Old 10-07-2009, 09:14 PM   #3046
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Originally Posted by slartidbartfast
I've got a dual-cable set up for my CV carb. Will I need a new throttle for the pumper or just a cable?
You can not use the CV cables with a pumper carb. The exposed portion of the inner cable is not long enough.
I'd go with the single cable setup from Kientech ($40) as mudmantra and Jcalis suggested.
Plus, If you're one that likes to carry a spare throttle cable as I do.... it's much more convenient.
Bob Onit is offline   Reply With Quote
Old 10-08-2009, 04:02 AM   #3047
TinyTim
Noob
TinyTim's Avatar
Oddometer: 58
Clutch sticking
Hi Guys,
Recently got another DR350SE(1996). I had removed and oiled the sticking clutch cable. Upon re-assembly I cannot get the gears to disengage completely. The bike dies as soon as I put it in gear with the clutch lever fully in. With engine off and clutch lever in I can feel resistance when I push the bike. It does not roll freely. I have tried adjusting the cable at the lever end as well as at the clutch arm to no avail. Other than sticking the clutch was fine before. Help please.
TinyTim is offline   Reply With Quote
Old 10-08-2009, 07:40 AM   #3048
mudmantra
Oddometer: 348
Originally Posted by duxrneet
Hey, what are some good brake pads for these bikes? I think mine still has the original ones. I'm not looking for something that's going to kill the rotor, either. Thanks!
Yeah there are so many pads out there, it's hard to decide. Suzuki would be good, but having said that. I'm going to use braking pads, semi metalic. I get a good price on them and they look just like the stock stuff.
mudmantra is offline   Reply With Quote
Old 10-08-2009, 07:49 AM   #3049
RENCRN8
RENCRN8's Avatar
Oddometer: 251
I am happy with EBC FA135Rks on my wifes bike. I run EBC on all my bikes and have had good luck with them.
RENCRN8 is offline   Reply With Quote
Old 10-08-2009, 09:48 AM   #3050
FlyingWman
FlyingWman's Avatar
Oddometer: 256
Originally Posted by TinyTim
Hi Guys,
make sure that wen you put the clutch cover back on the splines on the clutch shaft(located inside the cover to the cover) and the other splined rod coming out of the clutch line up. i cant think if the exact names of the part right now haha
___________________
2000 XR650R
1982 GS750TZ
FlyingWman is offline   Reply With Quote
Old 10-08-2009, 03:09 PM   #3051
FlyingWman
FlyingWman's Avatar
Oddometer: 256
REsistorrrr
Question....
I am going to to take the wires from the headlight and route them thru a High/low/horn switch. the horn will be conected to the killswitch function button on the switch, i believe the the continuity thru a kill switch will make it so the horn is on only when i push it, and not all of the time. The back is going to be a hydraulic brake switch running into a 3 wire socket and a dual filament bulb, in replace of the old 2 wire single element bulb.
My most important ever possibly is Do i need a resistor so all of these bulbs do not blow up when rpms go waaaaaayyyyy up? and were would one, or many, wire up to
___________________
2000 XR650R
1982 GS750TZ
Old 10-08-2009, 04:21 PM   #3052
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 18,140
do you have a dirt 350?
or an electric starter version?
there should be a regulator under your seat, screwed to the airbox, it keeps the voltage from burning the bulbs.
Originally Posted by FlyingWman
Question....
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 10-08-2009, 08:04 PM   #3053
FlyingWman
FlyingWman's Avatar
Oddometer: 256
I have a 99 Dirt model. and dont believe their is a resistor on the dirt model, but i dont know
___________________
2000 XR650R
1982 GS750TZ
Old 10-08-2009, 08:09 PM   #3054
nevada72
Klaatu barada nikto
nevada72's Avatar
Oddometer: 571
Well I found the leak
Hard to see in the pic but oil is leaking out of the frame. I removed the tank, cleaned everything up - no leak. I got it running with the gas tank removed to see if it only leaked under pressure. The oil started to flow through the crack where the engine mount is welded to the frame. It basically drips quite a bit of oil on the top of the motor which runs down and makes a mess, not to mention a smoke show.
I searched the topic on Maximum and found another guy who had the same problem. Now to find a fix. I've heard of people sealing the resevoir like a gas tank, but I believe one would have to take the bike apart in order to do that the right way (clean, flush, seal, empty, etc.). Welding or brazing is an option and it could be done in place. Then there's good ole JB weld, but the other guy said it didn't last on his. Maybe he didn't clean it up well enough?
Any ideas would be welcome.
2003 DR650
1976 Triumph Bonneville
2014 Harley Davidson Street Glide Special
1964 Honda Dream
1967 Honda CA Touring
nevada72 is offline   Reply With Quote
Old 10-08-2009, 08:23 PM   #3055
Phreaky Phil
Oddometer: 1,922
Where does this fit?
I recently purchased a X model 350 that is steet legal and has the big ugly headlight. Previous ownerat some stage has ridden bike as trailbike without headlight so wiring was all tapped up. I cant figure out where the bit that i'm holding in my hand is surposed to mount. No matter where I try it it seems to be in the way.
Phreaky Phil is offline   Reply With Quote
Old 10-09-2009, 09:35 AM   #3056
mouthfulloflake
Not afraid
Oddometer: 18,140
there wont be a resistor on it.
there should be an AC voltage regulator under the seat ( thats where it is on my 1991)
it takes the High voltage AC from the stator, and keeps it under 13/14 volts so it wont burn the bulbs up.
you still likely have AC though, NOT DC, the street versions had a regulator AND rectifier to change the AC into DC to charge the battery.
Old 10-09-2009, 10:15 AM   #3057
FlyingWman
FlyingWman's Avatar
Oddometer: 256
So the bulbs will not blow up with my current plan??
___________________
2000 XR650R
1982 GS750TZ
Old 10-09-2009, 10:31 AM   #3058
mouthfulloflake
Not afraid
Oddometer: 18,140
do they blow up now?
Old 10-10-2009, 10:24 AM   #3059
FlyingWman
FlyingWman's Avatar
Oddometer: 256
No
___________________
2000 XR650R
1982 GS750TZ
Old 10-10-2009, 12:40 PM   #3060
duxrneet
duxrneet's Avatar
Oddometer: 671
If your bike has a regulator that works, you won't be frying bulbs! Now GPS's are a different matter. Sensitive DC stuff will need a rectifier and capacitor to smooth out the voltage and make all the juice go one way.
duxrneet is offline   Reply With Quote
Times are GMT -7.   It's 01:39 AM.
