Old 02-04-2011, 05:25 AM   #7021
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,712
Originally Posted by GsVs View Post
Hey kobukan ...
Great you got out on such a COLD day !
Curious ?? -- what racks are you using to support the Wolfman bags ???
Can you post some closer pictures ??
Thanks ...
TCI Denali rack. There's not many new racks available for the DR350's anymore, especially with side bag supports.
These are the best pics I have on hand, sorry they don't show the rack very well..
Here's a couple links for more info & pics.
TCI Products Motorcyclegear.com
'04 R1150GS, '97 R1100GS, '99 DR350, '02 DR650, '03 DR650
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 02-04-2011, 05:33 AM   #7022
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Nice setup
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 02-04-2011, 06:15 AM   #7023
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,439
Rack 'n bags
Hey kobukan ...
Thanks for posting the pictures .... as BikePilot said ... "Nice setup" ..
Honda
GsVs is offline   Reply With Quote
Old 02-04-2011, 07:02 AM   #7024
AtlantaViking
AtlantaViking's Avatar
Oddometer: 961
I need a solution for my big feet
OK - I'm going to destroy the tranny in my DR unless I can figure out a decent/easy/cheap solution to my dilemma.
When I ride with MX boots, I find that as the trail gets more technical that I start moving around alot on the pegs. In the process my boot tip is always in contact with the shifter and sooner or later I catch a lower gear w/o the clutch. Its gotten to the frustration point.
The way I see it I can either fab a shifter extension or a bracket for the pegs to move them back (I saw the DR650 peg moving brackets - and thats a thought).
Has anyone else had this issue and found a decent solution
I'm here to chew bubblegum and kick ass....and I'm all out of bubble gum
06 Suzi DL1K
99 Suzi DR350SE
AtlantaViking is offline   Reply With Quote
Old 02-04-2011, 07:37 AM   #7025
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,564
I'd dealing with the same issue. I wear a size 49 mx boot and the shifter is way too close to the pegs to allow for up shifting. At this point I've got an extra shift lever that I will be experimenting with to come up with a solution. I'll let you know what I come up with.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 02-04-2011, 10:49 AM   #7026
EastBoundAndDown
EastBoundAndDown's Avatar
Oddometer: 748
I run a us size 13 and do fine witrh the dr shifter, when I use my mx boots, I just raise the shifter 1 spot, then in my street boots I lower it one. I have yet to do any single track riding on the dr though, so I will look out for this come spring time...
2002 DRZ-250S; 2008 DL650ADV; 2006 KTM 200XC (For Sale)
EastBoundAndDown is offline   Reply With Quote
Old 02-04-2011, 12:01 PM   #7027
matloik
kludge
matloik's Avatar
Oddometer: 1,245
I upshift with the inside lip of the sole of my mx boots. This way I don't have to have the shifter raised, and it doesn't require lifting my foot WAY up to downshift. Of course if your mx boots don't have a lip then that won't work for you.
2011 KTM 250 XC-F / DRZ-ADV / 2013 WR250R (wife's)
matloik is offline   Reply With Quote
Old 02-04-2011, 12:10 PM   #7028
AtlantaViking
Oddometer: 961
I think I'm leaning this way...It should be pretty easy to weld on an extension I think. When you get around to experimenting - I would love to see a pic!
Thanks for the feed back all. I thought about bumping the shifter up a notch but talked myself out of it. Maybe its worth a shot.
06 Suzi DL1K
99 Suzi DR350SE
Old 02-04-2011, 12:47 PM   #7029
BikePilot
BikePilot's Avatar
Oddometer: 11,251
The shifter is a bit closer to the pegs on the DR than on most bikes - wider pegs make matters worse. Always bugged me a little, but not a major issue for me. The shifter is mild steel, wouldn't be a huge ordeal to cut it and weld it longer. If you had another shifter to use for material that'd be ideal.
Old 02-04-2011, 12:56 PM   #7030
scharfg
Oddometer: 208
Thanks folks!
scharfg is offline   Reply With Quote
Old 02-04-2011, 12:57 PM   #7031
scharfg
Oddometer: 208
Originally Posted by pablo83 View Post
No, these are AllBalls PN's. Mouthfull's PN's are the universal ones. These are often stamped into the side of the bearing as well. You can take them to some auto parts stores or any bearing shop and get exact replacements.
Awesome thanks folks!!
ps: any stock numbers for the steering head bearing...?
scharfg screwed with this post 02-04-2011 at 01:16 PM
Old 02-04-2011, 01:52 PM   #7032
Mulekick
2.7 on Fu Man Chu
Mulekick's Avatar
Oddometer: 25,739
Originally Posted by PK View Post
Mine just arrived and I took some basic measurements for you:
The rack itself is 9 1/4" by 11" and 1/2" thick.
The mount arms are roughly 13 1/2" long.
When the front mount area (where it attaches to the bike) is level horizontally, the front mount to the rack rises around 3 5/8" and the rear mount rises about 2 5/8".
It ain't much but it might get you started. All measurements are approximate.
Sweet! Thanks! I should be able to work with that. I appreciate you taking the time to measure it for me.
Don't walk behind a Mule................
note to self~ LEARN LIVE LOVE
Mulekick is offline   Reply With Quote
Old 02-04-2011, 02:21 PM   #7033
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,819
Is the DR350 a bare steel sleeve or Nicasil?
Pablo83 is offline   Reply With Quote
Old 02-04-2011, 02:25 PM   #7034
Greg Bender
Oddometer: 1,215
Hi Pablo83,
A cast iron sleeve is used.
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 02-04-2011, 02:43 PM   #7035
Country Doc
Wanderer
Oddometer: 2,757
Hey kobukan ...
That is a good looking setup kobukan. My only worry is how rugged the frame would be for multiple off-road "naps". For a dual-sport/touring bike though, the system looks ideal.
I think I'll try the Andystrapz expedition bags lashed to the Dirtbagz pannier rails, the same setup Dr. Rock uses on his Mobius DRZ's. They may not be quite as waterproof as your Wolfman setup, the trade-off being potentially more crash-worthiness.
Nice lookin' DR you have!
dc
Country Doc is offline   Reply With Quote
Times are GMT -7.   It's 02:00 AM.
