Old 01-30-2011, 02:45 PM   #6961
LawrenceTheCat
3rd,Pinit,DumpdaClutch
LawrenceTheCat's Avatar
Oddometer: 143
Originally Posted by Speedo66 View Post
It appears both my proposed purchases have crapped out.
No new prospects at this time.
Looking for a '98 or '99, anybody have one they're looking to sell?
I saw this, it's a 97 tho.http://southjersey.craigslist.org/mcy/2181448927.html No price given, and it won't start. How would we approach this? The saying goes-"never approach a bull from the front, a mule from the rear, or an fool from any direction"
"Bones....-what is it?" ".....He's dead, Jim!"
LawrenceTheCat is offline   Reply With Quote
Old 01-30-2011, 03:11 PM   #6962
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,479
Definitely worth checking into. Might be one of those pick it up cheap and clean the carb finds.
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 01-30-2011, 06:12 PM   #6963
globe
Oddometer: 4
In case you haven't tried it yet also.
www.statewidelist.com
globe is offline   Reply With Quote
Old 01-30-2011, 06:57 PM   #6964
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Oddometer: 4,083
Offer $300-$500 and see how you get on. For that sort of money, you could rebuild or replace the engine and still be ahead of the game. If compression is OK, it probably just needs the carb cleaning.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 01-31-2011, 06:54 AM   #6965
Speedo66
Oddometer: 4,584
I'm a little leery about buying a non running bike. This is CL after all, so who knows what the tranny, engine, etc. are really like? "Oh, you mean the hole in the engine from the unlubed chain breaking and smashing through it is a problem?"
Thanks to all for the great search suggestions. I've looked everywhere at this point, including all mentioned, plus Craiglook.
I'd prefer the '98 and '99 models because of the improved forks.
'01 Kawasaki W650
'05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 01-31-2011, 07:21 AM   #6966
LawrenceTheCat
Oddometer: 143
Yes, on craigslist you can't even go by the pics- and some of the general populace can really talk some sh**, to be sure. If you are dead set on getting those forks, you might have to wait and pay a premium for the bike. Evilbay might have the exact machine floating somewhere.
My impression from the ad was the seller had little interest or knowledge, had made an failed attempt to repair it (the spare coil), possibly a squid spoiled by newer toys that considers a 14 yo bike to be hardly worth the effort. I would be calling the guy myself if I had some mad cash handy. Good luck, I'm sure if you keep your eyes open something will surface.
Old 01-31-2011, 07:42 AM   #6967
RiverRatRider13
Motorcycle Chum
RiverRatRider13's Avatar
Oddometer: 328
how close are the 99s suspension to a drz? I thought I remember reading some where a while ago that drz wheels will fit a 98 or 99 dr350 because the susp was the same? is that true?
RiverRatRider13 is offline   Reply With Quote
Old 01-31-2011, 07:57 AM   #6968
BikePilot
BikePilot's Avatar
Oddometer: 10,901
In terms of performance its approximately equal to the DRZ-K and E (and later S models), but a bit flexier. Note that early DRZ-S models had crappy damper rod forks.
In terms of actual mechanical parts there is no commonality. If front wheels happen to fit its not because the forks are mechanically the same but because suzuki couldn't be bother to cast new hubs
A race tech cartridge emulator will make early DR forks work about as well as later ones so don't be too hung up on finding a 98-99 model. Also the forks are only one small part of the overal handling equation - you've still got a shock with lousy valving (no matter what year), a swingarm that is ultra-flexy and a bunch of weight. The DR's a lovely bike, but its not really suited to being pushed really hard and fast. For most dual sporty riding I don't think you'll find the older-style forks a limitation.
Also, you'll likely here many claiming the DRZ has the same forks as the RMs from 1996-1998. This isn't true although the forks look sorta similar from the outside they are totally and completely different inside.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 01-31-2011, 08:20 AM   #6969
RiverRatRider13
Motorcycle Chum
Oddometer: 328
thanks for the info! Luckily im not that great of rider and I really wont be pushing it that much. I really just like exploring. The forks and rear susp on my 99 seem fine. Like i said though I am no expert!
Old 01-31-2011, 08:33 AM   #6970
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,479
I'm a little leery about buying a non running bike . . .
That's understandable. But, if it's close enough to take a look at you just never know. I didn't know anything about DR's when I bought mine and I felt the same way. Even though it wouldn't start it appeared to be in great condition and looked like it had seen very little use, kicked over OK but just wouldn't fire so I took a chance - these DR's aren't really very complicated. In my case the PO's story made sense too - he said he bought the bike a couple years ago then injured his back in a car accident and never rode it except for once around the block when he brought it home. The bike was chained to his back porch and he had to cut the chain off so I could look at it because he couldn't even remember where the key to the chain was. He was asking $1750, but ended up taking $1200. Turned out to be a great bike. You just never know.
Old 01-31-2011, 01:42 PM   #6971
thetourist
Just passing thru
Oddometer: 3,079
[QUOTE=Speedo66;15073002
QUOTE]
here is a pretty good search engine. Looks like all the wee DR's are out west this month.
http://motorcycle.jaxed.com/cgi-bin/...o=d&submit=+GO+
thetourist
The gate guard glares at me. "It's after curfew." He looks me up and down, "What do you think you are, some kind of ****** tourist?" ..Phu Loi 1969
http://advrider.com/forums/showthread.php?t=667893 My Idaho
thetourist is offline   Reply With Quote
Old 01-31-2011, 01:55 PM   #6972
cwc
Oddometer: 730
Reserve fuel in an IMS tank
A few days ago there was a discussion of aftermarket tanks.
The link below leads to a clip showing my son tapping the reserve supply in the IMS tank on his KLR. This also works on a DR350.
http://contour.com/stories/getting-all-the-gas
If someone can tell me how to embed this I'll do that.
Charlie
DR350 It'll get you there
But then so will my DR650
My Ride Reports Here
cwc screwed with this post 01-31-2011 at 05:20 PM
cwc is offline   Reply With Quote
Old 01-31-2011, 04:22 PM   #6973
_CJ
Kick'n it old-school
_CJ's Avatar
Oddometer: 749
Not mine. Just ran across the add locally. Oddly worded, "350DR" vs. DR350.
http://www.advrider.com/forums/showp...postcount=5171
_CJ is offline   Reply With Quote
Old 01-31-2011, 04:56 PM   #6974
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
I need a beefier skidplate than the stock one. Who makes a good one?
Pablo83 is offline   Reply With Quote
Old 01-31-2011, 06:00 PM   #6975
_CJ
_CJ's Avatar
Oddometer: 749
I could probably weld something up if you don't need it too soon.
Times are GMT -7.   It's 09:12 PM.
