Old 11-10-2013, 05:49 AM   #19261
simbaboy
Lansing MBS
simbaboy's Avatar
Oddometer: 1,060
Originally Posted by Gezerbike View Post
I ran across this on Craigslist up in western Wisconsin on Wednesday of this week, and brought it home last night at 10:00 after 10 hours of driving. A 2 owner 1997 with 6,100 miles. Never seen much, if any, offroad. New tires too boot ! I spent 3 hours this morning going over it and doing what cleaning was necessary. Reading thru the owners manual, it appears that the suspension was still set at the factory settings ! Yep, got all the manuals and original delivery inspection paperwork with it, and get this,it looks as if the tool kit had never been opened. It's sitting out in the geerage now making friends with my 1200 GS Rallye Edition. Life is good........
and its' new bud
Very Nice. I recently got a 97 350SE also and love it. I added a Acerbis, Spitfire windshield, Kenda 270 tires, etc. You will love it. Your bike looks super clean. Mine needed a lot of work but it did run when I bought it.
Good Luck and I also like your other no name bike!
Simba
simbaboy is online now   Reply With Quote
Old 11-10-2013, 06:48 AM   #19262
thump!
thump!'s Avatar
Oddometer: 1,564
Originally Posted by Greg Bender View Post
AFAIK, all of the dirt models have that little voltage regulator mounted under the seat, on top of the air box.
Regards,
Gregory Bender
Yes. And to answer the op's question, it will run fine without it. No lights of course.
thump! is offline   Reply With Quote
Old 11-10-2013, 07:46 AM   #19263
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
and its' new bud
Sounds like a great find. Have fun with it.
Sent from my SPH-L710 using Tapatalk
2000 KTM 200EXC
redleger is offline   Reply With Quote
Old 11-10-2013, 08:39 AM   #19264
psmcd
Oddometer: 1,000
Screaming deal, thanks!
[QUOTE=dyeinbreed;22746606]
If anyone is on the ropes about adding a hardcase, I bought this one
http://www.mcmelectronics.com/produc...n=ConfirmEmail
currently they are having a $5 ground shipping promo, and if you use the coupon code AFC909 you get an additional 15% off. So this case ends up being $26.24 shipped to your door.
psmcd is offline   Reply With Quote
Old 11-10-2013, 09:26 AM   #19265
AleksanderTheGreat
AleksanderTheGreat's Avatar
Oddometer: 501
^ yep. Even if you don't want to use it on the bike, I'm sure for $26, you'll find something to put in that case!
AleksanderTheGreat is offline   Reply With Quote
Old 11-10-2013, 09:41 AM   #19266
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,319
It was $28.08 with tax you bastard. What a ripoff! Looking forward to getting it. Did you do any special mounting technique to help retain the waterproofness?
*WTB: '90 DR350S Stock CV carb (bst33) PM if you have one*
'90 DR350S
How to misuse a '90 DR350S
Photos
Anonawesome is offline   Reply With Quote
Old 11-10-2013, 10:38 AM   #19267
Anonawesome
Scenic Rider
Oddometer: 1,319
Just realized it'll be a perfect spot for a rotopax.
'90 DR350S
Photos
Old 11-10-2013, 11:00 AM   #19268
AleksanderTheGreat
Oddometer: 501
Nothing special, just mounted it using 4 stainless allen bolts. You could always just slap some sealant under the washers before you tighten it down from the inside. I don't do any crazy river crossing or anything like that, so if theres water up to the bottom of the case, I have bigger things to worry about!
Yep, it's on my list as well. Even the 2 gallon should sit easily on top of the case. Though I'll probably go with a 1 gallon eventually.
Old 11-10-2013, 11:22 AM   #19269
simbaboy
Lansing MBS
simbaboy's Avatar
Oddometer: 1,060
You have to enter the CODE---they don't make it easy to see it. But just before you press the 'make payment' button you will see where they want you to press to enter the code. I just got me one too---it was $22.90 delivered.
Simba
Old 11-10-2013, 01:02 PM   #19270
AleksanderTheGreat
Oddometer: 501
Here are a few more photos, since I was in the garage changing the oil I figured I'd snap a few more pictures so you can gauge the size of the case on the DR.
I mounted it using 1/4" stainless button head allen screws with some blue loctite and nylon insert nuts with washers., from the bottom up -- nuts are inside the case --
I would've liked to have a bolt on each corner but I just used the pre drilled holes on my rack that were already there, hence the 2 spaced out and 2 together bolts, but it feels sturdy enough.
Old 11-10-2013, 01:31 PM   #19271
veriest1
Grand NOOBlet
veriest1's Avatar
Oddometer: 2,625
With that rack you could have probably used U-bolts and spaced things out a bit more. For additional weather proofing just add rubber washers under the fender washers.
I may have a look around their site and see if I can find something smaller.
Sent from my SAMSUNG-SGH-I727 using Tapatalk
veriest1 is offline   Reply With Quote
Old 11-10-2013, 01:38 PM   #19272
AleksanderTheGreat
Oddometer: 501
I couldv'e just drilled 2 holes since there is plenty of material, but once I bolted it up, it's very sturdy, but if I ever feel like it isn't, I'll just drill 2 more holes and add 2 more bolts.
I was going to add some neoprene washers, but I didn't really see the need for the type of riding I do. Like the holes, it will be no problem adding some later.
Old 11-10-2013, 01:38 PM   #19273
Baja Ho
Baja Ho's Avatar
Location: Central Coast, CA. USA & Cabo San Lucas, Baja Sur
Oddometer: 790
dyeinbreed
What model of DG exhaust pipe is that? And is it loud or quite?
Baja Ho is offline   Reply With Quote
Old 11-10-2013, 02:32 PM   #19274
AleksanderTheGreat
Oddometer: 501
Originally Posted by Baja Ho View Post
dyeinbreed
It's the 'O' series, which is the oval version. It was incredibly loud when I first got it to the point of taking it off after 2 days because I couldn't take the highway commute with it. I then added some baffles and it's pretty much just a little louder than stock with a nice rumble to it.
I'm rendering a video right now with a quick clip of the bike at different rpms, I'll post it up when it's done.
Quick video:
http://www.youtube.com/watch?v=B5RHDg5yFcA
The slight rattling you hear when I rev is because one of the baffles I put in came a little loose since it was the only one that I didn't rivet. One of these day's I'll go in and fix it.
AleksanderTheGreat screwed with this post 11-10-2013 at 02:42 PM
Old 11-10-2013, 02:47 PM   #19275
skelethon
skelethon's Avatar
Oddometer: 205
Went for a little ride today. Gotta love Florida weather.
Uploaded with ImageShack.com
skelethon is offline   Reply With Quote
Times are GMT -7.   It's 06:35 PM.
