Old 06-28-2011, 07:00 PM   #9046
EastBoundAndDown
EastBoundAndDown's Avatar
Oddometer: 596
Should I be getting 45mpg on the street on my DR250SE? Its all stock jetting and motor just has a cut air box.... also it seems to sputter a but every once in a while.... think there is something i should troubleshoot? My DR350 used to get 60mpg...
"And if my thought-dreams could been seen
They'd probably put my head in a guillotine
But it's alright, Ma, it's life, and life only."
'Couple old Kawasaki's and an Orange 200
EastBoundAndDown is offline   Reply With Quote
Old 06-28-2011, 07:23 PM   #9047
BikePilot
BikePilot's Avatar
Oddometer: 11,253
I don't think I've ever managed worse than 50mpg and I'm usually around 60mpg.
Maybe if you really flog it and run high rpms all the time that'd be normal mileage on the 250. I'd check the usual tune up stuff and make sure you don't have a fuel leak or fuel leaking into the vacuum system if its got the stock petcock.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 06-28-2011, 10:47 PM   #9048
Joe_Dirt
Oddometer: 14
Hey I have a 92 DR350 and my rear rim is bent. Do any of you guys no where i can get a used one or aftermarket one? I cant find anything.
Joe_Dirt is offline   Reply With Quote
Old 06-29-2011, 07:55 AM   #9049
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 395
Question to those of you who have gone the big bore (385-435-etc) route. More power everywhere? Less rpm up top say at 60mph. Or do you still need to wring it out?
Just got back from a 1250mile loop with a KTM690, and 3 DR650's some higher speed sections had me looking for 7th gear. Even geared at 15-41 I was showing 6800rpm @ 75mph indicated....there were long sections like this even one 20mile solid strech. Motor was soild and the valves never moved from where they were set before the trip...
2011 UPAT
rubberband is offline   Reply With Quote
Old 06-29-2011, 08:06 AM   #9050
od al
Just aint right
Oddometer: 227
Finally got the new front end on the DR350. I put the 2001 RM250 inverted forks on and they're working great. So my question now is what are the rear suspension upgrades that will work well with the new front end? I'm wondering what is needed to run a RM250 complete rear suspension.
Just cuz I aint right don't mean I'm wrong
od al is offline   Reply With Quote
Old 06-29-2011, 08:22 AM   #9051
Country Doc
Wanderer
Oddometer: 2,707
I have a 441 big bore, pumper carb, oversize header, oversize valves, FMF pipe, blah blah blah. It makes about a million times more power than stock, (ok, that might be a bit of an exaggeration, but not much...), but remember that no matter how much power it makes, the gearing/rpm is going to be the same.
I have more power everywhere for sure. It still screams on the highway. I find on my '94, 15-41 is still pretty short gearing. The later bikes had different primary drive gearing so the same 15-41 is taller.
I now run 16-41 with my big bore and have no complaints. Cruising at 70-75mph is now more comfortable and it has plenty of snap for passing at those speeds. Obviously it suffers a bit off-road in slow conditions, but it depends on what you're using it for.
I go 15-41 for even pretty gnarly, steep double track and single track, and 16-41 for dual sporting, and it still gets me through some tough spots with a bit of clutch work.
dc
Country Doc is offline   Reply With Quote
Old 06-29-2011, 09:54 AM   #9052
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 395
dc
Thanks Doc. Thats kinda what i was thinking.... in it's current state of tune I would not want to go any taller with the gearing. You are right it's a later 97 model bike.
2011 UPAT
Old 06-29-2011, 10:35 AM   #9053
jonnykilo
Traveller
Oddometer: 205
Lowering links...
Anyone know what is available, or for that matter have any lowering kits avail for a '95 350? They only way I can sell buying another bike (orange preferably) is to lower the DR for my shorter (5'5") s.o. to ride.
jak
jonnykilo is offline   Reply With Quote
Old 06-29-2011, 10:53 AM   #9054
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 395
jak
Electric carving knife.....trim the seat, and restretch the material.
2011 UPAT
Old 06-29-2011, 11:06 AM   #9055
dav_dman
dav_dman's Avatar
Oddometer: 821
works awesome, been there done that and feet touch the ground ..dropped a 37" seat ht to 35 on the xr650L. I had an upholstery shop do it per my instructions cuz i didnt want to mess with staples and i wanted ss staples put back in..cost me 65 bux.
dirt bikes, vstrom, cruiser, etc.
"what hurts, instructs" - ben franklin
dav_dman is offline   Reply With Quote
Old 06-29-2011, 11:48 AM   #9056
ga4boats
Oddometer: 41
Former 97 DR350 owner here; I posted a WTB ad in the Flea Market looking for a DS DR350 and only got one response. Anyone know of any for sale? I live in the Atlanta area.
Thanks, Brent.
ga4boats is offline   Reply With Quote
Old 06-29-2011, 01:25 PM   #9057
Country Doc
Wanderer
Oddometer: 2,707
This is a good step, but your S.O. needs more than a seat shave to get her feet on the ground.
You need these as well.
http://www.koubalink.com/drinstall.html
dc
Old 06-29-2011, 02:15 PM   #9058
Bowtie76
Bowtie76's Avatar
Oddometer: 319
Thanks, Brent.
I've got a 350 but I swapped the engine for a 250 that I'm about ready to sell.
Bowtie76 is offline   Reply With Quote
Old 06-29-2011, 02:35 PM   #9059
ga4boats
Oddometer: 41
If you have a chance, can you PM me with some pictures and details?
Thanks, Brent.
Old 06-29-2011, 03:26 PM   #9060
jonnykilo
Traveller
Oddometer: 205
dc
I know. I was kinda hoping someone on here might have a set to sell - gotta save my pennies if I want to afford some orange this season.....
Times are GMT -7.   It's 12:22 AM.
