Old 01-11-2011, 06:26 PM   #6721
cwc
Oddometer: 917
Originally Posted by ztaj View Post
Thanks for info guys...... now I have to find some wires to tap into as there is no battery.
If you have a model with no battery it gets more complicated.
I use a Garmin 60Cx and just run it off the internal batteries.
Two rechargeable Nimh AA cells will run it for 20-22 hours which for me is the better part of two days riding. Here we can buy 4 batteries and a charger for less than US$20.
If you want to wire it to the bike you will have to add a battery and create some charging circuitry. IMO that is way too much work.
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc is offline   Reply With Quote
Old 01-11-2011, 06:54 PM   #6722
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Is your DR a Dirt model or an S model with a battery eliminator installed?
Bob Onit is offline   Reply With Quote
Old 01-11-2011, 07:36 PM   #6723
alskee750
alskee750's Avatar
Oddometer: 518
DR350 lighting kit..
Thanks.. Your totally right I'm starting to lead to getting one w/ lights, battery, etc. I just haven't been lucky in my search, anyone out there near in the ADV world hear or have a DR 350 for sale which is somewhat close by New York State, please keep me informed.
Alex
Originally Posted by cwc View Post
Here is a basic wiring diagram.
http://auto.howstuffworks.com/turn-signal1.htm
If you find a couple of turn signals and a turn signal flasher you can wire it up on the bench to get a feel for how it works and then mount the parts on your bike. You may not be happy with the performance if you don't have a battery.
If you are not into this sort of thing or don't have much time it might be easier and faster to get a bike that already has signals.
alskee750 is offline   Reply With Quote
Old 01-11-2011, 08:20 PM   #6724
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Alex
Try Search Tempest (it searches craigslist but much more efficient)
http://www.searchtempest.com/
Be patient and good luck!
Old 01-11-2011, 10:13 PM   #6725
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,393
Originally Posted by Akiva1080 View Post
Hi everyone, just a quick question...
Because of a dumb f-up on my part I stripped one of the brake pad pins rendering my rear caliper of my 99 s model useless.
Bought an entire rear assy from a 96 and swapped only the caliper and mounting bracket. After bleeding the whole system the brakes do their job when I spin the wheel by hand, but the caliper seems loose if not pushing the pedal. Is this normal? I can't recall it being that wobbly.
Someone may jump in and correct me here but I'm pretty sure it is a floating caliper and should have some movement , it feels like more than you had because it is all cleaned up now on a fresh install.
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 01-12-2011, 02:41 AM   #6726
ztaj
jatz
ztaj's Avatar
Oddometer: 934
Acording to the reg sticker its a "1998 DR350 W" I only picked it up last night and rode it 300+ k's home.
Seems to go O.K. it's got an FMF muffler and I suspect it has been re-jetted, has a lot more pull than the other 2000 DR350 X in the garage, but I only got 150k from a full tank of fuel
How can I tell if there's a battery eliminator installed ?
Here it is.....
and here's the other late model one ( the wifes bike )
ztaj is offline   Reply With Quote
Old 01-12-2011, 02:54 AM   #6727
MiteyF
MiteyF's Avatar
Oddometer: 1,977
Here it is.....
150,000 miles on a tank? I'd say you're doing pretty well
You can tell if it has a battery eliminator kit by... seeing if the battery has been eliminated... aka, is there a battery?
MiteyF is offline   Reply With Quote
Old 01-12-2011, 09:52 AM   #6728
ztaj
jatz
ztaj's Avatar
Oddometer: 934
Every where you go, there's alays one
So.... when are you 'Mericans gunna join the 21st century and start using proper measurements ?
Old 01-12-2011, 10:17 AM   #6729
MiteyF
MiteyF's Avatar
Oddometer: 1,977
The smart ones already do
Old 01-12-2011, 12:38 PM   #6730
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,399
Yep, this could be the DR22 thread.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 01-12-2011, 12:47 PM   #6731
_CJ
Retrogrouch
_CJ's Avatar
Oddometer: 1,530
Alex
Keep an eye on this site: http://www.bikefinds.com/suzuki-dr350-for-sale
_CJ screwed with this post 01-12-2011 at 01:03 PM
_CJ is offline   Reply With Quote
Old 01-12-2011, 12:54 PM   #6732
BikePilot
BikePilot's Avatar
Oddometer: 11,253
Under $2k for a 1999 sounds like a fair price to me. The mileage wouldn't bother me, especially if its mostly street. I'd guess that 20k on the street probably works out to less wear than 2k hard dirt miles.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 01-12-2011, 01:12 PM   #6733
EastBoundAndDown
EastBoundAndDown's Avatar
Oddometer: 594
Alex
Found these 2 on CL that are what I would consider somewhat near NY.
http://nwct.craigslist.org/mcy/2135760024.html
http://philadelphia.craigslist.org/mcy/2119571953.html
And this one on New England Dirt Bikes, you might have to register to view this but its in Mass, a 1996 SE with 4k miles for $1600 bo
http://www.nedirtbikes.com/content/1..._230934/tm.htm
"And if my thought-dreams could been seen
They'd probably put my head in a guillotine
But it's alright, Ma, it's life, and life only."
'Couple old Kawasaki's and an Orange 200
EastBoundAndDown is offline   Reply With Quote
Old 01-12-2011, 01:16 PM   #6734
EastBoundAndDown
Oddometer: 594
Do you enjoy it? I just have a garmin car gps with the rechargable battery and it only lasts about 2 hours on my bike, so I've been eyeing the 60Cx, even if it ran low I figure I could carry batteries with me...
Old 01-12-2011, 01:21 PM   #6735
Country Doc
Wanderer
Oddometer: 2,706
I think that's about right. Amazing how hard dirt riding is on equipment.
I toasted a brand new chain, F/R sprockets, F/R wheel bearings, three sets of brake pads, and a host of other stuff on my '09 KTM in one season of hard dirt riding. Sheesh!
dc
Country Doc is offline   Reply With Quote
Times are GMT -7.   It's 01:04 AM.
