20-2013, 11:09 AM
#15110 | |
Oddometer: 1,270
94 DR 350 SE |
03-20-2013, 12:00 PM
#15111 | |
Oddometer: 539
I've had my 96 DR350SE for six years and run the stock CV carb and airbox, no issues, great power, excellent gas mileage. Leave the stock carb on and go riding. SP
1916 Ford Model T 1996 DR350SE |
03-20-2013, 12:29 PM
#15112 | |
Still a n00b
Oddometer: 190
I don't-......I can't even-......No comprendo |
03-20-2013, 01:10 PM
#15113 |
Oddometer: 520
From My Experience. (I've pretty much done nothing but work on motors all my life. In 1952 at 8 yo I was flying 1/2 A control line model airplanes with those little Cox .049 motors. If you could make those little things run you can probably make any thing run. Read every word of every Rod and Custom and HotRod magazine.
First car was a "49 Ford flathead V8. Put 3 Stromberg 97s on it with scavenger pipes. Thought I was cool. Had a "53 Belair Convertable. "59 Belair Hard Top, "65 GTO and a "68 Dodge Charger R/T 440 Magnum 375 HP. USAF Missle Electronics Guidance and Control Technician. Not quite rocket science, but pretty close. Opened my auto repair shop in "72 and averaged more than 2 major overhauls a week from "72 to "90, mostly air cooled VWs. Built a 440 for my 360 Dodge Maxi Van, Put a turbo on a VW Bus, built a motor for a Formula V race car, built a 4 carb Corvair for a Porsche 912, built buggy motors with two 2 barrel Webers (Webers are great) and Delortos. In "91/"92 ran a Cat 963 Track Loader at McMurdo Station in Antarctica. Closed my shop in "95 and went to work for a rental equipment co/ John Deere Dealer untill I retired. Finished 10th in the Texas State Enduro Circuit(250 class) in "74. Finished 9th in the Texas State Trials Championship Master Class in "76. Rides in Colorado, Mexico, New Mexico, Arkansas, Contintal Divide Trail and ~ 1/3 of the TAT.) Sorry for the long winded list of credits,got carried away and memory lane is just fun. Again, From My Experience. When you walk up on an cold bike that's been sitting for a few days or months, more than likely it's in a lean condition. It's probably not gonna start like that. Now, you can either apply the choke and kick/crank from that lean condition untill you get it rich enough to start or some how add enough fuel ( pumper squirt or pour some gas down the carb throat/remove the plug and add fuel) to make it a little rich and open the throttle to add air and kick/crank untill it gets lean enough to start. Down in Antarctica when it was 60 below zero and the big diesels wouldn't start we would soak a shop towel with gas and wrap it around the air filter. Knocked like hell, but it got em started. I don't recommend doing that. I'm sure you have had trouble starting your weed eater or mower after it has been sitting all winter, Dump the old gas, add fresh gas, pull the plug and put a LITTLE gas in the plug hole, open the throttle all the way and crank. It may only run a few seconds untill the prime is gone, but then it's in the right air/fuel condition to start. Works good for bikes too. Of course all of this assumes the rest of the motor is in good operating condition. BIG ASSUMPTION. So you guys with the e-start or pumper carbs have a little advantage (as long as you don't flood them) when it comes to starting. The kick start models with the CV carbs are gonna be the harder to start. That's why Greg says he kicks his through several times to prime it before he trys to start it. But then the guys with the CV carbs are gonna get better gas mileage and better altitude compensation. There are always trade offs. Hope this helps. |
03-20-2013, 02:09 PM
#15114 |
wandering the desert
Oddometer: 720
Got the DR350 going again.
And this is what happens when you pop wheelies in cowboy boots with no seat on the bike:
![]() Gonna go straighten out the bars now and take it for a ride on the trail.
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
03-20-2013, 02:31 PM
#15115 |
Oddometer: 98
Totally unfair Rugged! If its running well enough to throw you off I NEED TO KNOW WHAT YOU DID!
(ps. rash doesn't look horrible but it'll sting for a while!). |
03-20-2013, 04:12 PM
#15116 |
Oddometer: 26
removal of forks
Hey everyone,
Just a question on how to remove the forks from a 97' DR350SE. The reason is because I purchased new fork boots and will be replacing the old yellow ones with new black day star boots. The forks are stock on my bike, I'm assuming I have to put the boots on from the top of the forks once they are off. Thanks in advance! |
03-20-2013, 04:40 PM
#15117 | |
Oddometer: 1,270
Make sure you note how far up on the fork legs it was clampped. Mark with sharpie, so that you know where to reinstall them.
94 DR 350 SE |
03-20-2013, 05:59 PM
#15118 | |
Mid-life crisis sufferer
Oddometer: 200
I'm just throwing darts here but my gut is telling me you're running away from fuel. Of course that's assuming my first sentence is correct, if not i got nothin... |
03-20-2013, 06:32 PM
#15119 |
Oddometer: 191
IS IT running properly and correctly 100%? If so, you best be posting what ya came up with RE...cuz its been like Forever ago that this happend, fuck...you even went and bought a different bike...lol i see the DR gave you a booboo for trading it in! LOL So whatd ya come up with??
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. |
03-20-2013, 06:43 PM
#15120 | |
Fool
Oddometer: 55
The rubber looks new, and there's no varnish or anything in there. It looks like a new carb. I just snagged a used cdi on ebay so we'll try that in 3-5 business days, I'm not really sure what else could be going on. |
