07-03-2009, 04:49 PM
#2296 |
Did you see that wheelie?
Oddometer: 948
A few pics of my DR on the ride today
![]() ![]() One of the bridge crossings....
07-03-2009, 04:57 PM
#2297 |
Oddometer: 948
I put the Pro Taper bars on, the dunlop D606, and a 13 tooth front sprocket and tried it out today. That tire is awesome to say the least! And I really appreciate the 13 tooth sprocket in the tight stuff. I did 110 miles today, 70 of which was tight rocky terrain. I had a blast!
07-05-2009, 08:28 PM
#2298 | |
Hookers, my lad.
Oddometer: 6,223
The Capacitor, not so much.
"I'm half afraid Skippii's bike might actually be a giant hamster ball that he somehow powers around. With ape hangers." -GailCallsMeKarl |
07-06-2009, 01:13 PM
#2299 |
Oddometer: 1
94 DR350S and am having intermittent electrical problems
I recently bought a 94 DR350S and am having intermittent electrical problems that have left me stranded in the boonies 2 times. I’m not sure what the previous owner has done to the bike but here’s what is happening and what I’ve been able to determine so far. Problem #1 the bike would cut out and die while riding, seemed like the ignition. Solution: I checked the coil and removed the kick stand safety switch and crimped the wires together at the connector. Problem seemed to be solved. Problem #2 when I start the bike in neutral and shift into gear with clutch still engaged it dies. Not always but most of the time. I suspect that the kick stand / ignition interlock relay is bad or a bad connection. Also worth noting the clutch switch does not work, it is stuck in the closed position so the bike will start OK. I’ve looked at the wring diagrams in my service manual and don’t see how bypassing the kick stand switch should cause this problem. I’m thinking that the relay circuit should be removed but am concerned that doing so will cause problems to another component. I really need some advice from an experienced DR350 owner as how to permanently and reliably fix this issue.
07-06-2009, 01:51 PM
#2300 |
Lost Boy
Oddometer: 2,972
Might want to change the font color. Some folks on here are to old to try reading black on grey.
Geauga Power Sports By riders, for riders. Ohio Motorized Trails Association Are you a member? OMTA on Facebook Baja info thread. |
07-06-2009, 02:33 PM
#2301 | |
1.5 Finger Discount
Oddometer: 20,079
Yoink.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
07-07-2009, 09:37 PM
#2302 |
Do It!
Its not the prettiest thing to look at, but it really helps on the freeway at 75mph. It came off my buddies KLR. He just upgraded his windscreen, so i took this one and cut it down a bit.
![]() ![]() i made the braces from a stabilizer bar. cut it in half, drilled a couple holes, and tapped some threads.
07-08-2009, 10:49 AM
#2303 |
Oddometer: 41
WTB tank rear rack
anyone have either a lg tank and /or a rear rack to work on my 98 SUZ DRT-350?
Also interested in current mfr's of rear racks Love my Giant Loop Bag, but want add'l storage behind it. codger
Codger -- The less you know about motorcycles, the more you'll want a Harley. Lee Bruns |
07-08-2009, 11:15 AM
#2304 | |
Nobody Home
As for larger tanks, you can go with IMS, Clarke or Acerbis depending on your budget. Acerbis makes a 4.25 gallon tank with dual fuel valves. Clarke and IMS make slightly smaller ones @ 3.5 gallons but only have one fuel valve. So, there's always some fuel "trapped" on the right side of the tank. I added another fuel valve to the right side of my IMS and solved that problem. It sounds like you have a dirt (not street legal) version DR. If so, the bigger tanks will fit without issue. I have a '99 SE and am still using the CV carb. The bigger tanks are made to work with the 'dirt version' DR (with the 'pumper' carb - TM33SS) . So, you have to do a little work to get the bigger tank to fit around the CV cables. It's not difficult but just involves properly "dressing" all of the cables and wiring. HTH, Dave.
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
07-08-2009, 02:24 PM
#2305 | |
Gearing down for Hell
Oddometer: 3,753
2007 KLR650 1999 DR350SEX 2003 CRF230F 1994 Beta Techno 250 Striving to do better. |
07-08-2009, 07:29 PM
#2306 |
Wageslave
Oddometer: 197
Yeah, my Acerbis tank fits my 94 SE just fine.
02 Super Sherpa |
07-09-2009, 06:18 AM
#2307 |
Oddometer: 238
thought on no ignition key and spark
my 92DR350 has no key and someone modified the wires to kind of work. The key switch and kill button connect the black/yellow wire to black/white wire to stop the spark. with the key to run.. it opens the black/yellow and black /white wires, and connects the wires for the lights, on a kick start DR350s. so a kickstart DR well run with no key switch, you just won't have any lights. my Dr350s had 3150 miles of dirt riding so i removed and unplugged all the connections, then cleaned and tightened the bullet connectors.. they were real loose and full of dirt. spark went from dull orange to bright blue. i removed the kickstand switch and connected the wires under the tank. runs fine now. going to replace the key switch next. clean and check all your wires. wd40 works pretty good for me. good luck
07-09-2009, 07:02 AM
#2308 |
Oddometer: 201
electrical
I have a 99 DR350 off-road model and i want to make it street-legal. need blinkers, brakelight, high/low beam, horn, basicallly everything. im finding it hard to get info on how to wire all this stuff in and if i need a new regulator
07-09-2009, 07:38 AM
#2309 |
92 dr 350s
Oddometer: 177
92 Dr350 Pinging
JUST INSTALLED JESSE'S CARB REBUILD ALL WENT SMOOTH. I HAVE A 140 MAIN W/AIR BOX MOD
THE EXTENDED SCREW IS ABOUT 1 AND 3/4 TURNS OUT. THE PROBLEM I AM HAVING IS AFTER THE BIKE GETS HOT IT START TO PING UNDER 3/4 THROTTLE I CAN TURN OUT ANOTHER 1/2 TURN AND IT STOPS BUT THEN THE BIKE IS TO RICH AND DOES NOT RUN AS WELL IN THE LOWER RPM'S AND IS HARD TO START. DO I NEED A DIFFENT JET? OR AM I MISSING SOMETHING. ALSO I SHOULD MENTION I DID THE CARB KIT BECAUSE IT WASN'T RUNNING WELL AFTER PULLING THE CARB OFF FOUND THAT THE DIAPHRAM IN THE OLD SHOULD HAVE REPLACED PETc*** DESOLVED PUTTING TONS OF CRAP INTO THE CARB. I REPLACED W/RAPTOR ONE WORKS GREAT. |
07-09-2009, 08:29 AM
#2310 | |
Oddometer: 9,339
ping and stall
You could use higher octane fuel. If you're using regular, try mid-grade. Or shim up your needle.
