11-29-2011, 08:26 AM
#10306 | |
Oddometer: 87
Running 8 PSi in a D606 rear, I was pretty easily able to spin the rear enough to rip the stem out of the tube. I am setting up 2 sets of wheels -- street with no rim-locks (for the weekly commute) and dirt with 2 locks spaced as Greg described (for playing in the dirt.) |
11-29-2011, 09:26 AM
#10307 | |
Oddometer: 1,246
All DR350's wheels come with holes already drilled for rim locks. (statement not intended for you Greg but FYI to new-to-rim-lock folks)
94 DR 350 SE |
11-29-2011, 05:29 PM
#10308 |
Oddometer: 87
11-29-2011, 07:09 PM
#10309 |
Oddometer: 532
Does this sound ok?
Here's a run down of my bike:
3rd owner 4500 miles at purchase, now 14k Only used Suzuki 4-stroke engine oil since I bought it Engine all stock Runs fine 50 mpg off road 62 mpg on road Uni-filter is the only after market engine related. Check and adjust valves every year Transmission is getting hard to shift with clutch pulled in when not moving, bad but not too the point that I can't ride. Does use some oil but nothing I'd consider abnormal since it's usually turning 5K most of the time Cam chain tensioner has 1/4" of travel left Skid plate is coated with bed liner, sounds pretty much the same without it on Bike starts right up, bike hasn't been started since Saturday when I took the video today. Okay with that over take a look at this video I made today and tell me if my engine noise is excessive. ![]() Thanks, SP
1916 Ford Model T 1996 DR350SE Suzuki Phil screwed with this post 11-29-2011 at 07:14 PM Reason: add more information |
11-29-2011, 08:05 PM
#10310 |
KIWIINUSA
Sounds a bit noisy Mate , could be piston slap or it could just be cam chain stretch, 1/4 inch ain't much left .
88 R100GS 75 Norton Commando Roadster 98 DR450 07 Sherco 450 called BLING. 07 Sherco 510 called Holy Shit . |
11-30-2011, 02:30 AM
#10311 |
xendurist
Oddometer: 1,547
I recently purchased a 95 DR350SE with 1200 miles and part of that purchase was based on the notion that DR's are reliable. But, I also read about these engines failing or developing serious issues at a early age, say under 20K miles.
Just How long can these engines last when properly maintained and used 60/40 on road and off road? I'm used to owning 100,000 mile engines so when I read about these problems like running out of cam chain tension adjustment, replacing rings, clutch basket/bushing drag, shifting issues, etc. I begin to think is it poor maintenance, abuse or the limitations of a DR engine. So far I am very impressed with this bike and am happy I purchased it but realistically what kind of service limits can I expect?
Transalps |
11-30-2011, 03:54 AM
#10312 | |
Oddometer: 368
KTM 250 smokin lightweight Suzuki DR350... mellow fun KTM 450 EXC moved on XR 400 gone Transalp 600 always missed |
11-30-2011, 04:18 AM
#10313 | |
xendurist
Oddometer: 1,547
I don't think a DR is "as reliable as any well made single" , BMW F650's quickly come to mind and are know for their long service life without engine overhauling. Honda's NX650's have been know to run 60,000+ miles without major engine issues.
Transalps |
11-30-2011, 04:22 AM
#10314 | |
Oddometer: 818
You needed a big bore kit anyway. A few hundred bucks and a weekend, you're in business again. |
11-30-2011, 08:43 AM
#10315 | |
Oddometer: 368
11-30-2011, 09:22 AM
#10316 |
Oddometer: 1,246
Zuki Fill- My buddies DR sounds the same. Was like that the day he got it. Now 5K+ is sounds the same. Check the valves cam chain, everything looks right?? Who knows. There is a trick you get a little more tension out of the stock auto cam chain tensioner, he has yest to do. Hopes it quites things down. Let me find a link. He is jsut going to ride it till it blows up. Which might be never.
Mass- I think the longivety of the engine has a lot to do with how you ride it. Since the DR is much more dirt orineted riders tend to wringe the shit out of the motors. I know on some hill climbs I will redline and bounch off the limiter for the duration of the climb, and i think others do the same. Or my buddy who has his geared a little lower and takes it on the highway running at 8.5K rpm for 15 min at a time. How many people do that with their BMW 650's. Also what you read on the net is a very small population of the DR's out there. And most poeple post only when they have a problem. Most of all the DR owners I have meet NEVER post anything about their bikes.
94 DR 350 SE |
#10317 |
Oddometer: 1,246
94 DR 350 SE |
11-30-2011, 10:49 AM
#10318 |
explorer
Oddometer: 73
DR350 misses at high RPM
Any idea what causes my DR350 to start missing when I exceed 7200 RPM? I can get on it and everything is smooth, good pull and power until I cross the 7000 RPM range then the bike misses a spark. 4500 miles 1990 DR350
I have new fuel filter, cleaned carb and replaced float, new plug. I guess next will be new plug wire tonight. Thanks for the suggestions. Steve B
Steve Barrus North Bend, WA 1976 BMW R90/6 1999 DR650SE 1991 DR350S 1980 XL250 |
11-30-2011, 11:17 AM
#10319 | |
explorer
Oddometer: 73
Jesse says I'm running out of fuel and change jet to 145 since I have big bore 405 in it.. I will try this.
11-30-2011, 01:46 PM
#10320 |
xendurist
Oddometer: 1,547
MrPulldown, thanks for the reply. All the DR engine problems I read about on the internet are right here on this page as I started reading from page one to try and get up to speed.
I never expected this bike to be a 100,000 mile engine but at this point I haven't heard anyway with a mileage answer. Anyone riding a DR350 with say 40K on a unmolested engine? I like knowing that if a engine can reliably last a long time it generally says something about quaility of engineering. I am simply trying to get idea of what this engine is capable of as to longevity without major issues. 10K 20K 30K? I raced KTM's for 7 years and if I wanted high maintenance I would have bought another one. I looked for a long time to find a DR350, 95% of what I found was either not running, not running right, ran good the last time I ran it, had carb problems and didn't run right, had rebuilt top ends ( by questionable talent), clutch dragging or in general just a POS with no title. Even the bike I bought which only has 1,200 miles on it claimed to be running good but very cold natured, it was anything but the truth, Carb O rings were short, carb was dirty and it was running way too rich, plus the engine had a oil leak from loose engine case bolts and just about every other bolt was loose as well. I like the bike and it will suit my needs but I like knowing IF it can last a good long while.
Transalps |
