Old 11-17-2011, 07:28 PM   #10231
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,364
Originally Posted by Mission1 View Post
Hey Garth what are you doing here? Do you even own a dr these days. . ?
I was checking up on YOU...
2007 XR650R
2001 Montessa 315R
Garthe is offline   Reply With Quote
Old 11-18-2011, 11:32 AM   #10232
motolab
motolab's Avatar
Oddometer: 2,581
Originally Posted by EastBoundAndDown View Post
On the stock BST33 carb, is there supposed to be a plastic washer underneath the clip on the needle?
Yes there is.
Regards,
Derek
motolab is offline   Reply With Quote
Old 11-18-2011, 12:15 PM   #10233
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Be sure that the big plastic washer (# 3) is present and in the correct position as well.
It lays on top of the clip and the spring sits on top of it.
Bob Onit is offline   Reply With Quote
Old 11-18-2011, 12:46 PM   #10234
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,208
^ Maybe a dumb question, but is the needle supposed to be held in place or sit freely, held in the slide by gravity?
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 11-18-2011, 12:50 PM   #10235
motolab
motolab's Avatar
Oddometer: 2,581
It's held in place by the clip (#4), which is sandwiched between the spring seat (#3) and the needle spacer (#9).
Regards,
Derek
Old 11-18-2011, 12:55 PM   #10236
Rode2Nowhere
Oddometer: 2,208
Regards,
Derek
Holy $hit. Maybe that's my problem. Mine's just sitting in there. I'm happy to say that this time, it's not my mistake. Bike came that way.
- Jonathan
IBA #45896
Adirondack Tags
Old 11-18-2011, 07:19 PM   #10237
Helmet_Hair
Helmet_Hair's Avatar
Oddometer: 225
Yeah, that's probably it, unless the PO put the special anti-gravity needle in there.
Helmet_Hair is offline   Reply With Quote
Old 11-18-2011, 07:33 PM   #10238
EastBoundAndDown
EastBoundAndDown's Avatar
Oddometer: 632
Hmm, I don't have the thick washer, part #3. That must be why my needle became unseated. Thank you for pointing that out Bob.
"So long as roads were tarred blue and straight; not hedged; and empty and dry, so long I was rich."
06 KTM200, 08 V-Strom 650
EastBoundAndDown is offline   Reply With Quote
Old 11-18-2011, 07:54 PM   #10239
kobukan
almost gnarly
kobukan's Avatar
Oddometer: 1,712
You never know what a PO might have done. The TM33 pumper has two vent hoses and the PO of mine ran one hose between the two vents, effectively blocking them both.
'04 R1150GS, '97 R1100GS, '99 DR350, '02 DR650, '03 DR650
A Few Days Solo to Copper Canyon
A Maine Rider’s Arizona Day Trips
A Few Days Solo in Baja
kobukan is offline   Reply With Quote
Old 11-18-2011, 11:07 PM   #10240
motolab
motolab's Avatar
Oddometer: 2,581
I suppose you could call #3 a washer, but I think it would be more appropriate to call it a spring seat. Calling it a washer could cause some confusion, as the reader could mistake it for the spacer (#9) or perhaps think it's another part altogether (on the KTM BST40 carb for instance, there is a spring seat, a spacer, and a thick metal washer).
Regards,
Derek
Old 11-18-2011, 11:36 PM   #10241
Bob Onit
Rocket Surgeon
Bob Onit's Avatar
Oddometer: 1,519
Regards,
Derek
If you really want to get technical then lets call it what it is. It's called a "ring"
Part # 13382-42A00
Fits all DR350S models and other BST33 equipped machines.
Old 11-19-2011, 12:03 AM   #10242
motolab
motolab's Avatar
Oddometer: 2,581
Part # 13382-42A00
I suppose one could leave it to Suzuki to define for us what something "is". This brings up some interesting dilemmas. The first is that "engrish" has not been completely purged from Japanese technical literature, and I'd hate to just surrender unconditionally to the permanent perversion of the English language. The second is that they often call things by names that are technically completely incorrect, such as calling a cold start enrichment circuit a "choke". The third is that terminology should allow the reader to be able to distinguish one item from another, which is usually accomplished by having it be suitably descriptive, which brings us to fourth, which is in this case that they use the term "ring" to describe two different components with different purposes in the same assembly.
Regards,
Derek
Old 11-19-2011, 05:58 PM   #10243
dbarale
Squiddly slow
dbarale's Avatar
Oddometer: 1,269
I have a kidplate similar to this one on my DR project. Could someone tell me who made it and what it's worth? Thanks.
dbarale is offline   Reply With Quote
Old 11-19-2011, 09:31 PM   #10244
Rode2Nowhere
Oddometer: 2,208
Loosened airbox and carb holder clamps,
turned carb,
removed top, spring, needle...
Replaced needle, added washer found around shop so needle is held in place by spring,
Returned carb to normal position.
Tightened airbox and carb holder screws.
Rode 30 miles.
Fixed.
14 minutes of work after 2 months of ownership, chasing electrical problems.
Thanks to the randomly timely conversation between EastBoundAndDown and Bob Onit, I've got a working DR.
- Jonathan
IBA #45896
Adirondack Tags
Rode2Nowhere screwed with this post 11-19-2011 at 10:02 PM
Old 11-19-2011, 10:09 PM   #10245
dtp
dtp's Avatar
Oddometer: 383
Yeah that's happened to me more than once here too. Casually reading along and all of a sudden "hey I have that problem..."
What a gold mine.
07 Husqvarna TE250,07 VStrom 650, 92 Suzuki DR350S
"Go soothingly on the grease mud, as there lurks the skid demon!" -- 1962 Honda Safety Rules
dtp is offline   Reply With Quote
Times are GMT -7.   It's 12:40 PM.
