06-23-2011, 12:17 PM
#9016 |
Oddometer: 36
Non Cush Rear Wheel Question
I know there are two different rear wheels on the DR350. The "S" (street model through at least 1995) models have the cush drive and the dirt-only models have a "solid" hub. I think the street model received a solid hub in 96 or 97 that remained until the 350 was discontinued in 99.
My question is, are the rear sprockets for all solid hub rear wheels (1990-99 dirt-only and 96?-99 street model) the same, or are there differences between the early models (90-93) and the later ones? I have a 1995 DR350SE that has the cush rear wheel that I use with 50-50 tires and I have purchased a dirt-only solid hub rear wheel for a full knobby. I am wanting to install a 41, 42, or 43 tooth rear sprocket on the dirt wheel to match the street wheel and just change the countershaft sprocket for strictly off-road use. Are these sizes available for the dirt-only solid hub? |
06-23-2011, 01:41 PM
#9017 |
Single Track Noob
Oddometer: 1,455
front m/c bore spec
I ordered a moose front master cylinder rebuild kit for my 99se (0617-0084) and it's waaaay smaller diameter that the plunger coming out. The Nissin m/c is labeled a 1/2" bore as well as 8F 2. I'm starting to wonder if I have a non stock m/c or if the wrong part was packaged.
What is the correct M/C bore for a 99? Thanks.
Brian Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa ![]() www.PhotoSupportNW.com |
06-23-2011, 01:54 PM
#9018 |
Oddometer: 401
Got a guts tall seat and foam for free today. Back in february I sold my 97 DR350SE to a guy, and had just installed the guts tall sea. I'm 6'1 and this guy was 5'6 or so, I figured he would take it off for something shorter, at least the foam. Anyway I bought a DR250SE last month becuase I missed the 350, and this bike had the faom cut down lower than stock even.... I rode up to the guys house who I sold the 350 to since I had delivered it, and sure enough he was home, and gave me both the seat cover and tall foam. He also gave me the black steel bars off of the bike since mine has purple bars, and the aluminum handugards I sold it with. We BS'd for a few minutes too. I sold it with a new set of shinko 244's and i never got to test those, he told me they work great, so I will buy a set for this bike when the D606s are toast.
Anyways just mounted up the tall seat and love it, these bikes are a ton of fun, I've put 1000 miles on this 250 and I've had it 3 weeks!
"And if my thought-dreams could been seen They'd probably put my head in a guillotine But it's alright, Ma, it's life, and life only." KTM200, DR350SE, Concours 1000 |
06-23-2011, 02:21 PM
#9019 |
Young Rider
Installing the acerbis headlight and was wondering what the extra light built into it is for? It runs both high and lo fine on the main bulb, but has second smaller one for something
06-24-2011, 12:20 AM
#9020 | ||
not quite so broken
Oddometer: 686
06-24-2011, 03:31 AM
#9021 |
The Sprout
Oddometer: 121
I am wanting to install a 41, 42, or 43 tooth rear sprocket on the dirt wheel to match the street wheel and just change the countershaft sprocket for strictly off-road use. Are these sizes available for the dirt-only solid hub?[/QUOTE]
Here is a link for JT Sprockets. It will give you a list of applicable bikes for each sprocket. You have either a JTR808 or a JTR822. Just enter in those numbers in the search. You will need to measure the width of your hub bolt pattern to make sure. It should be 146mm or 156mm (5.75") (6.14"). I got mine at ebay. Love it. 15/41, 5100rpm @ 60mph and 54mpg with pumper carb! http://www.jtsprockets.com/61.0.html?&L=0
'92 DR 350 Dualsport Hey hey hey! Don't you think he is dead enough? Well he shouldn't have been playing on my side of the street! |
06-24-2011, 05:18 AM
#9022 | |
Oddometer: 584
Regards, Gregory Bender |
06-24-2011, 07:09 AM
#9023 | |
Oddometer: 36
Solid Hub Sprocket Question
http://www.jtsprockets.com/61.0.html?&L=0 [/QUOTE]Thanks for the info, that's just what I needed! |
06-24-2011, 07:10 AM
#9024 |
Oddometer: 10
I see your point. I am running 15/47 now and 1st is just usable and 6th is good for 60mph at 6,000rpm. Thought the big bore might allow me to go to a 14/43, but most likely my limiting factor is the spacing on the stock tranny.
06-24-2011, 12:21 PM
#9025 |
Oddometer: 223
tall seat?
I just about have my DR set up the way I want it. I am 6'1 and put 1.5 inch bar risers on to cure my hunched over when standing issues. Now I notice my knees bent and elbows reaching up for the bars when sitting. Tall seat foam sounds like the ticket. Does one need a new special seat cover to work with this?
Does this make a big difference for folks about my height? Thanks
2005 Yamaha Roadstar 1700 2008 KTM 450 XC (540) ATV 2005 KTM 450 EXC |
06-24-2011, 05:31 PM
#9026 | |
Young Rider
You would need a new seat cover if you get the foam. This place sells both and seems to be the only supplier of the two still around.http://www.gutsracing.com/SearchResu...ategoryID=1537 I too am 6'1" and have sat on one with the tall foam/cover (made by ceet) and felt like I was in a better riding position, needless to say it is also the next mod on my list
06-24-2011, 06:48 PM
#9027 |
Oddometer: 401
Just installed the guts tall seat yesterday and I'm 6'1. Do it immediately. Also I got the medium foam and its very comfortable.
06-25-2011, 08:20 AM
#9028 |
2 for the price of 1
Oddometer: 731
SE leaking fuel cap - solution???
searches have found mention of the problem, but not the solution & i have a dr200 doing it as well - hell of a mess.
and yes, a clarke or acerbis are on the short list for my 350 , but not the 200. thanks for your help! dean |
06-25-2011, 02:02 PM
#9029 |
Oddometer: 91
I opened the case of my 1990 DR350S the other day after a botched gasket replacement and kickstarter clean to find this. As you can see, the little lever gear thing attached to the gear shifter has been pushed upwards out of the case and into the kickstarter gear. It (the lever gear thingy) has been gouged and very slightly bent.
Bike HAS NOT been run since this happened, though it has been kicked over a few times, which probably is what started the problem i the first place. What happened I think is that the kickstarter lever was installed sitting in the 10 o'clock position, rather than the 12, and was then kicked over multiple times. ![]() ![]() ![]() So; thoughts on this problem? Is it bike-destroying? Can I just buy a new part to replace the gouged one? Why does it seem to be so far out of the case? This is out of my mechanical depth so any and all help would be great |
06-25-2011, 04:52 PM
#9030 | |
Single Track Noob
Oddometer: 1,455
