Old 07-03-2013, 03:25 PM   #16501
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,064
I know the Acerbis tank comes with it's own front mounts that use the top motormount bolts - but you still need the stock metal plate for the rear.
Only $210 at justgastanks.com Says for "S" only - but having installed one, I don't think it matters. Heat shield interference?
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 07-03-2013, 04:49 PM   #16502
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
and if you call clarke or IMS direct, they will make you a tank to fit your bike of whatever color you want. Since I have blue plastics on my DR350SE, they will make a Yami blue tank! Now I just gotta get the money :(
2000 KTM 200EXC
redleger is offline   Reply With Quote
Old 07-03-2013, 06:33 PM   #16503
thump!
thump!'s Avatar
Oddometer: 1,484
Might have to do with clearance of throttle cables/linkage. Left side on the S model (BST33). Right side on the off-road (TM33)
thump! is offline   Reply With Quote
Old 07-03-2013, 07:56 PM   #16504
Friedom
Opposable Thumbs Up!
Oddometer: 740
You've installed one on a dirt model? Where does the acerbis mount on the front? The picture does not show a bracket going up to the screws below the oil fill. And on that picture, there aren't any screws there. That leads me to believe that it mounts on the rubber circles that my bike is missing, else I could use my street tank.
I think I'm going to get out the dremel and carve a notch into a piece of rubber pipe to make it fit into the heat shield slots.
Or I could actually drill a hole and mount something there.. Oh the possibilities!
Meanwhile, I'm waiting for some seriously smelly epoxy/plastic weld to set on the tank now and see how it does. No luck with the water weld stuff. couldn't get it to be workable enough. Mind you, I'm trying to fix a 9"+ split :)
Friedom is offline   Reply With Quote
Old 07-03-2013, 09:54 PM   #16505
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,064
Here's some pics:
DR350 dirt
You can see the threaded boss for the dirt tank mount - and you can see that raised round bit - where a street bike would have a post for a rubber bumper
Here's a hack to put a street tank on a dirt bike (using an acerbis rubber bumper):
Here's a street bike:
You can see no threaded boss, just a raised round bump where the dirt bike had a threaded post - and you can see the post where the rubber bumper should be.
Oh! Oh! And here's both an Acerbis mount - and the street rubber bumper!
And the other side:
And another
Here's the back mount for a street bike - I think that's a Clarke, but Acerbis is similar - plate screwed to plastic tank, attached to original frame bracket - horns hold front of seat.
And here's a gratuitous pic of my DR
Old 07-03-2013, 11:31 PM   #16506
Friedom
Oddometer: 740
Here's some pics:
There's the money shot! Wait! They're all money shots. Major gratis for the dr350 gas tanks 101 course!
I love mods that aren't permanent. This is excellent.. Now to find some rubber bumpers. Think I'll borrow em off a "donor" bike.
Cheers man, that made my life a while lot easier!
I might print out a pic of your ride and tape it onto mine..
Old 07-04-2013, 06:07 AM   #16507
tominboise
Oddometer: 768
My street model, with CV carb, has a wee bit of a choke problem. When I start it cold, the choke knob tends to open by itself and then the engine dies. I have to hold the choke closed until the engine warms up. Any thing I should look for next time I'm in the carb?
tominboise
1995 DR350SE - mini adventure bike,,,,
1982 R80G/S - bigger adventure bike,,,,
1995 R1100R - touring adventure bike,,,,
tominboise is offline   Reply With Quote
Old 07-04-2013, 02:05 PM   #16508
thump!
thump!'s Avatar
Oddometer: 1,484
The "choke" is technically an enrichment circuit. The are little ridges on the shaft that hold it in place in the on and half-on positions. The entire assembly can be removed and replaced or maybe repaired. I've seen small zip-ties used around the rubber dust shield to make them snug on the shaft.
Old 07-04-2013, 02:55 PM   #16509
mwilliamshs
Oddometer: 233
basic question
Does the DR faithful have a preferred clutch/brake lever replacement? I've searched and found EMGO, Motion Pro, MSR, Moose, blah blah etc. Forged, cast, snapback, with molded in grips, black, polished...long lists. I'm looking for a simple lever that fits correctly, feels okay, and that will neither break the bank nor the first time I dump the bike. I have sturdy handguards and ride cautiously but hope to only buy new levers once. I have broken (but usable) stockers for spares. Also I've seen some curled up ends, wassup wif dat?
mwilliamshs is offline   Reply With Quote
Old 07-04-2013, 03:06 PM   #16510
Thanantos
Ride hard.
Thanantos's Avatar
Oddometer: 3,690
I'm back! w00t! So excited to have a DR again. Here's the 99 I picked up today:
2013 V-Strom
Thanantos is offline   Reply With Quote
Old 07-04-2013, 03:28 PM   #16511
Thanantos
Ride hard.
Thanantos's Avatar
Oddometer: 3,690
My new to me 99 also has a broken brake lever. What say you collective?
2013 V-Strom
Old 07-04-2013, 04:22 PM   #16512
parttime rider
in the woods
parttime rider's Avatar
Oddometer: 41
gas tank
anybody looking for a stock tank? give me a pm its off a 98se.
ain't got no gas in it
parttime rider is offline   Reply With Quote
Old 07-04-2013, 06:06 PM   #16513
Friedom
Oddometer: 740
Will that fit a 90 dirt model? I'm still learning my DRs.
So, I'm all about it!
Old 07-04-2013, 07:04 PM   #16514
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 419
Nice bike,congrats! Enjoy it!
2011 UPAT
rubberband is offline   Reply With Quote
Old 07-04-2013, 07:29 PM   #16515
mwilliamshs
Oddometer: 233
gas tank
Friedom, read the last 2 pages. Excellent lesson in gas tank compatibility, including pics. I sent a pm about the tank btw. Couple hours ago.
Times are GMT -7.   It's 04:49 PM.
