Old 09-28-2010, 01:39 PM   #5941
matloik
kludge
matloik's Avatar
Oddometer: 1,245
Get the TM33 pumper carb! All who have will undoubtedly echo that sentiment. Search and read up on it.
Originally Posted by cruiserbrett
Hi all,
Just got a 1999 Dr350SE and I am trying to nail down some problems... BST33 CV carb:
Got the carb apart to clean the pilot jet(clogged) and discovered that the gray plastic part that the vacuum slide slides against appears to have caught fire and melted at one point-yeah!?!? inside the carb... needless to say its trashed, so I need another carb... Could use a few other little parts like the wire that holds the idle speed cable knob to the float bowl.
If anyone has one send me an email or PM.
BTW, CLR cleaner in the lime green bottle does a fantastic job of cleaning the jets. Dont use it on the cast body of the carb...
-Brett
2011 KTM 250 XC-F / DRZ-ADV / 2013 WR250R (wife's)
matloik is offline   Reply With Quote
Old 09-28-2010, 01:47 PM   #5942
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,424
Originally Posted by yondering
I like that. Got a part number, and/or an online source?
Also, is that a MT43 front tire? What do you think of it?
Here yer are Mate !
I used to burn the crap out of my pants all the time but not anymore , these things work fantastic and don't look too bad .
http://www.cyclebuy.com/shopping/fla..._pipeguard.htm
Love the MT43 ! I don't a lot of high speed dirt cornering, mainly single track so for me it is perfect , it sticks to rocks and roots like glue .
I run my rear at 10lb and the front at 8lb I don't even bother airing up for the road and it handles it all well and man do they last forever !!!
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is online now   Reply With Quote
Old 09-28-2010, 02:02 PM   #5943
worldrider555
worldrider555's Avatar
Oddometer: 447
hey guys, I just bought a parts bike to help when I refurbish mine.
Its a 95 dirt model, does anyone know if the suspension on this is better then my 94 street model? It definitely looks nicer, looks similar to the suspension on my dr 650 that I had last year. Also by the way Im gonna sell some of the parts on it, like the keintech vortex air box, and the pumper carb, and the engine, I have an add in the flea market if anyone is intersted.
worldrider555 is offline   Reply With Quote
Old 09-28-2010, 03:48 PM   #5944
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Yes, the dirt model suspension is better
If you do sell the pumper be sure that you have tested it and it works 100% because they ALL wear out eventually
If it's not working 100% in all throttle ranges you'll probably have one pissed off buyer on your hands.
Bob Onit is offline   Reply With Quote
Old 09-28-2010, 04:00 PM   #5945
worldrider555
Oddometer: 447
Thanks for the advice, I think Ill just sell it for a discount instead of dealing with trying to get it running etc
Old 09-28-2010, 04:07 PM   #5946
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
IMO that's not a very good idea. There is no in between. Either the slide bore is worn out or its not.
The only way to tell is if it's installed on a running bike such as yours and you have all the parts which will make it a simple test.
Old 09-28-2010, 04:18 PM   #5947
worldrider555
Oddometer: 447
interesting, perhaps I will put the pumper on my street model when i tear it down just to test it? Is the slide bore you are reffering to the channel that the throttle rides in? Wouldnt the plastic wear out before the metal?
Old 09-28-2010, 04:24 PM   #5948
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Yes...and the slide and the bore are both metal..... that's the problem.
Old 09-28-2010, 04:52 PM   #5949
worldrider555
Oddometer: 447
ahh I see, well i guess Ill have to test her out then. Thanks I appreciate the info
Old 09-28-2010, 07:03 PM   #5950
hajime
hajime's Avatar
Oddometer: 196
[QUOTE=shearboy2004]Here yer are Mate !
G'Day Mate,
That looks interesting! I'm not so sure it looks good, but it does look like it will work. Good looks are over-rated anyway...THX
hajime is offline   Reply With Quote
Old 09-28-2010, 07:06 PM   #5951
AaronK
Grumpy Grumperson
AaronK's Avatar
Oddometer: 260
Originally Posted by shearboy2004
Here yer are Mate !
Which model number pipe guard did you purchase and how did you attach it to the header?
AaronK is offline   Reply With Quote
Old 09-28-2010, 08:24 PM   #5952
shearboy2004
KIWIINUSA
Oddometer: 4,424
I believe i got the 1171 not that i think it matters a whole lot , they can be bent into shape fairly easily.
They come with mounting clamps that actually work well but do put some high temp locktite on the screws .
88 R100GS
98 DR450
Old 09-28-2010, 10:23 PM   #5953
AaronK
Grumpy Grumperson
AaronK's Avatar
Oddometer: 260
Old 09-29-2010, 08:51 AM   #5954
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,407
[quote=hajime]
Here yer are Mate !
G'Day Mate,
Being a certified Cheap Bastard(tm) I went to my local machine/welding shop, rooted around in his scrap pile and for the price of 4 hose clamps and a six pack of beer got these heat shields:
Ride what makes you giggle in your helmet
oremike is online now   Reply With Quote
Old 09-29-2010, 02:12 PM   #5955
yondering
yondering's Avatar
Oddometer: 1,100
Cool. I really like the MT43 rear on my DR for singletrack, but haven't tried the front. It has some downsides, but is worth it in our slick roots/rocks/mud trails we have in the PNW.
You mentioned not doing much high speed dirt cornering, but can you give an opinion on how that front tire works in that situation? I felt like the rear MT43 ruined the high speed gravel road handling; does the front make it even worse?
yondering is offline   Reply With Quote
Times are GMT -7.   It's 09:05 PM.
