Old 01-24-2011, 03:56 PM   #6871
lstuckey1
Ret. Pro Bench Racer
lstuckey1's Avatar
Oddometer: 100
Originally Posted by fletchbee View Post
Hello guys,
Has anyone bought that DR350 Stock Muffler Conversion from Kientech?
If so had it made any differents to power?
what about the combo deal he has going with the stock exhuast mod and jet kit?
Iam thinking of getting the jet kit but might get both?
It's about 100 US dollards plus shipping. [from Australia, might cost as much to ship it there and back though]
Just wondering if it's worth getting the stock pipe converted or getting an after market that is lighter and maybe better?
What are your thoughts?
Is there a good aftermarket can that works with his jetting kit?
Thanks for your time and help
kind regards
Andrew
I also replaced a loud Cobra silencer with the stock/modded Kientech silencer and jet kit. While I cant say that it was a significant improvement in power over stock, I will say that the engine is more responsive to the throttle with no stumble or flat spots and no "popping" on closed throttle deceleration. It seems much more crisp. I'm very happy with the sound as well.
lstuckey1 is offline   Reply With Quote
Old 01-24-2011, 04:17 PM   #6872
johnnyandjebus
johnnyandjebus's Avatar
Oddometer: 532
Originally Posted by dtp View Post
You can try cleaning it as suggested or what I did was go to Cycle Gear and bought a new one. Any after market switch will work. I chose one that is much easier to read for on and off than the stock switch.
Thanks for the replies all
DTP any suggestions on an aftermarket replacement? I did a quick search and am unable to find any variety.
John
1994 DR350se
johnnyandjebus is offline   Reply With Quote
Old 01-24-2011, 04:17 PM   #6873
yondering
yondering's Avatar
Oddometer: 1,100
Originally Posted by frdbronco8 View Post
As I pulle the spark plug cap off the plug it practically fell off the wire when I let go. Not sure if this has something to do with the resistor you speak of.
This may have been the problem, or part of it anyway. If you look in the plug boot where the wire went, you'll see a pointed screw. The wire threads onto this; if it was loose it could cause intermittent spark and bad idle. If it's nasty, you'll want to trim the wire back a bit and re-install by twisting the boot onto the wire. (note how the core sticks out and is bent around the outer sheath) I hope that fixes it; it must have vibrated loose.
The resistor is accessed from the spark plug end of the boot, not the wire end. Look for the flat head slotted screw down in the boot.
yondering is offline   Reply With Quote
Old 01-24-2011, 04:49 PM   #6874
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,424
John
Mate I have tried about everything out there as far as after market mufflers and found they were all obnoxiously loud with massive amounts of backfiring on decel freaking annoying for me and anyone riding with me along with pissing off general public .
I went with Jesse's modded one and have been very happy , nice tone with it.
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 01-24-2011, 07:11 PM   #6875
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,634
John
I scored one from a wrecker for an R1 for ten bucks.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 01-25-2011, 04:34 AM   #6876
Greg Bender
Oddometer: 1,177
Bought a new plug today and started pulling things apart. The air filter was pretty dirty so I cleaned it (just to eliminate everything i can) and am waiting for it to dry as we speak. As I pulle the spark plug cap off the plug it practically fell off the wire when I let go. Not sure if this has something to do with the resistor you speak of. Ill mess with it when i get back into the garage.
Ill keep ya updated, thanks for the help.
To answer your question my experience with carbs is on the low end. I have had a BST 40 all the way apart but never been deep into a pumper carb.
PS any one have prefence with the DPR9 over the DPR8 spark plug or visa versa?
Hi frdbronco8,
If you are looking for a new spark plug cap, I've had good luck with this one.
http://thisoldtractor.com/gtbender/d...g_resistor_cap
Hope this helps!
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 01-25-2011, 04:42 AM   #6877
Greg Bender
Oddometer: 1,177
Hello guys,
kind regards
Andrew
Hi Andrew,
My 1993 DR350 dirt model came with a SuperTrapp that was way too loud for my taste. I wanted something a lot quieter. I bought a modded muffler from Jesse and I'm very pleased with it. It isn't silent, but it is much quieter. As for performance, I couldn't tell any difference between it and the SuperTrapp (seat-of-the-pants dyno).
I started off with Jesse's recommended jets, but they were too big for my DR350 where I ride (2250 feet and up, up, up from there). I'm back down a lot closer to stock (37.5 idle, 132.5 main) and it is running great (only other mod I inherited is the air box).
I've never experienced a stock muffler, so I can't provide any comparison data for you there.
Hope this helps!
Regards,
Gregory Bender
Old 01-25-2011, 06:37 AM   #6878
dtp
dtp's Avatar
Oddometer: 383
John
Yeah the switch I bought was this one here. Only $20 and it works. My local Cycle Gear had about three or four in stock.
http://www.cyclegear.com/spgm.cfm?L1...em=PRC_L15-150
07 Husqvarna TE250,07 VStrom 650, 92 Suzuki DR350S
"Go soothingly on the grease mud, as there lurks the skid demon!" -- 1962 Honda Safety Rules
dtp is offline   Reply With Quote
Old 01-25-2011, 07:45 AM   #6879
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,470
WHY are all the deals on the wrong side of the country!
Guy lists this bike as a dual-sport, but the headlight looks like the offroad version to me:
http://www.cycletrader.com/find/list...r-350-97949866
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 01-25-2011, 08:36 AM   #6880
Airvent
Airvent's Avatar
Oddometer: 347
I would assume that is not street legal. No mention of title or any apparent street equipment.
Airvent is offline   Reply With Quote
Old 01-25-2011, 10:20 AM   #6881
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Its a dirt model, note the lack of a starter motor and presence of a kicker :)
He may have gotten a plate for it though. Great deal too.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 01-25-2011, 11:06 AM   #6882
_CJ
Retrogrouch
_CJ's Avatar
Oddometer: 1,618
Mine's a street model and it has a kicker with no electric starter.....as do other pre-1994 DR350S's.
_CJ is offline   Reply With Quote
Old 01-25-2011, 11:12 AM   #6883
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,470
This one is a '98, with the updated forks.
Old 01-25-2011, 11:52 AM   #6884
BikePilot
BikePilot's Avatar
Oddometer: 11,251
The add says 1998, no reason to think that's wrong, esp as its got forks that can't be older than 1997, the frame color was only used in later years, it lacks turn signal mounts on the rear fender support, etc. Unless someone has swapped a ton of parts around its a 97-99 dirt model.
Old 01-25-2011, 01:20 PM   #6885
EastBoundAndDown
EastBoundAndDown's Avatar
Oddometer: 683
Newb question - when I do an oil and filter change on my DR is it better to warm the motor up before I drain it? That's what I do on my trucks but they have much more oil in them so I'm not sure if it matters on this bike, it's my first 4-stroke.
"The only way I knew I didn't miss a turn off was the occasional side by side tracks where you could see evidence of massive acceleration and fun." - Cobra5150
EastBoundAndDown is offline   Reply With Quote
Times are GMT -7.   It's 03:16 PM.
