06-29-2009, 10:24 AM
#2266 | |
Lost Boy
Oddometer: 2,961
Geauga Power Sports By riders, for riders. Ohio Motorized Trails Association Are you a member? OMTA on Facebook Baja info thread. |
06-29-2009, 02:28 PM
#2267 | |
Nobody Home
I ran my "drain" leg right down the frame and terminated it just behind the rear brake master cylinder. Use zip ties to hold it in place (but don't crush the tubing). Take extra care near the exhaust pipe so it doesn't melt.
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
06-29-2009, 04:25 PM
#2268 | |
Less talk, More ride
Oddometer: 850
-Ride Safe- RandyM
06-29-2009, 04:43 PM
#2269 |
Oddometer: 350
More starting problems
I've got a problem with my bike that just popped up today. Riding home this afternoon I had to hit the reserve and then it didn't want to start. I thought since I ran the carb dry it would take some time to get full flow. I needed to run an errand about an hour after I got home and it was hard to start again?!. While I was out I went to the gas station and tanked up and it still didn't want to start.
Typically this bike starts on the first push of the button no throttle required but now I have to crack the throttle, then it will start. It's spinning fine so it's not the battery. I have already replaced the petcock with the raptor piece. I added seafoam to the last tank of fuel, in a pretty heavy mix to clean the carb. I still haven't taken the carb apart because I don't know what I'm doing in that arena. The problem sounds similar to muddyrabbit's issue but I haven't dropped the bike....yet. Any ideas about a fix? thanks, Jamie ps my wife and kids say I smell like exhaust when I get off the bike. Too rich? There is a little blackness on the fender near the pipe. |
06-29-2009, 08:18 PM
#2270 | |
Oddometer: 850
-Ride Safe- RandyM
06-29-2009, 08:49 PM
#2271 | |
Oddometer: 350
Jamie |
06-30-2009, 06:57 AM
#2272 | |
Turn it up to eleven
Oddometer: 4,507
What's left? 2 front brake levers, rear fender, front and rear suspension, front and rear calipers/lines/master cylinders, frame, engine components, 14T sprocket with 1500 miles, o-ring chain with 1500 miles and 2 master links (don't ask) and the seat. |
06-30-2009, 08:48 AM
#2273 |
Lost Boy
Oddometer: 2,961
What about the tank?
06-30-2009, 09:27 AM
#2274 | |
Oddometer: 4,507
06-30-2009, 07:56 PM
#2275 |
Did you see that wheelie?
Oddometer: 942
Well, I got a big box of joy from rocky mountain today! I mounted a set of pro taper bars after work only to find that I needed to get smaller inserts for my hand guards due the the wall thickness of the new bars.the inserts won't be here till thursday, so tomorrow I'm mounting a new dunlop 606 on the rear and putting new whoa gears on(brake pads). I also removed the factory decals from the side panels.I'll post picks when its all together again.
07-01-2009, 11:12 AM
#2276 |
Oddometer: 1,072
Rocker arm damage
If you have valve noise that won't go away with adjustment, check your rocker arms!
I posted a question a while back in this thread about some top end noise in my motor, must have been about 50 pages ago. Anyway, the general concensus was "don't worry about it", so I kept riding it for a while, but it kept bothering me so I pulled off the valve cover the other day, and found this: ![]() Anybody else here had this problem? The cam lobe wore a deep gouge into the exhaust side rocker arm. No wonder it sounded like a loud valve tap. It's worth noting that I've adjusted and re-checked the valves several times, and they were all within spec. There is no way I could tell the rocker arm was bad without pulling off the valve cover (which was pretty easy to do btw.) For some reason, the intake rocker arm has an oil hole that squirts oil on the cam lobe; the exhaust side doesn't. Evidently the exhaust side is just splash lubed; which wasn't good enough for this particular rocker arm. The cam lobe has some streaking, but surprisingly that's about it. I may just touch up the surface with some 600 grit sandpaper. The "right" thing to do is probably to replace the cam, but for $130 for the stock cam, I probably won't. Are there any performance cams still available for these motors, and are they any good? |
07-01-2009, 11:32 AM
#2277 | |
Rocket Surgeon
Oddometer: 1,519
07-01-2009, 11:35 AM
#2278 | |
Oddometer: 4,507
07-01-2009, 11:48 AM
#2279 |
Rocket Surgeon
Oddometer: 1,519
Got your reply Z@ch, I think I'll pass on the seat.
Sorry to hear of your engine failure... the DR's really are great bikes. Thanks very much for the quick reply |
07-01-2009, 11:50 AM
#2280 |
f.k.a. j0hn0tt0
Does anyone know if the Maier rear fender that Keintech sells will work fine with the rear subframe? I don't mind if the subframe is sticking out or anything, just as long as everything bolts up.
Also, has anyone ever bought the DR350 rack from Precision Motorcycle Racks (here)? If so, I have an installation question: The rack has 3 mounting points. There are 2 points that share mounts with the rear grab rail, which makes perfect sense. Then, there's another mount underneath the rack that doesn't line up with anything. Do I just drill a hole through the fender and mount it to the plastic? That doesn't seem very secure or sturdy to me...? |
