Old 04-29-2013, 10:01 PM   #15661
jmderyke
Miner
jmderyke's Avatar
Oddometer: 43
Originally Posted by Schneiderman View Post
So I have to ask about a topic that I already know has already been covered a lot... I've searched the forum and read a lot of posts and I'm still not getting it about the decomp lever.
I bought a 1993 dr350 last week, originally thought it was a Street model but now I have confirmed it is the dirt model. I was able to start it when I went to buy it, and once when I got it home, now I can't get it started again.
I've seen a lot of posts saying to pull the decomp lever in, let go of it, push the kick starter until the lever pops out, then kick hard. My decomp lever seems to pop out as soon as you move the kick starter, no matter where the piston is. Then if I try to kick without it I get compression and bust my ankle (got bit bad twice now).
Bike has gas, petcock on, choke on, etc...
Does the fact that my decomp lever pops out immediately indicate that the cable is adjusted incorrectly?
Am I supposed to kick hard with the decomp lever pulled in or not? I've busted my ankle twice already. I don't feel like owning a bike that will bust my ankle every time I try to ride it.
Ive seen this come up in the forum a lot so go motivated and made a video
http://m.youtube.com/user/jdburnouts...&v=BinUqlNElyo
jmderyke is offline   Reply With Quote
Old 04-30-2013, 05:43 AM   #15662
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,277
http://m.youtube.com/watch?v=wsNPbd0ruVw#
Hey I'm not sure if you're aware of this but apparently according to some guy on youtube, "ur bike not suppose to idle that high u will blow ur engine".
Better make some adjustments!
Anonawesome is offline   Reply With Quote
Old 04-30-2013, 05:44 AM   #15663
thump!
thump!'s Avatar
Oddometer: 1,368
That's pretty much how I do it too. The only thing I would add to your video is the admonition of NO throttle when kicking. When it had the BST33 carb I would begin the cold start process by leaning it over far enough to overflow the float bowl, thus "flooding" the carb... the same effect as a couple twists with the TM33.
As your video illustrates, it's not necessary to "jump on it". That's a recipe to break something. It only takes a brisk kick adequate to spin the engine thru the next compression stroke with crankshaft momentum.
FWIW, 94 and newer models have a lower primary gear ratio and each kick moves the engine thru more rotation than the 90-93 models. I think they are easier to start than the early models because of that. The engine in my 96 frame is a 93 off-road but I replaced the early model clutch and primary drive gear with the clutch and primary drive from the newer model for that reason.
thump! is offline   Reply With Quote
Old 04-30-2013, 06:12 AM   #15664
jmderyke
Miner
jmderyke's Avatar
Oddometer: 43
i messed up on one of the videos lol mine is the starting the suzuki dr 350 for dummies. I only know enough to get into trouble with computers lol
Old 04-30-2013, 06:55 AM   #15665
Schneiderman
Oddometer: 13
Originally Posted by Anonawesome View Post
Ahh kickstarting the DR. Okay here's my method that starts my bike cold every time. I have the pumper carb.
Full choke, pull decomp while giving throttle and kick it like 5-10 times. This primes the cylinder.
Slowly push the kickstart lever until I get resistance from compression.
Jump on it. (NO THROTTLE!)
If you do it properly you'll never have your leg suddenly stopped (trust me I know your pain)
Just don't kick it wherever it is in the stroke. That's when you'll kill your ankle and I did it like that for a while before I knew how to start it and I never got it started once like that.
You'll get used to it, just gotta get the method down.
Thanks, this description helped me out a lot.
The funny thing is, I had a DR350 when I was a kid and I figured this out quickly and never really had a problem starting it. But I found out when I bought this one that I had completely forgotten whatever technique I was using before.
Schneiderman is offline   Reply With Quote
Old 04-30-2013, 07:03 AM   #15666
Schneiderman
Oddometer: 13
So I cleaned the carb yesterday (TM33 pumper) and replaced some seals, needle valve, etc. Got the bike started and it is running very rich, and stuttering/popping. It is also idling very high, with the idle screw turned all the way out. Where should I start looking for problems? I replaced the pilot screw and set it out about 2 and 1/4 turns, which I thought I had seen recommended somewhere. First thing I am going to do is check the float level.
(PS just wait till I start asking questions about the wiring... previous owner(s) did a number on this poor bike!)
Schneiderman screwed with this post 04-30-2013 at 07:09 AM
Old 04-30-2013, 08:24 AM   #15667
dentvet
Oddometer: 1,364
I need to find how long the head tube is, can somebody measure theirs for me? contemplating a fork swap.... thanks!
dentvet is offline   Reply With Quote
Old 04-30-2013, 09:41 AM   #15668
thump!
thump!'s Avatar
Oddometer: 1,368
Cold start enrichment circuit?
Old 04-30-2013, 09:43 AM   #15669
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,243
How the hell did you get that plate? Jealous.
This is the story: The NM DR350 dirt bike
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 04-30-2013, 04:22 PM   #15670
travis789
travis789's Avatar
Oddometer: 103
first farkle ordered, and a aftermarket gas tank ?
I just mailed off a fleabay seat pan to Seat Concepts today! The next upgrade I am thinking about is an oversize gas tank. I notice most of them come with their own vented gas cap with a tube. I'm wondering if I'll still be able to use my stock locking gas cap on any of these tanks, I like the added security.
“Immorality is the word we use to describe people that are not sinning the same way we are.”
― Shannon L. Alder
travis789 is offline   Reply With Quote
Old 04-30-2013, 04:25 PM   #15671
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,040
The stock cap will not work, but Acerbis offers a locking cap for theirs:
http://www.rockymountainatvmc.com/p/...ocking-Gas-Cap
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 04-30-2013, 04:46 PM   #15672
travis789
travis789's Avatar
Oddometer: 103
Thanks Wadester, you just saved me a lot of searching!
― Shannon L. Alder
Old 05-01-2013, 08:11 AM   #15673
Skeeter Cruz
Skeeter Cruz's Avatar
Oddometer: 15
Some updated info on mine!
Complete motor rebuild and bored out to 440.
Mikuni carb. FMF exhaust.
RMZ250 fork.
Supermoto-ed with DNA wheels and Distanzias.
Complete tear down to frame/cleanup.
Rewired whole bike very minimalist.
Next up: try to convert headlight to HID (for cheap!) and a bigger fuel tank.
Skeeter Cruz is offline   Reply With Quote
Old 05-01-2013, 08:28 AM   #15674
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,816
That's very nice looking!
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 05-01-2013, 09:33 AM   #15675
RuggedExposure
Oddometer: 1,243
RMZ250 fork.
Write up on the RMZ250 fork please! What year was the donor RMZ?
RE Fotowerks
Times are GMT -7.   It's 09:20 AM.
