Old 03-20-2012, 06:36 PM   #11311
kknuth
Up Nort!
kknuth's Avatar
Oddometer: 190
Question Matching Blue Frame Paint?
Anyone know of a matching spray paint brand/color for the blue on a 1994 DR frame? My frame needs to be touched up before things get out of hand!
Thanks!!
kknuth is offline   Reply With Quote
Old 03-21-2012, 02:26 AM   #11312
P@vlos.B
Stuck in an Island
P@vlos.B's Avatar
Oddometer: 83
Originally Posted by dtp View Post
So will adding a shim/washer work without having to shave down the clutch basket?
Well, this is what it looks like!
P@vlos.B is offline   Reply With Quote
Old 03-21-2012, 02:46 AM   #11313
3uba296
Thumpcurious
3uba296's Avatar
Oddometer: 133
Yes, it´s really the same thing when you think about it, with the shim/ washer you are making the spacer between the current thrust washers longer resulting in some more play, same thing happens if you would take material out of the clutch basket.
Dr350(80)R-97
3uba296 is offline   Reply With Quote
Old 03-21-2012, 03:10 AM   #11314
Alli
Alli's Avatar
Oddometer: 56
throttle broken
Hi Teeeeeemu
Maybe this?
http://www.ebay.com/itm/94-Suzuki-DR...#ht_500wt_1219
I know this won't be as fast as you want, but still an option.
Alli is offline   Reply With Quote
Old 03-21-2012, 09:59 AM   #11315
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Originally Posted by Teeeeeemu View Post
Im not sure if I was on the correct stroke... If I was on the wrong one, HOW BIG would the clearances be? Many mm bigger or just a tiny tiny amount? Like I said, all gaps were bigger than what manual says. Intakes (carb side? think so) should be under 0.080mm and they were over 0.12
Exhausts should be 0.01 - 0.015 and they were over 0.02
You were on the correct stroke. If not, there would have been no clearance and you wouldn't have been able to measure the gap.
Pablo83 is offline   Reply With Quote
Old 03-22-2012, 08:40 PM   #11316
tntmo
Oddometer: 494
Originally Posted by Davey T View Post
So i have a 1990 dr350 dirt that runs like a bear but its a bitch to start some times with the whole manual decompression process. My 1994 dr350 dirt is auto decompression and works mint very easy to start. Can i retrofit the auto cam in a older head? part number wise it looks doable.
I wanted to do the same thing, so I called the expert (Jesse) and asked him. He said the 94 and newer DR350 had a different head and the auto-decompression cam won't fit in the older bikes. I have a 1991 that is a pain to start, and a 1998 that I can start with my hand....big difference.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 03-22-2012, 08:41 PM   #11317
Chicken Helmet
I'm A Stumper™
Chicken Helmet's Avatar
Oddometer: 5,001
What about swapping heads if you really wanted to go that far?
1988 KLR 650 Bare frame,swing arm & title For Sale PM for Details 2009 KLR 650 1994 DR 350
Originally Posted by WaterWheel View Post
From what I've heard, riding a DR feels just like riding a KLR except your head doesn't sway left and right constantly scanning the ditches for aluminum cans.
Chicken Helmet is offline   Reply With Quote
Old 03-23-2012, 11:20 AM   #11318
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,317
I finally got the wife's DR out for a test ride last night.
It's been in dry dock for an extended stem-stern overhaul.
Welded in a new steering stop, installed key switch, new front brake line, HID lights, rebuilt linkages, fresh oil in all suspension, valve adjust, new rear tire, brake pads at both ends, unclogged the airbox drain, fresh air filter, clutch EZ pull....
Wow! What a difference. The 55W HID really lights up the world. The motor purrs right along. After bedding in, the new brakes actually work. I'm looking forward to few years of riding now with just oil changes and valve checks.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 03-23-2012, 11:34 AM   #11319
MrPulldown
MrPulldown's Avatar
Oddometer: 3,156
oil vavle checks?
I was changing my oil out every 500. But then I see that the interval is more like 3k. I do it about every1000-1500. But it seems like forever or never.
Every time I check the valves they are spot on. I am begining to think that they never need to be adjusted either.
The only thing my bike ever NEEDS is gas and a air filter wash.
MrPulldown is offline   Reply With Quote
Old 03-23-2012, 11:38 AM   #11320
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 407
Originally Posted by HellSickle View Post
unclogged the airbox drain, .
has anyone rerouted thier bottom iarbox drain? Mine gets clogged damn near every sloppy ride. it "dumps" out just inside the front sprocket area. might post i pic tonight when i get home
And good job on the DR, have fun with it.
2011 UPAT
rubberband is offline   Reply With Quote
Old 03-23-2012, 11:41 AM   #11321
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,317
I think a better solution would be to entirely eliminate he hose. The little "frog vagina" check valve should be mounted directly to the air box, like XR's do.
Old 03-23-2012, 12:36 PM   #11322
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 407
"frog vagina" classic!
2011 UPAT
Old 03-23-2012, 01:14 PM   #11323
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,317
Same term used for camelbak drink valves.
You hydration experience will never be the same....
Old 03-23-2012, 02:46 PM   #11324
MrPulldown
MrPulldown's Avatar
Oddometer: 3,156
I"frog vagina"
I know the one.
Old 03-23-2012, 03:22 PM   #11325
tntmo
Oddometer: 494
That's what you'd have to do, an entire 94 or newer head with the auto decompression cam set up.
Times are GMT -7.   It's 04:49 AM.
