Old 04-06-2013, 04:07 PM   #15376
markk900
markk900's Avatar
Oddometer: 464
Originally Posted by redleger View Post
I am short, and had a low spot underneath my foot so instead of keeping it up, I just kept going.
While I am not short, I did drop a friend's BRAND NEW Buell RR1000 (last one made) at 0 mph when the same thing happened....that little spill cost me plenty to correct!
It simply hurts my soul because the DR350 really is my baby. I am going to start tomorrow. Never changed out handle bard before, seems to be alot of crap to take off and put on for something so simple. Pictures will follow.
Not sure what bars you have but if they're steel you might be able to bend them back....depends on how bad the damage is. If you do have to change them out, its not as bad as it looks. Only the left grip ever causes me trouble no matter what people say about how to take them off. The rest of the stuff is mostly on split mounts so comes off pretty easily....
Hope the ankle heals up soon.....
markk900 is offline   Reply With Quote
Old 04-06-2013, 04:58 PM   #15377
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
Well it was time to get rid of the purple bars anyway. Got new grips and a fly racing set of bars cheap. It was on my to do list anyway. Just upped the priority. Now I gotta get that frame painted and I will be set. Ankle is ok. Just gotta wear a boot for a while but weather sucks now anyway so I am not missing out on much.
Thanks for the well wishes.
Sent from my KFJWI using Tapatalk HD
2000 KTM 200EXC
redleger is offline   Reply With Quote
Old 04-06-2013, 06:13 PM   #15378
2old2Bbold
was 2bold2getold
Oddometer: 1,834
Turn Signal Indicator
I couldn't figure out why you guys had to remove the indicator light to get your LED turn signals to work. I couldn't do that. I'd be running around all over the place with my blinkers on. Heck I can't even remember to turn mine off with the indicator light. Any way, after checking the wireing diagram, they use the two off turn signal bulbs as a path to ground for the indicator. Not the way I would have done it, but they didn't ask me. And my way would cost more but not much. If you want to use your indicator, cut the two wires from the indicator and connect one of them to ground. Then get two small cheap diodes (radio shack). Diodes are kind of like check valves. They let current flow one way but not the other way. Splice a wire from the power side of each turn signal to one of the diodes to the other indicator light wire. Same with the other side to the same indicator light wire. Both diodes to the same indicator light wire. The diodes will isolate the left from the right. Cathode to the turn signal---Anode to the indicator ( I think) If it don't work, turn em around. I get it mixed up. It works though. I did it on an old Gold Wing and on my Transalp when I added LED turn signals, extra LED indicators ( one for left and one for right) and retained the stock indicator. Actullaly, I don't know why you would want to use LED for turn signals any way. They aren't on enough to save much power (unless you don't have an indicator light ) unless you hook em up with a couple NC relays as running lights and turn signals. That's what I did on the TA. Hope this helps.
2old2Bbold is offline   Reply With Quote
Old 04-06-2013, 08:02 PM   #15379
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,906
The way Suzuki did it is the same way all other bike and car manufacturers have done it for decades. You get the right mode of operation without the need for troublesome semiconductors. Your solution is one way to do it but there are several others. You could also replace the single indicator bulb with two LEDs in parallel, each with one leg grounded.
On my DR I only converted the front signals to LED and the indicator light still functions correctly.
The benefits of LED turn signals include:
1) The "instant on" light is more noticeable
2) The lower current draw helps to avoid the headlamp dimming as the signals flash
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 04-06-2013, 09:02 PM   #15380
SFC_Ren
SFC_Ren's Avatar
Oddometer: 94
My cracked engine
Well not sure what could have caused this but it sure is trashed.
If anyone has a good right side engine case from a kickstart model DR350 or DR350S or see's one on their local craigslist. Or has a spare motor let me know please.
This is the transmission side of the right side engine case
This is outside the case behind the kickstart mechanism area
Behind where the clutch sits on the right side case
Inside the area where the kickstart assembly goes
SFC_Ren is offline   Reply With Quote
Old 04-06-2013, 09:17 PM   #15381
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
JB Weld.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 04-07-2013, 04:52 AM   #15382
markk900
markk900's Avatar
Oddometer: 464
Oh don't do that RE! - I'm drinking my morning coffee and almost choked!
SFC_Ren - I know you said you don't know what happened but holy cow - that's grenaded....
Old 04-07-2013, 05:11 AM   #15383
FireDog45
Mid-life crisis sufferer
FireDog45's Avatar
Oddometer: 817
I'd suggest picking up a new throttle tube from Jesse if you're still running the OEM grips. While some have successfully removed the stock grip from the tube it is a major PITA! For a few bucks you can save a LOT of headache.
Just my .02 after trying and giving up...
FireDog45 is offline   Reply With Quote
Old 04-07-2013, 05:40 AM   #15384
Chicken Helmet
I'm A Stumper™
Chicken Helmet's Avatar
Oddometer: 5,022
Originally Posted by RuggedExposure View Post
JB Weld.
+1
1988 KLR 650 Bare frame,swing arm & title For Sale PM for Details 2009 KLR 650 1994 DR 350
Originally Posted by WaterWheel View Post
From what I've heard, riding a DR feels just like riding a KLR except your head doesn't sway left and right constantly scanning the ditches for aluminum cans.
Chicken Helmet is offline   Reply With Quote
Old 04-07-2013, 07:37 AM   #15385
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 423
JB Weld.
Possibly the worst advice I've read on this forum...... replace the cases. And major forces caused that cracking. I have seen it before on this same thread...can't seem to locate it now.
2011 UPAT
rubberband is offline   Reply With Quote
Old 04-07-2013, 07:38 AM   #15386
SFC_Ren
SFC_Ren's Avatar
Oddometer: 94
Hahaha yep a little goes a long way huh?
JB Weld.
SFC_Ren screwed with this post 04-07-2013 at 08:02 AM
Old 04-07-2013, 08:06 AM   #15387
SFC_Ren
SFC_Ren's Avatar
Oddometer: 94
I agree and think he was just kidding about the JBweld.
What I thought had happened was that I had an oil leak on my stator cover and I thought that the leak caused overheating which caused the crack. But looking at it apart I'm beginning to wonder if I didn't kick start the thing too hard at one time while it wasn't exactly at TDC or something or maybe a combination of the two problems.
Old 04-07-2013, 08:17 AM   #15388
RuggedExposure
Oddometer: 1,247
That was a joke. I wouldn't even attempt to TIG that case together because it would just keep cracking.
Its works long enough to get it back together and put the bike on ebay under the listing "DR350 - like new!"
RE Fotowerks
Old 04-07-2013, 08:21 AM   #15389
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,564
Hey Ren here's one option http://seattle.craigslist.org/skc/mcy/3715599489.html I've seen another engine in Vancouver bc lately too.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 04-07-2013, 08:42 AM   #15390
Chicken Helmet
I'm A Stumper™
Oddometer: 5,022
I thought JB Weld was a KLR secret.
Times are GMT -7.   It's 11:52 PM.
