Old 04-23-2011, 08:26 PM   #8311
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Originally Posted by Bob Onit View Post
I have two brand new new TM33-8012 spares myself.
http://shop.viperizerracing.com/prod...&categoryId=75
Sweet, thanks for the link.
jessepitt is offline   Reply With Quote
Old 04-23-2011, 08:31 PM   #8312
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Get em while they're hot
Bob Onit is offline   Reply With Quote
Old 04-24-2011, 07:05 AM   #8313
RENCRN8
RENCRN8's Avatar
Oddometer: 249
Speaking of pumper carbs for the little DR.
I bought my wife a 1994 DR350SE a couple years ago and it came with a pumper on it of unknown origin. We really like how it runs. The only problem we see is that on cold start it is pretty finicky. I went out this morning to start it after it has sat all night.
choke up(if that is what it is), couple twists of the throttle, clutch in, push start button. crank crank crank fire, idles for a second then dies. If I do this about 4 times((with or without chocke) it will then idle fine and runs great.
Am I missing something or doing something grossly wrong on the start procedure?
I have concluded that I have this carb(size may not be exact one but I havent pulled it off bike to measure yet)
32mm MIKUNI TM Flat Slide smoothbore carburetor 13-5042
And final question. Is there an advantage to this carb over the dirt model pumper or vice versa?
RENCRN8 is offline   Reply With Quote
Old 04-24-2011, 09:06 AM   #8314
slowsuki1
Oddometer: 118
can someone tell me if the dirt model carb on the dr250 is the same size as the one on the dr350? the one that i have came off a dr250 dirt and it is 32mm inside .
slowsuki1 is offline   Reply With Quote
Old 04-24-2011, 09:07 AM   #8315
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
I don't think they are the same, the 350 carb is a 33mm.
Old 04-24-2011, 09:12 AM   #8316
TwilightZone
Oddometer: 3,152
>"choke up(if that is what it is), couple twists of the throttle"
IMHO: Don't touch the throttle on a pumper carb.
No touch = Couple kicks. One if hot.
Throttle = Many F'n kicks.
TwilightZone is offline   Reply With Quote
Old 04-24-2011, 09:18 AM   #8317
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
+1 I never touch the throttle when starting.
Old 04-24-2011, 09:31 AM   #8318
slowsuki1
Oddometer: 118
i find if i have not started my bike in a while it starts beter if i pull decomp lever and kick over 4-5 times with no throttle, before starting.
Old 04-24-2011, 11:10 AM   #8319
slowsuki1
Oddometer: 118
#8313 carb in pic is not pumper carb, just flat slide.
Old 04-24-2011, 02:19 PM   #8320
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
The DR250 dirt model came with a TM31 which are extremly difficult to find, if you can find one at all it's going to be big $$$$$$$
The DR350 dirt model came with a TM33.
Old 04-24-2011, 03:18 PM   #8321
sage06
Oddometer: 28
Question gearing
Hey, anyone know the stock gearing on a 93 duel sport model. the guy i got the bike from geared it waaay down. tops out at about 55 at full throttle. and 1st gear is pointless
sage06 is offline   Reply With Quote
Old 04-24-2011, 04:14 PM   #8322
Silentrider
Horizon Bound
Oddometer: 4
Neddle
I picked up a 1995 DR350 a couple of weeks ago and changed the usual- brake fluid, fork oil, engine oil and filter- I opened up the carb and emptied out what at one time in its life was gas- looked more like turpentine. The tip of the needle looks like it has been eaten away. Can I thank the ethonal in the gas for this?
Silentrider is offline   Reply With Quote
Old 04-24-2011, 04:38 PM   #8323
slowsuki1
Oddometer: 118
14-43 is factory gearing on 93 street model.
Old 04-24-2011, 05:10 PM   #8324
juda5
juda5's Avatar
Oddometer: 124
14-43 if memory serves... I run a 15 front if I plan to be on the road for an extended period of time -- 13 if I'm going to play in the woods.
juda5 is offline   Reply With Quote
Old 04-24-2011, 06:22 PM   #8325
clab04
The Sprout
clab04's Avatar
Oddometer: 121
my '92 has 15/41. First is pretty tall but its great on the highway.
'92 DR 350 Dualsport
Hey hey hey! Don't you think he is dead enough?
Well he shouldn't have been playing on my side of the street!
clab04 is offline   Reply With Quote
Times are GMT -7.   It's 01:12 PM.
