Old 09-09-2010, 03:02 PM   #5746
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Originally Posted by MiteyF
No one can answer this for me?
Cush drive hubs (they have little rubber blocks in the hub) are different than the Dirt model, or the newer S model hubs (non crush drive) they require different sprockets.
What year are the spare wheels?
You can check any DR part number for cross reference here.
Just enter the the required information.
http://fiche.ronayers.com/Index.cfm/.../2/Make/Suzuki
Bob Onit is offline   Reply With Quote
Old 09-09-2010, 05:12 PM   #5747
DisTech
DisTech's Avatar
Oddometer: 599
OEM rear sprockets & hubs
I have a question maybe someone can help me with.
My 93 S is my daily commuter, and I've got dual sport tires on her. I also have an extra set of wheels with knobbies for when I do the dirty stuff. The rear wheel is off of a dirt model, and when I went to put it on, the sprocket from my stock S wheel did not fit. Just wondering if the bushings are the same from the S to the dirt model, or what I will have to change to use the dirt model wheel on my S besides the sprocket.
Any help would be great. Looking to do a bit of dirt riding before the season is over!
You can check any DR part number for cross reference here...
Bob, I thought the same thing you did. In fact I looked all this junk up:
  • 1990 L DR350, DR350S
  • 1991 M DR350, DR350S
  • 1992 N DR350, DR350S
  • 1993 P DR350, DR350S
  • 1994 R DR350, DR350SE
  • 1995 S DR350, DR350SE
  • 1996 T DR350, DR350SE
  • 1997 V DR350, DR350SE
  • 1998 W DR350, DR350SE
  • 1999 X DR350, DR350SE
1990-93 DR350 L/M/N/P
  • SPROCKET, REAR (NT:46) 64511-14D31
  • SPROCKET, REAR (NT:47) 64511-14D00
  • SPROCKET, REAR (NT:46) 64511-14D40
  • SPROCKET, REAR (NT:48) 64511-14D60
1994-99 DR350 R/S/T/V/W/X
  • SPROCKET, REAR (NT:43) 64511-14D70
  • SPROCKET, REAR (NT:44) 64511-14D80
  • SPROCKET, REAR (NT:45) 64511-14D90
  • SPROCKET, REAR (NT:43) 64511-08D40
  • SPROCKET, REAR (NT:44) 64511-08D50
1990-96 DR350 L/M/N/P/R/S/T
  • HUB, REAR WHEEL 64111-03D00
1997-99 DR350 V/W/X
  • HUB, REAR WHEEL 64111-14D10
1990-93 DR350S L/M/N/P
  • SPROCKET, REAR (NT:43) 64511-22D11
1994-95 DR350SE R/S
  • SPROCKET, REAR (NT:41) 64511-15D50
1996-99 DR350SE T/V/W/X
  • SPROCKET, REAR (NT:41) 64511-14E00
1990-93 DR350S L/M/N/P & 1994-95 DR350SE R/S
  • HUB, REAR WHEEL 64111-15D00
But now re-reading the question , I think Mitey just wants to know if there is anything besides the sprocket to do the wheel swap.
Mitey, I think it's a straight swap. Let us know.
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is online now   Reply With Quote
Old 09-09-2010, 05:13 PM   #5748
MiteyF
MiteyF's Avatar
Oddometer: 1,007
I don't know what year it is off of. I checked the fiche at Ron Ayers earlier and didn't really get anywhere, it looks like I'll just have to measure and make some bushings. I was just hoping there was an easier solution. I found out the sprockets were different when I tried to fit mine to this wheel. I knew the non S models were not a cush drive, but did not know how different they were. Should have done my research I suppose. I know they've been fitted to S models before, but can't find a detailed writeup on exactly how it was done and was hoping someone here knew.
Here's the wheel, don't know if it helps at all, but it's the pic provided from the ebay auction when I bought it.
MiteyF is online now   Reply With Quote
Old 09-09-2010, 06:40 PM   #5749
Ghostpilots
Oddometer: 91
If you put a 15 on the front you should have enough adjustment in your chain to use the 108 if you keep the 43 out back.
So another question; will it go the other way as well? Can I also purchase a 13T for trails and swap that in with no need to change the rear or chain?
EDIT: Would moving to 15/41 110 link like the 93 and up make an appreciable difference either? I really do not run a ton of trails on the 350, but seem to be doing a lot of highway miles and I'll give the old girl any break I can get
Ghostpilots screwed with this post 09-09-2010 at 06:56 PM
Ghostpilots is offline   Reply With Quote
Old 09-09-2010, 07:22 PM   #5750
SloSolo2
SloSolo2's Avatar
Oddometer: 350
Maybe you could trade that wheel with someone who has one from the year range you need via the flea market?
Jamie
SloSolo2 is offline   Reply With Quote
Old 09-09-2010, 07:39 PM   #5751
MiteyF
MiteyF's Avatar
Oddometer: 1,007
That's a possibility, but there's not much DR stuff in there that I've found... may post an ad though. Unfortunately it's an almost new rear tire I just had put on!
Old 09-09-2010, 09:37 PM   #5752
Rex Nemo
horizon calling
Rex Nemo's Avatar
Oddometer: 233
Hey y'all, apologies in advance for the novice questions...I'm still searching through this thread. I love my DR650 but want to get something smaller but still street-legal for surface streets and more challenging dirt.
I'm looking at a pair of DR350s tomorrow...a '93 with a supermoto setup and spare dirt wheels and aftermarket tank (4900 miles, ask $2200) and a '92 with 2500 miles, carb recently cleaned, and nothing but a FMF exhaust (ask $1500).
I'm leaning towards the cheaper '92, but will have to see them to be sure. What should a relative newbie to thumpers know about these bikes, and look for in a used one? From my reading it seems that a hard-to-find neutral is a warning sign.
Wandering re-establishes the original harmony which once existed between man and the universe. --Anatole France
Rex Nemo is offline   Reply With Quote
Old 09-10-2010, 12:39 AM   #5753
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,084
Send a message via Skype™ to shearboy2004
$2200 for a 93 sounds to me to be bloody high, it would need to be a SE model with electric start before i would even look at it .
$1500 for the 92 is still high in my opinion unless it is in really good condition , the FMF exhaust are wonderful for creating noise and annoying the folks next door.
They should start easy and run quiet, they are really solid machines but a worn carb can make them run like crap , make sure they idle well with no spluttering , if the seller has started them before you get there be suspicious. Touch engine to make sure.
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 450 called BLING.
07 Sherco 510 called Holy Shit .
shearboy2004 is offline   Reply With Quote
Old 09-10-2010, 06:24 AM   #5754
1TufMarine
Resistance Is Futile
1TufMarine's Avatar
Oddometer: 126
Grrrrrrrrrrrrrrrrrrrrr!
Damn electrical gremlins !
96 SE
Will not fire with the magic button. It will push start so that eliminates a few problems. Tore into the button assembly itself and it looks fine.
I have it all broke down ( seat off, guage cluster broke down, etc...) but am kinda at a loss as to what to start testing....
I have the Clymer manual ( through 94) but the wiring diagram is not exact close may not help this time.
Anyone wanna take a stab at helping me weed out the ....
The problem kinda came on slow....meaning it started a few times after dicking with it . I adjusted the clutch cable some thinking that maybe it wasn't engaging the switch and that seemed to work...once....
so......
My head makes me want to blame the clutch switch. I know this has been covered but I can't find it fast and I am in dire need of my bike to be running ASAP! I don't want to just start chopping wires either.
Some people go through life wondering if they've made a difference in the world...Marines don't have that problem - Ronald Reagan
1TufMarine is offline   Reply With Quote
Old 09-10-2010, 06:43 AM   #5755
rubberband
rubberband's Avatar
Oddometer: 318
confirm the kickstand switch and clutch switches are working properly....or wire them out of the system. It's a good place to start.
Does the easy button work? Check the contacts.
Any noise from the starter?
2011 UPAT
rubberband is offline   Reply With Quote
Old 09-10-2010, 07:06 AM   #5756
1TufMarine
1TufMarine's Avatar
Oddometer: 126
Pretty sure the kickstand switch is working OK because I can push start it. The clutch switch is my main suspect at this point. I wanna start by eliminating it but am not sure of that procedure just yet.
Yes I 'think' the easy button is Ok...I have it apart and all looks pretty sweet in there.
No noise from the starter. It isn't getting fire due to whatever. I suppose the starter could actually be the problem but I doubt it. It started to many times as this problem progressed. My best guess is something in the switching process.
I need to get out there and put a meter on stuff but I am a total idiot when it comes to tracing stuff like this.
Process of elimination ....I need to make sure my wire cutters are well hidden!
Thanks for replying...I need the moral support at the very least!....
Old 09-10-2010, 07:20 AM   #5757
tpar1220
such a pud..
tpar1220's Avatar
Oddometer: 2,007
Send a message via Skype™ to tpar1220
for the clutch switch you don't even have to cut anything. take the headlight cover off and follow the wires coming from the clutch switch to behind the headlight cover. then simply unplug them and plug the two from harness back into each other. 5 min job.
my buddy picked up a 99se, the po had been starting it using a screwdriver... jumping the selenoid. i bypassed the clutch switch and starter works perfectly.
you push it!......... it's your motorcycle.
There will only be two things left moving after WW3.
Cockroaches & KLRs.
tpar1220 is online now   Reply With Quote
Old 09-10-2010, 08:14 AM   #5758
MiteyF
MiteyF's Avatar
Oddometer: 1,007
I paid 1500 for my 93 S with about 4k on the clock, running/riding perfectly.
As to the FMF comment, I bought my bike with stock exhaust and put an FMF pipe on. When I bought the bike I had 5 people in 3 days pull out RIGHT in front of me. "Loud pipes save lives" may be a bit extreme, but I love knowing I can be heard. It's like having a bright headlight - sure, some people will bitch when it shines in their eyes from the other lane... but I'd rather have an angry cager that sees me than a happy one who doesn't any day of the week.
Old 09-10-2010, 08:52 AM   #5759
1TufMarine
1TufMarine's Avatar
Oddometer: 126
Continuity test are coming out good across the whole circuit as far as starter button all the way to the clutch switch.
I see what you are saying about just plugging them together. I'll try that.
Kickstand switch seems fine because it will push start. Or am I wrong not to suspect that?
I'm stumped at this point. Starter relay maybe?
Old 09-10-2010, 08:58 AM   #5760
1TufMarine
1TufMarine's Avatar
Oddometer: 126
It's kicking my ass no having the wiring diagram.
Anyone know where the heck the later model diagrams are?
I swear someone posted one but jeesh I have no clue who or how far back?
Times are GMT -7.   It's 05:18 AM.
