Old 10-11-2010, 02:52 PM   #6061
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Originally Posted by Airvent
Im looking for some handgaurds for my DR350. Their primary role for me would be keeping the cold wind off my hands for the winter....
What color were the stock hand guards on your DR350?
I have a stock set and I'm only a few miles from you
Bob Onit is offline   Reply With Quote
Old 10-11-2010, 07:27 PM   #6062
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,423
Originally Posted by pablo83
Does anyone make a fork brace for the '98 DR350 kicker?
I haven" seen one Mate but then i stopped looking after putting a RM front end on mine .
Would the one for the DR650 work ? Maybe someone here wold know .
http://www.kientech.com/DR650ForkBrace.htm
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 10-12-2010, 05:38 AM   #6063
rfx
White Lighting
rfx's Avatar
Oddometer: 162
My DR350se is for sale if anyone is interested!
http://www.advrider.com/forums/showthread.php?t=627869
Action sport Photos:
http://tomolesnevich.smugmug.com/
http://www.tomolesnevich.com/
Ride: To move by way of an intangible force or impetus; move as if on water.
Current: 03 DRZ400s
Sold: 95' DR350se (You'll be missed)
rfx is offline   Reply With Quote
Old 10-12-2010, 06:45 AM   #6064
EastBoundAndDown
EastBoundAndDown's Avatar
Oddometer: 717
Any interest in selling the clarke tank separate?
"The only way I knew I didn't miss a turn off was the occasional side by side tracks where you could see evidence of massive acceleration and fun." - Cobra5150
EastBoundAndDown is online now   Reply With Quote
Old 10-12-2010, 07:10 AM   #6065
Bowtie76
Bowtie76's Avatar
Oddometer: 321
Hard shift 3-2
Has anyone ever had issues with hard shifting from 3 down to 2? I can find neutral easy, upshifts are fine but the 3-2 downshift I have to stomp on the lever to get it to go.
I read the 3rd gear thread on the 650's but have not seen anything except for hard shifting into neutral for the 350. Anyone have any ideas?
Bowtie76 is offline   Reply With Quote
Old 10-12-2010, 09:46 AM   #6066
3uba296
Thumpcurious
3uba296's Avatar
Oddometer: 134
Can someone confirm that there are only two different OEM cams to the DR350, the newer with autodecomp, and the older without?
Dr350(80)R-97
3uba296 is offline   Reply With Quote
Old 10-13-2010, 05:51 AM   #6067
Greg Bender
Oddometer: 1,200
Originally Posted by MrPulldown
On a side note. THere use to be a DR350 page. Really good info. Talked about common problems, mods, maintance... The best part was that it had links to repair manuals. I can not remember the guys name anymore. Use to be one of the first things that popped up when you search dr350. Now I can not find it anymore. THere was also a cartoon along the bottom of the page of a DR350 running from the cops, pulling a wheelie and flipping over and blowing up. Anyone got a link to that guys page. I wanted to read his section on clutches.
Hi MrPulldown,
That was suzukidr350.com - G Man's Suzuki DR 350 Resources. The domain name is gone and I've reached out to G Man about hosting the content on my webpage (no charge), but I've not heard back from him. Excellent site and I wish I had downloaded all of the content from it. I do have the workshop manual here:
http://thisoldtractor.com/gtbender/d...rkshop_manuals
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 10-13-2010, 01:27 PM   #6068
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,639
Just a reminder for those with a pumper:
If you're re-jetting, and you don't put the little spring back under the plunger for the accelerator pump, it'll run rich.
Don't ask me how I know.
Now that that little oversight is corrected, got the jetting on my 91 sorted out for now:
Vortex airbox, TM33 pumper, FMF can, stock header.
140 main, needle clip on 4 (4th one down from top), pilot jet 40, air screw 1.75 turns out. Might go to 142.5, gonna ride it for a bit.
With the street gearing still, it lofts the tire in 2nd easy. Gonna be switching that out for lower, don't need to be able to do 80 mph, got my GSA for the high speed gravel.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 10-13-2010, 02:24 PM   #6069
MrPulldown
MrPulldown's Avatar
Oddometer: 3,339
THanks Bender,
At lest some knew what I was talking about. The site is no more, how sad. I was going mad looking for it.
Thanks for the link on the repair manual.
Cheers
MrPulldown is online now   Reply With Quote
Old 10-13-2010, 03:02 PM   #6070
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
The 3rd gear problem with the DR650's doesn't apply to the DR350.
If you're not running motorcycle oil (or running oil with "friction modifiers") it could cause problems as you described.
If you are using the proper oil and have an older (kicker) model DR350 do some research on the " Shift Drum Bolt" and possibly worn shifting forks.
The shift drum bolt is usually the cause for having a tough time finding neutral and it can lead to disastrous results if ridden without the simple repair.
Good luck.
Bob Onit screwed with this post 10-13-2010 at 03:07 PM
Old 10-13-2010, 03:29 PM   #6071
MiteyF
MiteyF's Avatar
Oddometer: 2,001
Good luck.
Where might one look for this?
MiteyF is offline   Reply With Quote
Old 10-13-2010, 04:06 PM   #6072
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Google is always a great place to start.
Or the DR/DRZ forum... one must join to read the boards but it's well worth it
http://www.maximum-suzuki.com
Or the ThumperTalk DR forum .... no need to register to read and tons of information if you know how to search a forum.
http://www.thumpertalk.com/forum
Old 10-14-2010, 10:52 AM   #6073
MrPulldown
MrPulldown's Avatar
Oddometer: 3,339
Motorcycle oil. Ohh lets not get started on this one. Or do, I love reading what people have to say about this.
Old 10-15-2010, 06:33 AM   #6074
Bowtie76
Bowtie76's Avatar
Oddometer: 321
Good luck.
I thought I remembered reading something about that. Well looks like I'm going in...
I'll check out the clutch backet, and add the kick start while I'm in there. Sounds like a great cold weather weekend.
Old 10-15-2010, 07:57 AM   #6075
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,639
Don't forget the keeper plate from the donor engine, you won't know until you've buttoned it up and try to kick it that you've forgotten it. It's the one held on by two screws, above an a bit left of the KS shaft hole:
You can just see the edge of it on the left, under the KS idler gear.
Times are GMT -7.   It's 08:23 PM.
