Old 10-07-2010, 07:36 PM   #6031
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Originally Posted by EastBoundAndDown
It doesnt make a whole lot of sense, but thats how it was when I bought it. I have the Raptor 660 petcock added to my winter parts list for her.
It makes perfect sense..... it's just overkill.
And now I understand it wasn't your idea.
the Raptor660 petcock will do just fine unless you decide to go with a Clarke tank someday
Bob Onit is offline   Reply With Quote
Old 10-07-2010, 08:18 PM   #6032
MrPulldown
MrPulldown's Avatar
Oddometer: 3,356
I was actaully thinking about getting an acerbis tank and trying to run the stock petcock on one side. Will scrap that idea now.
I change my oil at 500 miles, since most of my riding is slow offroad. But i don't ususaly get to it till about 750 :)
MrPulldown is online now   Reply With Quote
Old 10-08-2010, 11:43 AM   #6033
straight cut
Oddometer: 136
Whats a good oil change interval? Book says 60 hours, which would be about 1800 miles for me I ride 70/30 street/dirt. Is that too much?
1,000 miles for the oil, oil filter at 3,500miles
Dont forget to clean out the oil strainer on the bottom of the front down tube
straight cut is offline   Reply With Quote
Old 10-09-2010, 11:05 AM   #6034
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,604
My clutch is slipping. It's odd, because it'll slip when the oil is cold, then it seems to go away as everything heats up. Should I try a different oil?
The previous owner told me the bike had a "heavy-duty clutch" installed when they put the piston kit in it. It's 435 cc, so there is more power for the clutch to handle.
Maybe I'll put a new clutch in it.
Well, I ain't always right but I've never been wrong.
It seldom turns out the way it does in the song.
Old 10-09-2010, 05:21 PM   #6035
MrPulldown
MrPulldown's Avatar
Oddometer: 3,356
Klay,
With 55k post, I will just go ahead and assume that the cable tension is adjusted correctly.
Old 10-09-2010, 05:53 PM   #6036
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,604
Originally Posted by MrPulldown
Klay,
Although post count has nothing to do with anything, yes, it's adjusted right.
Old 10-09-2010, 06:07 PM   #6037
matloik
kludge
matloik's Avatar
Oddometer: 1,245
No, with 55K posts, we expect that it's adjusted right.
2011 KTM 250 XC-F / 2013 WR250R
matloik is offline   Reply With Quote
Old 10-09-2010, 07:57 PM   #6038
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Or at least the spelling has been corrected
Still want to buy my DR250 Klay?
Old 10-09-2010, 08:04 PM   #6039
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,604
I think you live too far off.
Old 10-09-2010, 08:07 PM   #6040
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,604
Hey, this is a good time for some DR350 pictures. Here's how she's set up now:
I just need to figure out what to do with the clutch.
Old 10-09-2010, 08:14 PM   #6041
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Thats exactly what I was wondering when you had interest in buying it last month.
Quite a drive.
Old 10-09-2010, 10:23 PM   #6042
LooksGoodInRed
aka TrilobiteMX
LooksGoodInRed's Avatar
Oddometer: 131
Foot Pegs issue
I went for my first longer dirt ride and I realized my foot pegs are at different height. Left one is higher.... throw me out of balance when standing.
Is this a normal thing with DR? Both left and right mounting brackets looks stock.
Did any of you noticed something like that on your bike?
95 DR 350 SE
Before I start looking for replacement I would like to hear what others noticed.
'03 BMW F650GS
'08 CRF 230L
'00 GZ 250
"The most effective way to do it, is to do it" - Amelia Earhart
LooksGoodInRed is offline   Reply With Quote
Old 10-10-2010, 04:37 AM   #6043
3uba296
Thumpcurious
3uba296's Avatar
Oddometer: 134
Looks great Klay! Fall it is..
Dr350(80)R-97
3uba296 is offline   Reply With Quote
Old 10-10-2010, 05:33 AM   #6044
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Pegs should be at the same height, something is bent, broken or worn out. SE models have rubber mounted pegs, maybe the rubber on one side is more worn out than the other.
Klay, it sounds like the pressure plate when cold is bottoming out on the inner hub before it gets a chance to squash the clutch pack properly. When the pack gets hot it expands quite a bit. Could be due to very worm clutch plates, crappy aftermarket plates that were too thin to start with or to few plates installed. For fun you could try slipping in an extra steel plate and see what that does for you.
Alternatively, if the cable is too tight (mentioned already I know) or too dirty/worn such that its not entirely releasing it will do the same thing.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 10-10-2010, 07:56 AM   #6045
AndrewStout
AndrewStout's Avatar
Oddometer: 30
Newbie questions!
Hey everyone, I've loved this place even before I picked up my97 DR350SE. This is the place that convinced me this should be my bike!
Ok, the newbie questions. I have just moved to Belize and the DR was brought down in the back a pick up through Mexico. It ran great in Indiana, but I'm starting to get what my friends call the Belize flu. They say everything gets sick once it comes, but after that they are fine.
here are the symptoms. Speedo stopped working, left turn signal stopped working and just yesterday I had the first time it refused to restart after a short ride to the Chicken place. It seems like from reading it was the typical hot start problems, but it has never done it to me before.
It started up after 5 mins and I made it home.
Here are my thoughts. Being cranked down to a bed of a truck through Mexico messed up the turn signal and speedo. Not sure about the hot start or what really causes it. I did think possibly elevation and the carb not adjusted right, but where I lived in Indiana is 712ft and I'm just under that here around 550-600ft. Is that enough to matter? I'm not thinking so.
Anyway, any help would be great!
Andy
AndrewStout is offline   Reply With Quote
Times are GMT -7.   It's 10:36 PM.
