Old 05-23-2013, 10:30 AM   #15976
jackanory
I am Jack's wasted life
jackanory's Avatar
Oddometer: 476
Originally Posted by tonusmaximus View Post
that bike stand kills Jackanory.
haha! There isn't a square angle on it anywhere. Wobbly as hell but it probably could hold the 600lb Tiger.
jackanory is offline   Reply With Quote
Old 05-23-2013, 10:43 AM   #15977
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,257
I just noticed today that my right side fork reflector has been scraping my acerbis tank when full-right. I don't know if this is the case for anyone else but I just wanted to let y'all know to check before you damage it at all. I had a pretty good gouge out of it and I've only had it for a few months.
Anonawesome is offline   Reply With Quote
Old 05-23-2013, 11:36 AM   #15978
motolab
motolab's Avatar
Oddometer: 2,530
"close pitch end of spring should position bottom" thanks to Benders web site copy of manual. Cheers.
You'd normally put the close coils on the unsprung end (the close coils otherwise add sprung weight).
Regards,
Derek
motolab is online now   Reply With Quote
Old 05-23-2013, 11:38 AM   #15979
thump!
thump!'s Avatar
Oddometer: 1,282
Originally Posted by slartidbartfast View Post
Is this how to tell the difference between cartridge and damper-rod forks? My 93DR350S should have come with damper-rod forks yes? ...but I'm pretty sure it has an adjustment screw in the cap and at the bottom of the fork legs (not home to go and look right now.)
The caps on early damper rod forks have a large screw (~1 cm diameter) to adjust pre-load, the later cartridge forks have a small (~6 mm) recessed screw for adjusting rebound. Lots of other differences including different brakes and a larger diameter axle. Check the pic below:
thump! is offline   Reply With Quote
Old 05-23-2013, 12:57 PM   #15980
jackanory
jackanory's Avatar
Oddometer: 476
oh screw!!
that helps to explain the shavings on the screen, the rattle in the motor and the jumping out of gear. Hopefully the damage is minimal.
Old 05-23-2013, 01:32 PM   #15981
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 455
Good to know. Bought an Acerbis recently. Just finished new seals and adjustments. Ive been on my beemer and dr650 so much I forgot how fun this bike is! Gonna drop it for my big boy brother and my lady to ride it.
Sent from my SPH-D700 using Tapatalk 2
tonusmaximus is offline   Reply With Quote
Old 05-23-2013, 04:20 PM   #15982
Anonawesome
Scenic Rider
Oddometer: 1,257
Originally Posted by jackanory View Post
oh screw!!
Now the question is where the hell did that come from?
Old 05-23-2013, 05:03 PM   #15983
jackanory
jackanory's Avatar
Oddometer: 476
It's the dreaded shift drum bolt. Apparently quite notorious for loosening up, falling out and creating varying amounts of engine carnage.
Old 05-23-2013, 07:15 PM   #15984
Richklr650
Oddometer: 172
had the same problem
oh screw!!
same thing to mine but have a new bolt coming $6.00 plus $25. over night shipping
Richklr650 is offline   Reply With Quote
Old 05-23-2013, 10:51 PM   #15985
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,804
oh screw!!
This screw was loose and ready to fall out on both of the DR's I bought.
Pablo83 is offline   Reply With Quote
Old 05-23-2013, 11:27 PM   #15986
Rich667
Rich667's Avatar
Oddometer: 177
I know how you feel... my right handguard had a bolt that would rub the tank at full lock. I never noticed it till I saw a huge gouge in the top of my tank about a month after I got it.
Rich667 is offline   Reply With Quote
Old 05-24-2013, 03:17 AM   #15987
mustangwagz
mustangwagz's Avatar
Oddometer: 242
Shift Drum Bolt
So...this shift drum bolt...how many miles yinz got on your machines? or..when should a guy expect failure? i got 7k on mine..I dont have much trouble finding nuetral.. If bike is coasting i have no issues at all..if bike is sitting still running, SOMETIMES it takes that special touch.
Time to disect it?
-WagZ-
'93 DR350S
My attempt to roundup Local Riders..
https://www.facebook.com/dualsportridingwesternpa
mustangwagz is offline   Reply With Quote
Old 05-24-2013, 05:13 AM   #15988
markk900
markk900's Avatar
Oddometer: 439
Funny - mine rubbed on the left....I did a bunch of twisting and filing and now have about 1mm of clearance at full lock.
Guess it depends on which side you fall down the most!
markk900 is offline   Reply With Quote
Old 05-24-2013, 05:14 AM   #15989
markk900
markk900's Avatar
Oddometer: 439
Time to disect it?
I'm interested in this as well....I normally am the "if it ain't broke don't fix it" school but it seems the bolt loosening/falling out can be pretty unnoticeable until it completely fails....
Old 05-24-2013, 07:57 AM   #15990
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,559
I know my 99 with 20k mikes on it and the drum bolt is still tight. There is no reason for anyone not to check this. $12 for a clutch cover gasket and maybe 30 minutes of work and you have either fix it or have piece of mind.
Lay the bike on its side 10 bolts and it's right there. If you get the bike laying flat you won't even need to Mess with the oil.
Typos and nonsensical words courtesy of fat fingers on a make believe keyboard.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Times are GMT -7.   It's 12:13 PM.
