Old 12-16-2013, 02:07 PM   #19801
Bodysnatcher
Oddometer: 2
DR 350 Electric start/kick start procedure
Hi newby here based in Scotland (UK for the moment)
just bought a 1991 DR350 kick start only. Just noticed it has a place for a starter motor but none of the electrics and none of the gears going from crank to starter. It has the auto decompressor mechanism.
My question is what is the starting procedure for kick starting the cold engine when it has an auto decompressor its is a complete bar steward to start but once warmed up runs fine and starts fine, it has the non pumper carb and non of the electrics for a starter motor.
Hoping some of you DR gurus can help. Thanks Alastair
Bodysnatcher is offline   Reply With Quote
Old 12-16-2013, 02:37 PM   #19802
SloMo228
World Class Cheapass
Oddometer: 1,729
Originally Posted by LoopGaroo View Post
So i was tuning my carb with some new jets and was having a hard time kicking it over because of the cold. I resorted to kicking it without the decomp release and guess what? Now I have no compression... There's no spot on the kick lever that's has resistance like it used to. The kicker isn't broken.
So besides cracking my case, is there anything else that I might have screwed up that's causing this. Is a cracked case a kiss of death for a $900 motorcycle like my DR3?
feeling glum.
I don't know for certain, but I wouldn't think a cracked case would leave you with no compression. There's a picture somewhere on this thread that shows the typical damage that results from kicking without the decomp lever on. It's the side of the case that cracks, around the kicker shaft, I think. Hopefully you have a different problem, maybe a failure of the decomp mechanism that is holding a valve open so you wouldn't see any compression? I'm not sure. Hopefully one of the DR350 gurus can offer some better advice.
If it is a cracked case, maybe you could take it to a welder and have it repaired for a reasonable cost, or sometimes you can find spare engines for a couple hundred bucks...
If it does end up being too cost-prohibitive to repair, I might be interested in buying the kickstart assembly off of you, though I hope for your sake and your DR's sake that it doesn't come to that.
--------------------------- Steve----------------------------------------
'93 GL1500 frankenbike basketcase in progress
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 12-16-2013, 03:28 PM   #19803
MrPulldown
MrPulldown's Avatar
Oddometer: 3,163
feeling glum.
Can you still bump start it? You might have cracked the case right where the kick start gear is located and messed with the ability of the KS to engage.
You can pull off the cover to the big nut used to turn over the engine when doing valve adjsutments. Turning the engine over there will allow you to feel if there is compression.
MrPulldown is offline   Reply With Quote
Old 12-16-2013, 03:31 PM   #19804
LoopGaroo
Oddometer: 192
The kicker feels exactly the same as it did beforehand, but without that "bump" in the stroke. Otherwise, it sounds and feels exactly the same. If I kick it, as is, I'll still get the headlight to light up for a split second, so I know it's engaging.
LoopGaroo is offline   Reply With Quote
Old 12-16-2013, 03:36 PM   #19805
jackanory
I am Jack's wasted life
jackanory's Avatar
Oddometer: 477
Originally Posted by cwc View Post
Has anyone tried an 80% nitrogen - 20% oxygen mix in these. It works in some other applications.
If I end up rebuilding my shock this winter I'll guinea pig it
jackanory is offline   Reply With Quote
Old 12-16-2013, 03:42 PM   #19806
jackanory
jackanory's Avatar
Oddometer: 477
what I would try is ignition off, gas and choke on, wide open throttle and kick it through 3 or 4 times. Then bump it just past TDC, ignition on, don't touch the throttle and give it a mighty boot.
Old 12-16-2013, 04:16 PM   #19807
MrPulldown
MrPulldown's Avatar
Oddometer: 3,163
Assumed you checked the little doodad that engages the decomp. Where the end of the cable attaches. Flipped back?
Old 12-16-2013, 04:59 PM   #19808
jackanory
jackanory's Avatar
Oddometer: 477
feeling glum.
Mine did the same thing last time I had it out. I was using the decomp lever though, but at one point it felt just like you describe - lost all compression and I didn't have the decomp engaged.
I have no idea what the culprit was - I didn't do anything special, just kicked it through a bunch until the compression came back then went about business as usual.
Old 12-16-2013, 05:00 PM   #19809
mas335
xendurist
Oddometer: 1,970
Here is the 98 DRse that I bought last friday. Eventually I will be parting with the Acerbis tank and Corbin seat.
Transalps
mas335 is offline   Reply With Quote
Old 12-16-2013, 05:13 PM   #19810
Soldier311
Oddometer: 1,845
Nice, mas! Do you intend to return it to stock configuration?
Soldier311 is offline   Reply With Quote
Old 12-16-2013, 05:27 PM   #19811
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 489
Wanna part with those forks also?? hehe
Sent from my SPH-L710 using Tapatalk
tonusmaximus is offline   Reply With Quote
Old 12-16-2013, 05:56 PM   #19812
Anonawesome
Scenic Rider
Anonawesome's Avatar
Oddometer: 1,277
The one time I didn't have compression, I had misaligned the cam with the chain. Just throwing out ideas.
*WTB: '90 DR350S Stock CV carb (bst33) PM if you have one*
'90 DR350S
How to misuse a '90 DR350S
Photos
Anonawesome is offline   Reply With Quote
Old 12-16-2013, 06:28 PM   #19813
vmcrcr
vmcrcr's Avatar
Oddometer: 301
Interested in the seat if it has not been spoken for yet. Tank also, but I think someone else yelled dibs on it already.
1993DR350S Southern NH
Thoughts? Suggestions? Jokes?
The internet is a nice place to visit, but I wouldn't want to live there.
vmcrcr is online now   Reply With Quote
Old 12-16-2013, 06:30 PM   #19814
toates89
Oddometer: 218
Why are you parting with the tank and seat?
toates89 is offline   Reply With Quote
Old 12-16-2013, 06:59 PM   #19815
DeutschMark
Full Tilt Boogie
DeutschMark's Avatar
Oddometer: 316
I love my big Acerbis tank. There is nothing like riding all day without having to stop for fuel.
89 BMW R100RS
97 Suzuki DR440
And away we go!
DeutschMark is offline   Reply With Quote
Times are GMT -7.   It's 12:51 AM.
