Old 05-08-2013, 06:22 PM   #15781
Airvent
Airvent's Avatar
Oddometer: 347
Originally Posted by Rich667 View Post
The gap looks bigger in person.
[IMG][/IMG]
Now thats what I'm talking about! Freakin' awesome
Airvent is offline   Reply With Quote
Old 05-08-2013, 10:00 PM   #15782
pnw
Oddometer: 149
missing case saver
I discovered that po of my Ď99 SE had changed the front sprocket to a 16t, he took out the case saver and used nuts to space the sprocket cover. It sounds like a case saver is a good idea but I canít find one online. Someone mentioned Bike Bandit as source but they donít have one listed for this bike. Any ideas or just try Suzuki dealer? I also see that the sprocket ate into the plastic swing arm guard, it doesnít look like it is going to fall off but I donít see that as a problem mentioned for the 16t sprocket. I put a 13t sprocket on and gearing is now much more to my liking.
pnw is offline   Reply With Quote
Old 05-09-2013, 02:31 AM   #15783
cwc
Oddometer: 939
http://www.bikebandit.com/1999-suzuki-dr350se/o/m22310#sch244679 #34
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc is online now   Reply With Quote
Old 05-09-2013, 04:30 AM   #15784
markk900
markk900's Avatar
Oddometer: 468
Originally Posted by MrPulldown View Post
Your carb looks funny, is that a BST33?
It looks like a normal BST converted to single cable, but the float bowl casting is also different. The code on the side (14D02) looks somewhat familiar - could this carb be off a DR250?
markk900 is offline   Reply With Quote
Old 05-09-2013, 05:14 AM   #15785
Greg Bender
Oddometer: 1,216
Originally Posted by mustangwagz View Post
Wait, Torque the head??... What you talkin bout willis? This need to be done on a regular basis? i musta missed this note...Please Explain
The Workshop Manual (see PDF page numbers 9 and 11 and 163) states that the cylinder head bolts (the four tapered shaft bolts that secure the cylinder head to the engine block) be re-torqued after the first 5 hours, then every 30 hours after that (for the "S" models: after the first 1,000 miles, then every 6,000 miles after that).
In practice, I highly doubt any DR350 has seen such regular tightening of the cylinder head bolts. Typically I'll do it about once a year, whenever I start seeing any leaks from the cylinder head cover. That gives me a chance to clean, inspect, and put on a fresh coat of sealant. If that cover isn't leaking, I don't touch it! :> :> :>
In my experience with my DR350, the cylinder head bolts rarely need any additional torque. I check by loosening one 90 degrees, then I'll re-torque that same one and note if I move past 90 degrees. Then I move on to the next one, etc. I do one at a time, so that I don't run any risk of dislodging the head gasket.
On a newly acquired DR, I would absolutely do this task because I wouldn't have any idea if it had ever been done in the past.
I hope this helps!
Regards,
Gregory Bender
Greg Bender is online now   Reply With Quote
Old 05-09-2013, 05:14 AM   #15786
jackanory
I am Jack's wasted life
jackanory's Avatar
Oddometer: 477
Pretty sure the first couple years were a single cable system. As far as I know it's a stock carb.
jackanory is offline   Reply With Quote
Old 05-09-2013, 05:34 AM   #15787
pnw
Oddometer: 149
Thank you! I made a bad search engine term choice(s).
Old 05-09-2013, 06:58 AM   #15788
original mcguiver
original mcguiver's Avatar
Oddometer: 32
Originally Posted by jackanory View Post
I routed my fuel lines the way I saw it had been done in this thread.
Remember that we have alcohol fuels to deal with now. It vaporizes easier than gas and the higher the altitude the more risk of vapor lock (I see your in Idaho). I'm in Colorado and have had this issue on Hot days until I did away with the inline fuel filter. Your filter being so close to the HOT cylinder doesn't help either. Hope this helps.
original mcguiver screwed with this post 05-09-2013 at 07:07 AM
original mcguiver is offline   Reply With Quote
Old 05-09-2013, 07:15 AM   #15789
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,910
I discovered that po of my ‘99 SE had changed the front sprocket to a 16t, he took out the case saver and used nuts to space the sprocket cover. It sounds like a case saver is a good idea but I can’t find one online. Someone mentioned Bike Bandit as source but they don’t have one listed for this bike. Any ideas or just try Suzuki dealer? I also see that the sprocket ate into the plastic swing arm guard, it doesn’t look like it is going to fall off but I don’t see that as a problem mentioned for the 16t sprocket. I put a 13t sprocket on and gearing is now much more to my liking.
I'm coming due for C&S replacement myself. Will that case saver work with a 16T sprocket (I had to lightly dremel the current one to fit a 15T in there)?
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is online now   Reply With Quote
Old 05-09-2013, 08:16 AM   #15790
2old2Bbold
was 2bold2getold
Oddometer: 1,842
http://www.advrider.com/forums/showp...ostcount=13738
2old2Bbold is offline   Reply With Quote
Old 05-09-2013, 09:59 AM   #15791
MrPulldown
MrPulldown's Avatar
Oddometer: 3,391
That is what I am talking about.
All years used a dual cable set up. Not jsut using a single cable but the cable attachment lobe thing is desinged to be a single cable set up.
The idle speed or throttle stop adjsutment is different too.
DR250 used a BST33 for the "S" and a TM31 for the dirt. The BST(CV) is exactly like the DR350's except for slight internal tweek to the jetting.
MrPulldown is offline   Reply With Quote
Old 05-09-2013, 10:17 AM   #15792
slartidbartfast
Oddometer: 4,910
Originally Posted by 2bold2getold View Post
Thanks! I think I remember seeing that post - but I also seem to recall someone saying there was more than one case saver that fits our DR350s.
Old 05-09-2013, 11:06 AM   #15793
thump!
thump!'s Avatar
Oddometer: 1,564
'90 and '91 model DR350S models had a single pull cable for sure. Don't know a thing about the 250 tho.
thump! is offline   Reply With Quote
Old 05-09-2013, 12:10 PM   #15794
2old2Bbold
was 2bold2getold
Oddometer: 1,842
That one is OEM "98SE.
Old 05-09-2013, 05:56 PM   #15795
markk900
markk900's Avatar
Oddometer: 468
Thump! is correct - just checked the parts manual and the L and M models had the BST carb with the single pull cable and the straight idle adjust....
For further reference, the N and P model had dual cable and the same idle adjust setup, and the R/S/T models had the dual cable (different pulley) and the curved idle adjust setup.
Times are GMT -7.   It's 05:54 AM.
