Old 09-18-2007, 11:00 AM   #76
CJohn
CJohn's Avatar
Oddometer: 55
I like the graphics you put on the 350 blackbird. Very nice
CJohn is offline   Reply With Quote
Old 09-18-2007, 11:15 AM   #77
blackbirdzach
Daily Adventurer
blackbirdzach's Avatar
Oddometer: 3,430
Thanks! I got them from Jesse at Kientech Engineering. They were $69, but the quality is outstanding. I'm having to get a light coat of clear put over them since they were ment for a metal tank and mine is a plastic IMS. I put my ADV stickers on this morning but I'm still waiting on my fork decals, swing arm decals and number plate decals.
blackbirdzach is offline   Reply With Quote
Old 09-18-2007, 12:19 PM   #78
blackbirdzach
Daily Adventurer
Oddometer: 3,430
I was next door at the motorcycle shop looking for some boots and saw these. They're the registration number stickers for watercraft. I couldn't help myself. Just screwin around till my Suzuki decals come in.
Old 09-18-2007, 01:58 PM   #79
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,890
Originally Posted by electrolite
There is no speedo cable. The previous owner removed the speedometer and there is just a plug where the cable connected to the metering assembly .
Is it possible to rebuild the metering assembly or can I use a spacer as on the other side and eliminate the metering assembly altogether?? Or do I have to buy a new one?
The inner bearing feel fine, they turn easy, real smooth.
-Nick
Well, Nick, at this point, it sounds like the metering assembly might be giving up the ghost. I have not seen anyone replace the assembly with a spacer. But, that doesn't mean it can't be done. If the assembly is truly shot, a good candidate for a spacer would be the inner sleeve in the assembly itself. I would just be sure the assembly is shot before you butcher it. Did you try to pull that plug out to see if there's any way to lube the gears inside? The only other thing I can think of is to replace the assembly (and the cable, if you so choose).
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 09-18-2007, 02:12 PM   #80
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,890
Originally Posted by Suzuki Phil
Can any of you DR350 gurus recommend a good set of tires? Most likely my riding will be 70% street to 30% off-road.
Thanks,
SP
Pirelli Scorpions (MT or AT - I forget), Avon Gripster or Distanzia. I still have the OE Dunlop 601s on my '99 DR. They're a little more like 50/50 if there is such a thing. You'll get a million opinions. It's almost personal preference. Dunlop 607s might work, too.
Old 09-18-2007, 06:53 PM   #81
Matttys
Matt the Balloon Guy
Matttys's Avatar
Oddometer: 436
Are these the Walmart seat covers? I've been looking for a low cost solution for making the seat hight a little higher on my DR and these will work well if they are cheap
www.ProTwister.com
'04 Bonneville hack, '05 DRZ134SM minimoto, '02 955i Tiger, '08 WR250R
Matttys is offline   Reply With Quote
Old 09-18-2007, 09:52 PM   #82
snare
sittin and breathin
snare's Avatar
Oddometer: 255
Looks like they are the China Mart ones to me, yes.
Mountain Forge
Combat Systema - Emergency Care - Outdoor Skills
Empowering You To Explore The Wild, Beautiful World
snare is offline   Reply With Quote
Old 09-20-2007, 05:34 PM   #83
GOT DIRT?
GOT DIRT?'s Avatar
Oddometer: 888
Blackbird, it looks good getting dirty!!!!
GOT DIRT? is offline   Reply With Quote
Old 09-21-2007, 06:13 PM   #84
electrolite
Wanderer
electrolite's Avatar
Oddometer: 48
Think I found the culprit
Now the question is, new assembly, or figure out a spacer?
electrolite is offline   Reply With Quote
Old 09-21-2007, 06:14 PM   #85
Burtonridr
Wanderlost
Burtonridr's Avatar
Oddometer: 3,727
I would like to know how they feel
Have beer, will fly
"This forum requires that you wait 30 seconds between posts. Please try again in 1 seconds."
Burtonridr is offline   Reply With Quote
Old 09-22-2007, 04:25 AM   #86
BikePilot
BikePilot's Avatar
Oddometer: 11,251
BTW new seat foam is $54 from Guts Racing.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 09-22-2007, 08:44 AM   #87
Matttys
Matttys's Avatar
Oddometer: 436
Really? Do they make taller foam too? I wonder how hard it would be to do a seat yourself? My seat is fine, however I would like some thing taller for offroad riding as standing up is pretty tough when you are seated so low.
www.ProTwister.com
Old 09-22-2007, 09:11 AM   #88
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Yep, that's what I put on my DR. Its super easy to DIY, I did my first dirt bike seat when I was 11yo;) All you need is a staple gun and some fairly short staples.
Old 09-24-2007, 12:19 PM   #89
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,890
Nick - what is that? Is it something embedded in the metering assembly or something that wore thru from the inside? I don't think you can disassemble those things, can you? Might be time for a new one. At least you figured it out.
Old 09-24-2007, 09:42 PM   #90
electrolite
Wanderer
Oddometer: 48
Dave - That is what appears to be a chip missing in the hard rubber of the metering assembly. What you see in the triangular hole are the gears that work the speedo cable.
I'm not sure what to do right now, a new assembly costs about $60 which seems a little steep for something I don't need. (I'm using a sigma bicycle computer)
Anyone got a suggestion on how to fix this one, or got a used one for sale?
-Nick
Times are GMT -7.   It's 02:08 AM.
