01-08-2011, 09:48 PM
#6661 | |
Rocket Surgeon
Oddometer: 1,519
$1,000 tops for the one on CL this time of year. I bought my '91 in CT with 2,800 miles in excellent condition on it for $550. I paid $700 for my '90 in the dead of summer. Be patient the deals will come. Try Search Tempest http://www.searchtempest.com/ Good luck |
01-08-2011, 09:59 PM
#6662 | |
Rocket Surgeon
Oddometer: 1,519
There are many good deals to be had in seasonal riding areas of the country. |
01-08-2011, 10:16 PM
#6663 | |
Dual Sport Addict
Oddometer: 988
![]() I will have to start saving my pennies for a new one. I have mostly new jets so between those and your carb I might be back on the trail. The way it runs right now makes it very difficult to ride but I'm so desperate for my fix that I've been doing it anyway.
2011 DirtRoad650 http://i838.photobucket.com/albums/z...mping12182.jpg '98 DR 350 http://i838.photobucket.com/albums/z...t/Photo280.jpg '99 DR 650. Sold. |
01-09-2011, 07:46 AM
#6664 | |
Oddometer: 611
Here's how I start my 1993 dirt model with the factory pumper carb. Petcock on, choke/enricher pulled all the way out. I pull the decomp lever and hold it, kick it through a bunch of times and then release the decomp lever (this is all to get the fuel/air mixture into the chamber). Then I kick it through slowly until I feel compression. I let the kick lever return to the top. Then I pull the decomp lever and immediately release it, kick it through just a tiny amount until the decomp clicks. I let the kick lever return to the top. Now I give it a real starting kick. One or two tries and she starts up every time. Without this ritual, it was a cruel battle that would take me 10 or 15 minutes. The key - I believe - is to give it the real kick just after TDC. Hope this helps! Regards, Gregory Bender |
01-09-2011, 08:20 AM
#6665 | |
Wanderer
Oddometer: 2,451
dc |
01-09-2011, 08:23 AM
#6666 | |
Oddometer: 251
01-09-2011, 08:25 AM
#6667 |
Oddometer: 10,906
shearboy re the weights I suspect that suzuki may have been a little bit more optimistic than ktm. Also note that that's for the off-road only, kick start DR350. The 350SE, a more apples-to-apples comparison is about 30lbs heavier.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038 Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703 |
01-09-2011, 08:28 AM
#6668 |
snoogins
Oddometer: 105
So I just picked up a 1990 DR250. It came with an Acerbis tank that I am trying to install. In reading and searching through the thread, it look slike I'm missing the mounts that install on the engine mount to the frame. It also looks like locating replacement items is very tough. Anyone know where I can get replacement items, or can post pics/dimensions so I can make some?
Also, I see that both the right and left side petcock is actually below the carb inlet. Will this cause any problems - ie, fuel not being fed to the carb properly? I thought gravity needed to help out on that account... Any help is appreciated-I thought I'd post here, since the 250 shares so much with the 350... |
01-09-2011, 09:44 AM
#6669 |
Oddometer: 1,987
Starting Ritual:
Here's how I start my 1995 dirt model with the factory pumper carb. (Has factory decompression). Petcock on (long enough to fill the carb), choke/enricher pulled all the way out, maybe kick 2 or 3 times. Half warm, choke pulled one step out... warm, heck just kick it. It usually starts on the first kick warm. Do not TOUCH the THROTTLE... or it will be a mess to start. |
01-09-2011, 10:13 AM
#6670 | |
KIWIINUSA
I am at 5000ft and ride to 10,000 so my demands aren't as great nonetheless I would like to hear how it works out for you.
88 R100GS 75 Norton Commando Roadster 98 DR450 07 Sherco 450 called BLING. 07 Sherco 510 called Holy Shit . |
01-09-2011, 10:29 AM
#6671 | |
KIWIINUSA
I think the important thing is to lean what your particular one likes and stick to it , don't be one of these guys that turns their legs into a frigging windmill kicking the crap out of it .
01-09-2011, 10:30 AM
#6672 |
Oddometer: 10,906
uwjberg, you can order the stuff from Acerbis I think. I got a replacement petcock and stuff from my local (awesome) dealer who ordered it up from acerbis. Shouldn't be hard to locate at all.
01-09-2011, 11:02 AM
#6673 |
snoogins
Oddometer: 105
Huh - I'll try with my local shop. They can usually find stuff. Thanks for the tip - I had kept reading that they were hard to find, but hopefully I'll get lucky.
Will the petcock location be a big deal? I assume not, since it's made to work on the bike, but maybe the tank was made for the 350? Not sure on that one. |
01-09-2011, 11:47 AM
#6674 | |
Dual Sport Addict
Oddometer: 988
01-09-2011, 12:03 PM
#6675 | |
Oddometer: 10,906
