Old 07-24-2010, 03:19 PM   #5296
jplum1556
Oddometer: 102
Originally Posted by BikePilot
Order one for a DRZ, it won't be listed for the DR350 as it won't quite clear the little case protector. A few minutes with a bench grinder fixes that though.
My 350SE case saver fit the 15T sprocket as that was stock. I relieved it a bit with a bench grinder to make room for a 16T sprocket.
My 250SE case saver didn't fit a 15T sprocket (I think the 250 came with a 14T stock). There are definitely different ones out there.
For chain length I always just order a standard length (120 usually) and cut to fit. I'm much too lazy to go and count out links:)
Ok, thanks . I figured I'd need to do something with the case saver since it looked pretty tight with the 15t.
jplum1556 is offline   Reply With Quote
Old 07-25-2010, 08:31 AM   #5297
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 414
Ok, I was digging through the previous owners notes and reciepts. And found the following. "Installed JX Needle and spring, opened up pilot jet with #78 drill bit and main jet 145 installed." Was this a common practice? The bike is running a bit rich, but nothing I'd go messing with at this time.
Also what kind of oil consuption is normal? After 350miles I needed to add about 400ml to bring it to mid level on the dipstick.
1997 SE with a Supertrapp IDS2 slip on, and 3X4 hole in the top of the airbox. Stock carb....Non pumper...boo
2011 UPAT
rubberband is offline   Reply With Quote
Old 07-25-2010, 09:54 AM   #5298
BikePilot
BikePilot's Avatar
Oddometer: 11,251
I don't get any measurable oil consumption on either DR. I'd guess that yours is on the high side unless those 350 miles were all very hard off road miles, in which case maybe its normal.
Some cheaper oils will evaporate at high temps I think. If you have no smoke or leaks you might try a quality syn oil if you aren't already using it and see what that does for you. I'd think that if you are burning that much oil you'd have some smoke. That is almost as much oil per mile as my 2-stroke uses
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 07-25-2010, 10:01 AM   #5299
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Also be sure that you are checking the oil using the procedure posted in the manual or you will get false readings as the DR is a dry sump system.
Bob Onit is offline   Reply With Quote
Old 07-25-2010, 10:31 AM   #5300
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 414
To be honest most of the riding was 5th & 6th gear, fairly higher speeds 50+. Just bombing around some local backroads. Even with that kind of riding I was getting 55mpg. I don't seems to be leaking anywhere, and I agree if I was burning it...it would look like I was riding a 2 smoke.
And yes I'm checking the oil per the procedure in the manual. As usual thanks for the replies.
2011 UPAT
Old 07-25-2010, 10:50 AM   #5301
D-Fuzz
D-Fuzz's Avatar
Oddometer: 479
Does anyone know if any parts from a DR650 will fit onto a DR350, namely the rear shock, seat and an IMS tank? I have a DR650 but would like to downsize to a DR350 and hopefully put my "fancy" parts on the 350.
Scott
D-Fuzz screwed with this post 07-25-2010 at 02:26 PM
D-Fuzz is offline   Reply With Quote
Old 07-25-2010, 11:58 AM   #5302
DisTech
DisTech's Avatar
Oddometer: 616
Originally Posted by D-Fuzz
Does anyone know if any parts from a DR^%) will fit onto a DR350, namely the rear shock, seat and an IMS tank? I have a DR650 but would like to downsize to a DR350 and hopefully put my "fancy" parts on the 350.
I know that the stock tank does not fit. The oil reservoir in the DR350 frame makes the mounts too wide. Since the IMS tank mounts the same as the stock tank I'm betting it doesn't fit either.
I don't know about the dimensions of one shock vs the other but the DR350 shock has a detached reservoir and the DR650 attached reservoir is right where mid tube runs. So if it does fit, you would probably have to rework the exhaust.
The seats are closer than I thought they would be. You could make it work, but it would be too much rigging for my taste.
DR650 top, DR350 bottom.
HOWEVER, the footpegs are interchangeable!
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 07-25-2010, 12:03 PM   #5303
MiteyF
MiteyF's Avatar
Oddometer: 1,995
I'm having a hell of a time finding a 41 tooth rear steel sprocket for the DR (93 S). Does anyone have a link?
MiteyF is offline   Reply With Quote
Old 07-25-2010, 12:10 PM   #5304
DisTech
DisTech's Avatar
Oddometer: 616
ProCycle sells chain & sprocket sets, but if you call them I bet they sell them separately.
Old 07-25-2010, 12:26 PM   #5305
MiteyF
MiteyF's Avatar
Oddometer: 1,995
But they don't list a 41 for the 93 DR S. I checked there first actually.
Old 07-25-2010, 01:47 PM   #5306
DisTech
DisTech's Avatar
Oddometer: 616
Sorry I didn't notice the distinction on the ProCycle site. How about cheapcycleparts.com?
Old 07-25-2010, 04:09 PM   #5307
superandy89
erutnevda
superandy89's Avatar
Oddometer: 16
Anyone ready to part with their DR350? (Mass)
I got shafted by a CL seller yesterday who withheld the fact that he didn't have the title for his DR350s. Since I thought I'd have a bike by now I'm scrambling a bit to find another bike, and I'm looking to a more reputable crowd.
Doesn't have to be in amazing shape, just titled and street legal.
I left my other bikes in WI for the rest of the year and I am anxious to get out of the city. I'm primarily looking for early 90's Jap dual-sports, so if you have something similar, please feel free to shoot me a PM.
bike w#ore
superandy89 is offline   Reply With Quote
Old 07-25-2010, 04:45 PM   #5308
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 414
www.bikefinds.com
will search ebay, CL, etc buyer beware....but it's where I found mine.
www.thumpertalk.com has a pretty good classified section as well
2011 UPAT
Old 07-25-2010, 10:29 PM   #5309
MiteyF
MiteyF's Avatar
Oddometer: 1,995
Perfect. Thanks, very much appreciated!
Old 07-26-2010, 05:11 AM   #5310
Greg Bender
Oddometer: 1,177
Rocky Mountain ATV has them:
http://www.rockymountainatvmc.com/
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Times are GMT -7.   It's 05:19 AM.
