Old 10-24-2010, 09:15 AM   #6121
AaronK
Grumpy Grumperson
AaronK's Avatar
Oddometer: 260
Originally Posted by Greg Bender
Hi snow4aaron,
The inside diameter of the o-ring is 15.8mm. The width (or cross-section) of the o-ring is 2.4mm.
The "only" harm in not running the o-ring is that there will not be a tight seal between the filter and the engine case. This will lead to oil not being forced through the filter as it should.
Short-term consequences? Nothing to worry about. Long-term consequences? Increased wear to everything the oil is supposed to lubricate. When I bought my DR350 used a year and a half ago, the o-ring was there, but the filter was installed backwards with the spring on the wrong side. I can't remember for sure if that was the exact arrangement, but I do know that the filter wasn't filtering anything. Bike continues to run good. Filtering engine oil is a very good thing.
Regards,
Gregory Bender
Gregory
Thank you for the fast reply and explanation.
AaronK is offline   Reply With Quote
Old 10-24-2010, 07:20 PM   #6122
RRMoto
Oddometer: 4
jcalis, thanks, today, to try to dismantle and replace the resistor on a piece of wire.
RRMoto is offline   Reply With Quote
Old 10-25-2010, 02:41 PM   #6123
boardrider247
Weekend Anarchist
boardrider247's Avatar
Oddometer: 736
Finally made a proper thread for my DR parts liquidation.
Find it here
http://advrider.com/forums/showthread.php?t=631455
boardrider247 is offline   Reply With Quote
Old 10-26-2010, 03:17 AM   #6124
halmc
Turkey T*urd
halmc's Avatar
Oddometer: 2,154
51T rear sprocket, anyone? I have a new Renthal, ordered by mistake, still in the blister pack, $20 to any lower 48 state inmate, including shipping. $15 Plus shipping outside da' 48. PM me if ya gotta have it.
BMW R1200RT; KTM 300 XCW; KTM 400 EXC: Suzuki 350SE; Buell X-1
Always forgive your enemies, but never forget their names -- JFK
halmc is offline   Reply With Quote
Old 10-26-2010, 08:31 AM   #6125
Ghostpilots
Oddometer: 91
Replaced the pads on my 1990 DR350S yesterday and ran into a bit of a problem. The front pads went on great, but when I went to replace the rear I found the piston nearly impossible to compress. After a LOT of wiggling and pulling, I managed to remove the old pads and immediately noticed that not only were they both severely worn down but that the right side pad that is pushed by the piston was worn down totally in the centre and 'U' shaped from pressure from the cylinder!
Now my problem is that since I cannot compress the piston, I cannot get both new brake pads back in! Opinions? I really have no idea what could be causing this, what I can do to fix it that ideally does not involve a full system bleed, or why it happened.
Ghostpilots is offline   Reply With Quote
Old 10-26-2010, 08:47 AM   #6126
Greg Bender
Oddometer: 1,200
Have you unscrewed the cap on the reservoir? That could be preventing the fluid from being pushed back up into the reservoir when you squeeze the piston.
Could be a collapsed line allowing fluid to move in one direction, but not the other.
Could be a mostly seized master cylinder or caliper piston.
Just some random thoughts...
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 10-26-2010, 08:50 AM   #6127
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,026
I suspect the linkage between the rear brake lever and the brake master cylinder is adjusted too tightly. This won't allow the master cylinder piston to return far enough to release the pressure to the caliper. You could open the bleed valve on the rear caliper which will allow the fluid to escape. This won't solve the problem but it will tell you if the caliper pistons are operating.
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 10-26-2010, 11:22 AM   #6128
MiteyF
MiteyF's Avatar
Oddometer: 2,001
I'm about to do a little tune up (valves, oil, and take a look at my clutch) and like others, the clutch drags in gear, but only when she's cold. I suspect it's just oil and a cable adjustment, but I'm going to do the shift drum bolt and replace the thrust washers most likely too. Or at least order new ones just in case. However, I don't know where the shift drum bolt is at, and the Suzuki parts diagrams don't list it as so. Does anyone have the part number for the bolt and thrust washers? Or at least describe where exactly they're at so I can order the right thing? Figure they can't be too expensive, so I might as well grab some just in case. She's my DD, so I don't want to find out they're fucked and then have to wait for parts to arrive and ride my pretty bike in the rain until they do.
Any help?
MiteyF is offline   Reply With Quote
Old 10-26-2010, 11:29 AM   #6129
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Bob Onit is offline   Reply With Quote
Old 10-26-2010, 12:16 PM   #6130
MrPulldown
MrPulldown's Avatar
Oddometer: 3,339
benifits of a CV carb
Is there a reason why the S and SE modles of our bikes were speced with a CV carb.
MrPulldown is offline   Reply With Quote
Old 10-26-2010, 12:21 PM   #6131
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,581
Emissions, right?
I have the 435 big-bore kit in mine, but the CV carb is working perfectly. The airbox is opened up and the carb rejetted.
The future is bright, fruitful, and positive.
Old 10-26-2010, 12:24 PM   #6132
original mcguiver
original mcguiver's Avatar
Oddometer: 30
Laugh
More E.P.A. compliant -better fuel mileage and jetting is not as sensitive of elevation changes...
original mcguiver is offline   Reply With Quote
Old 10-26-2010, 12:30 PM   #6133
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Mcguiver, do you have any data to support the EPA claim?
I've often wondered why Suzuki used the BST rather than the TM.
Thanks.
Old 10-26-2010, 12:41 PM   #6134
original mcguiver
Oddometer: 30
Thanks.
Bob, I don't have anything I can put my hands on right now but the street compliant bikes all used the CV carbs and the diret bikes used the pumpers
Old 10-26-2010, 01:13 PM   #6135
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
I'm well aware of this. I'm just curious why Suzuki would put such a lousy carb on a decent bike.
I guess it would have to be EPA related since the BST costs more than the TM.
thanks.
Times are GMT -7.   It's 05:35 PM.
