Old 03-13-2014, 07:19 PM   #21541
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,855
Originally Posted by Toadady View Post
why is it you can park a perfectly running bike, then two days later start it up and it only wants to idle, anything past a idle results in popping and some back firing .
so I pulled the carb and the inside was clean as a new one, it should be, it's only a 6month old carb. new plug too, no results.
so what's the PN# for the ignition pick up? I tried to look it up with no results,
Probably a speck in the pilot jet. Did you clean the tank before installing a new carb? Is there a fuel filter?
If ignition pickup was bad, it probably wouldn't run at all. You COULD have a bad coil or plug cap (worth swapping out the latter if you have one handy) but I think a carb issue is more likely.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 03-13-2014, 07:46 PM   #21542
Toadady
Push'n parts
Toadady's Avatar
Oddometer: 3,894
new carb, new tank with new blaster petcock with a filter, I pulled the main and pilot jet out and flushed , put in a new plug too,
tomorrow night I'm gonna set the valves. done it once before, but he's worn out a rear tire since then too.
Get to work, millions on welfare are depending on you
Toadady is offline   Reply With Quote
Old 03-13-2014, 07:53 PM   #21543
Jayala
Oddometer: 22
Thumb
Appreciate the help everyone. Gonna get to work and post some updates later. Hopefully some pics of a running dr350 by the end of the weekend
Jayala is offline   Reply With Quote
Old 03-13-2014, 08:18 PM   #21544
jacksonrpower
Oddometer: 7
Does anybody know if the dr350 dirt model's engine and carb will bolt right into an se frame?
jacksonrpower is offline   Reply With Quote
Old 03-13-2014, 08:25 PM   #21545
Toadady
Push'n parts
Toadady's Avatar
Oddometer: 3,894
carb is different, will need throttle cable change, spacer for the intake boot , as for the engine, might be a difference in stator plug for charging the battery that the dirt model doesn't have.'
Old 03-14-2014, 05:33 AM   #21546
thump!
thump!'s Avatar
Oddometer: 1,282
The '94 or newer dirt model motor will "bolt" in but there are carb differences as pointed out by Toadady and the dirt model stator will not charge the SE battery (single phase 70 watt versus 3 phase 150 watt - it more than just a different connector) nor will it operate the SE electrical components. Before '94 the stator and rotor were mechanically interchangeable between the models so it was possible to retrofit a dirt model engine with S model charging components. However, with the advent of electrical starting in 1994 the bottom end of the SE engine was changed - the crankshaft is longer to allow room for the starter gear/clutch. The SE stator MAY fit in the dirt model case but the rotor is different and definitely won't work on the dirt model crankshaft. And there is a difference in dirt model CDI and the one on the S/SE models. The S model has circuitry for the starter interlock, neutral light and provides a signal for the tachometer that is missing on the dirt model. Pre '94 models have a different CDI (single trigger rather than double).
thump! is offline   Reply With Quote
Old 03-14-2014, 08:40 AM   #21547
Archery21
Oddometer: 16
I incorrectly posted that Scotts no longer had a damper for my 97 Dr 350. Please disregard.
OTE=MrPulldown;23684135]I am sure you can mount a Scott Dampener on the DR350, they still list it on their web site. http://www.scottsonline.com/Stabiliz...d=&BI_ID=14211
They only sell the weld on version.
Seems like it will work fine. It is the $400 that is holding me back. For some reason they do not have the head tube clamp version, that all the rest of the modern bikes use.
A WER version might be easier and cheaper to mount.
The bolt on oil dip stick version is no longer sold. IMO it was a pretty bad design. DR350 tend to consume a bit of oil. It is common for the oil ring on the piston to get stuck. I know many have perfectly running DRs that do not drink a drop , but I check and fill regularly. Running an air cooled bike low on oil is its death song. A machined "bolt" replaces the dip stick and the tower clamps to the bolt.
[/QUOTE]
Archery21 screwed with this post 03-14-2014 at 04:49 PM
Archery21 is offline   Reply With Quote
Old 03-14-2014, 10:10 AM   #21548
DR350seKING
Oddometer: 68
Hid
I got my hid kit in yesterday and worked on it last night and this is what the DR looks like now. i got the 35w 6000k bulb and it is so much brighter i cant wait to ride to work at 4am
DR350seKING is offline   Reply With Quote
Old 03-14-2014, 10:12 AM   #21549
GSAragazzi
GSAragazzi's Avatar
Oddometer: 1,425
Looks dark
"The Only Easy Day Was Yesterday"
GSAragazzi is online now   Reply With Quote
Old 03-14-2014, 10:12 AM   #21550
LoopGaroo
Oddometer: 192
Can't see the pic! It looks like its a yahoo-mail link.
LoopGaroo is offline   Reply With Quote
Old 03-14-2014, 10:18 AM   #21551
DR350seKING
Oddometer: 68
hows that
http://s947.photobucket.com/user/pd0...tml?sort=3&o=0
Old 03-14-2014, 10:20 AM   #21552
LoopGaroo
Oddometer: 192
I was hoping to see it installed on a Dirt version DR....
Old 03-14-2014, 10:21 AM   #21553
DR350seKING
Oddometer: 68
99 electric start with kicker as backup
Old 03-14-2014, 10:22 AM   #21554
polarice
Former Ice Pirate
polarice's Avatar
Oddometer: 221
or THIS
PolarIce=http://en.wikipedia.org/wiki/USCGC_P..._%28WAGB-11%29
Served Onboard 94-97
2008 R1200GS 1995 DR250 2009 CRF230M 1986 BW80 1972 Suzuki RV90 -SOLD
polarice is offline   Reply With Quote
Old 03-14-2014, 10:44 AM   #21555
thump!
thump!'s Avatar
Oddometer: 1,282
I would think aftermarket LED lights expect 12-15 volts DC. There is no DC on a dirt model as there is no rectifier. The dirt model lights run on AC.
Times are GMT -7.   It's 01:00 AM.
