Old 03-08-2010, 01:48 PM   #4246
J$Ridin'Dirty
Oddometer: 10
Hopefully Someone Can Help Me!
When I purchased my 96 dr 350 se the previous owner had it sitting in his garage for awhile. When I test rode it, it hesitated quite a bit on the throttle. I started it the other day and rode around a little and there was no hesitation Then yesterday I started it again and it was hesitating again! damnit! My guess is that either I need to clean the carb or maybe it needs to be rejetted. It does have a newer acerbis gastank (thinking maybe he didnt clean it and maybe theres junk in one of the petcocks) , an aftermarket exhaust (not sure what kind, it doesn't say) and Im not sure if its stock or not but has a mikuni carb, if any of this info helps. Any info would be greatly appreciated-Justin
J$Ridin'Dirty is offline   Reply With Quote
Old 03-08-2010, 01:50 PM   #4247
J$Ridin'Dirty
Oddometer: 10
When I purchased my 96 dr 350se in December se the previous owner had it sitting in his garage for awhile. When I test rode it, it hesitated quite a bit on the throttle. I started it the other day and rode around a little and there was no hesitation Then yesterday I started it again and it was hesitating again! damnit! My guess is that either I need to clean the carb or maybe it needs to be rejetted. It does have a newer acerbis gastank (thinking maybe he didnt clean it and maybe theres junk in one of the petcocks) , an aftermarket exhaust (not sure what kind, it doesn't say) and Im not sure if its stock or not but has a mikuni carb, if any of this info helps. Any info would be greatly appreciated-Justin
Old 03-08-2010, 02:33 PM   #4248
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 13,442
You can't go wrong with cleaning the carbs after it's sat for a long time.
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
EvilClown is offline   Reply With Quote
Old 03-08-2010, 03:07 PM   #4249
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,074
I'm very slowly figuring this out.
Hopefully this most recent teardown will mean I won't have to do it again for a while.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 03-08-2010, 04:56 PM   #4250
nevada72
Clatto Verata Nicto
nevada72's Avatar
Oddometer: 496
Got my 1st chance to put some serious miles on the Dr since I bought it last fall. Fellow ADV'er DNTOUCH and I trailered our bikes down to Arkansas and took advantage of the 65 degree weather and amazing terrain. Two days of morning to night riding.
The bike performed flawlessly and confirmed that it was a great choice. It also drew lots of praise from others on the group ride, riding far more powerful bikes. It really kept up well. No one was waiting on the DR!
Cheryl and I tour the West, summer of 2011
http://advrider.com/forums/showthread.php?t=718387
nevada72 is offline   Reply With Quote
Old 03-08-2010, 05:45 PM   #4251
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 1,753
Originally Posted by original mcguiver
It is not unusual for an aluminum bike rim to crack from the spot where it was welded from the factory
Just pull the rear wheel-remove tire & rim band-take it to a "REAL" welding shop and let them weld the crack. Probably 20$ and yes I have done this more than once, without a problem (thousands of miles of use)... Ron
I figured I couldn't make it any worse:
"turn it on man, turn it on-whatever, whoever you are-TURN THE FAWKER ON!" -Herbert Foster Gunnison
01 Girlie
09 TE450
bobnoxious67 screwed with this post 03-08-2010 at 05:50 PM
bobnoxious67 is offline   Reply With Quote
Old 03-08-2010, 06:16 PM   #4252
EvilClown
EvilClown's Avatar
Oddometer: 13,442
Originally Posted by Liza
Honestly, I have an in-house REAL welder (the aforementioned "my guy Bob"). If he's not comfortable with welding it for me and letting me run it, then I'm not going to push the issue, and am going to replace it instead.
If you don't re-use it please let me know if it's for sale.
Old 03-08-2010, 08:06 PM   #4253
RandyM
Less talk, More ride
RandyM's Avatar
Oddometer: 850
Originally Posted by tominboise
So the previous owner of my 95 DR350SE managed to strip the internal teeth out of the plug that goes in the magneto cover, that one removes to do valve adjustment. (the one used to rotate the crankshaft, not the viewing port.) So, I have ordered a new plug and o ring, and a gasket for the magneto cover. I plan to drain the engine oil, pull the magneto cover off, drill a couple of self tapping #10 hex head screws into opposite sides of the plug, put a large prybar (relatively speaking) between the two hex heads and removing the plug. Any tricks I should be aware of in removing and replacing the magneto cover? I was planning on installing the cover with the gasket dry (as opposed to putting perma tex or similar on it). Will I have any leaks?
Tom
I have had the same problem on my 91 Dr250 and my 99 DR350. I suspect that the problem is that owners or mechanics over-tighten them. There is no torque spec in the dr350 manual for the plug. My Vstrom has a similar sized plug and it supposed to be torqued to 7.0 Ft-LB. The plug uses an O-ring and does not need sealant.
My 99 DR350SE will hesitate until it warms up. Mine is stock with CV carb, stock jets, no air box or exhaust mods. If it goes away after warm-up then it is probably normal. May be worse if temperature is lower. May also happen if you left the choke on after warm up.
-Ride Safe-
RandyM
RandyM is offline   Reply With Quote
Old 03-09-2010, 08:00 AM   #4254
bobnoxious67
Baby steps...
Oddometer: 1,753
See my post (I'm "her guy") :
01 Girlie
09 TE450
Old 03-09-2010, 08:19 AM   #4255
Mulekick
2.7 on Fu Man Chu
Mulekick's Avatar
Oddometer: 25,733
Welds are stronger than material ...some people like to waste their money...
I'd ride on that ...
Don't walk behind a Mule................
note to self~ LEARN LIVE LOVE
Mulekick is offline   Reply With Quote
Old 03-09-2010, 09:02 AM   #4256
EvilClown
EvilClown's Avatar
Oddometer: 13,442
Looks good! I'll take it!
As long as I'm here...is it a cush drive? Yes. I'm taking a poll.
Old 03-09-2010, 10:48 AM   #4257
bobnoxious67
Baby steps...
Oddometer: 1,753
Yup, cush drive ('94).
Seems good so far
01 Girlie
09 TE450
Old 03-09-2010, 12:13 PM   #4258
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,444
Not always true, particularly with rims. The filler material is supposed to be stronger than the base material. This is easy to accomplish with steel because the overwhelming majority of steel is mild steel and all types of new steel filler rod are stronger than mild steel. And it’s easy to tell if you’re welding stainless instead because you can see it’s stainless, and then you can get the right filler rod for it.
The biggest problem with welding aluminum is you can’t tell what kind of alu it is by looking at it or putting a magnet on it, or trying to grind it, all of which you can do with steel to help identify the alloy. In fact the only ways I know to identify alu is to find out from the product manufacturer or use a very expensive laser gun that welding shops rarely own. On top of these issues, there are many more alloys of alu than there are of steel. The most common is 3003, also common are 1100 and 6063, all of which are commonly welded with 4043 filler rod.
Bike rims are very specialized. The metal needs to be extruded, then bent, then welded. After going through these processes the rim still needs to remain extraordinarily tough. Due to these requirements, most rims are made of 7000 series alu but the manufacturers will not tell you the exact alloy because it’s “proprietary” (and they want you to buy a new rim when your old one breaks). 4043 filler rod is not as tough as 7000 series alloys, but it will join 7000 series. Due to its frequent use, most welding shops stock 4043 filler. So if you bring a rim to most small welding shops they’ll grab their 4043 filler rod and it will make a decent looking repair, but the weld will be weaker than the rim which will give it a very high chance of failure.
So if you are going to have your rim welded, try to find a place that has done rims and ask what filler they are using. Most 7000 series alloys should be welded with 5356, 5183, or 5556 filler. It’s unlikely you’ll be able to find the exact alloy your rim is made of so you won’t know the best filler to use, but at least if you use a 5000 series filler you’ll have a much better chance at a quality repair.
Thanks for reading my novel.
Pablo83 is offline   Reply With Quote
Old 03-09-2010, 01:26 PM   #4259
EvilClown
EvilClown's Avatar
Oddometer: 13,442
You're welcome,...Cliff.
Actually, very helpful information, Paul. Thanks for taking the time to post it.
Old 03-09-2010, 01:28 PM   #4260
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,086
Send a message via Skype™ to shearboy2004
Excellent Pablo even i could understand that !! Great writeup.
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 450 called BLING.
07 Sherco 510 called Holy Shit .
shearboy2004 is offline   Reply With Quote
Times are GMT -7.   It's 12:22 PM.
