Old 04-23-2012, 03:34 PM   #11701
MrPulldown
MrPulldown's Avatar
Oddometer: 3,045
Originally Posted by Chicken Helmet View Post
Ok, i've spoke with one person who has done the RM fork swap and read a few threads and posts here from people that have done it. Two things; is there a thread somewhere on the pros and cons and differences between different year forks and what is involved in the swap with respect to rims, axles, brakes, etc...
I see people commenting about 96-98 forks, whats wrong with th 99 and newer as I have an opportunity to buy some 99 RM250 forks.
I jsut finsihed doing the 98 RM fork swap. As of my first ride (with old fork oil) I am not impressed. Though it was jsut a rutted dirt road. I have not ridden my dr in 4 months either, so it is not really a head to head comparision.
The 96-98 were dual chamber conventional forks. 99+ are up side down. What it comes down to is conventional vs USD forks. The jist is USD is more of a MX fork and conventional a trail bike fork. The pre 96 RM USD forks were said to be total crap, as they were jsut using them due to market demand. People think USD forks are sexy.
What ever you end up doing, you will need the entire front end: forks, triples, wheels, calipers, rotors. Then you will have to deal with insturmentation, head lights, blinkers; I am currently at that stage. The only drop in fork is an early 89ish RM fork as they are 43mm fork tubes like ours. Even then the wheel is different.
MrPulldown is offline   Reply With Quote
Old 04-23-2012, 09:35 PM   #11702
wbedient
MoTard
wbedient's Avatar
Oddometer: 1,265
Originally Posted by PhiSig1071 View Post
Just watched Mondo Enduro. Great show! Now I really do want a DR350.
Watch Tera Circa, you enjoy it as well!
2008 KTM 690 Enduro
My Videos: http://www.youtube.com/user/wbedient#g/u
wbedient is offline   Reply With Quote
Old 04-24-2012, 09:48 AM   #11703
.tdc
b00b
.tdc's Avatar
Oddometer: 14
does anyone have a kickstand in good shape laying around? preferably blue. some previous owner shortened mine and left the end a cut off pipe. i could (and probably will) weld a pad to the end, but i'd like to get my hands on a good stock one.
.tdc is offline   Reply With Quote
Old 04-24-2012, 12:30 PM   #11704
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,204
Rim lock question
Hey All,
n00b rim lock question for the masses. Never had a bike that used them before, and my '95 SE came with them installed (complete with the studs pulling out of the disintegrating rubber).
I'll be ordering a pair of Trakmasters in the near future. I rarely, if ever (I mean almost never) ride serious trails enough to need substantial airing down. Maybe 20psi for the 2-track or gravel that I spend most of my offroad time on. Is there a need for rim locks at this pressure?
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 04-24-2012, 12:50 PM   #11705
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,371
Will do.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 04-24-2012, 12:52 PM   #11706
Greg Bender
Oddometer: 1,158
Originally Posted by Rode2Nowhere View Post
Hey All,
IMHO, no.
Greg Bender is offline   Reply With Quote
Old 04-24-2012, 01:01 PM   #11707
MrPulldown
MrPulldown's Avatar
Oddometer: 3,045
I run them in my off road tires/wheels. Though I never air down, I figure this is a good insurance for a flat tire. With the stiff side walls of modern dual sport tires, you can basiclly run them flat. THe rim lock insures they don't spin.
Old 04-24-2012, 03:48 PM   #11708
P@vlos.B
Stuck in an Island
P@vlos.B's Avatar
Oddometer: 83
PM sent!
P@vlos.B is offline   Reply With Quote
Old 04-24-2012, 05:55 PM   #11709
MadChap
MadChap's Avatar
Oddometer: 437
Hey All,
My '97 SE does not have rim locks. I air down all the time, ride in the desert and have never had a flat. YMMV
MadChap is offline   Reply With Quote
Old 04-24-2012, 08:39 PM   #11710
tntmo
Oddometer: 460
I have two of them. PM sent.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 04-25-2012, 02:52 AM   #11711
Hammerspur
Hammerspur's Avatar
Oddometer: 1,138
Originally Posted by pavlos79 View Post
PM sent!
I've found much needed stuff here (ADV) in the past.
Gotta' love this place! I do...
Hammerspur is offline   Reply With Quote
Old 04-25-2012, 07:20 AM   #11712
spannerman
spannerman's Avatar
Oddometer: 51
Hi just got dr 350 and head gasket leaked after week have stripped down and found it is 385cc big bore i have a k+n air filter for it and dep silencer anyone had this set up before ???? what jetting works best , standard at moment 127.5 main 37.5 pilot , also where can i get head gasket in 82/83mm for big bore thanks
spannerman is offline   Reply With Quote
Old 04-25-2012, 03:13 PM   #11713
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Cometic sells an 82mm
http://www.cometic.com/powersports.aspx
If the K&N is the paper type and if you're ever going to ride where it's dusty, I'd swap it out for a foam type. K&N paper filters clog up quickly.
Pablo83 is offline   Reply With Quote
Old 04-25-2012, 11:14 PM   #11714
Helmet_Hair
Helmet_Hair's Avatar
Oddometer: 225
You'll want at least a 140 main jet on that baby. 127.5 is stock, and it was lean to begin with. I run a 137.5 on my stock 350. The big bore is going to want more juice than that. Pilot is probably fine.
Helmet_Hair is offline   Reply With Quote
Old 04-26-2012, 03:36 PM   #11715
Seavoyage
Seavoyage's Avatar
Oddometer: 133
DRZ250 swingarm for DR350?
Anyone try to shoehorn the DRZ250 swingarm into the DR350?
Apparently swingarm pivot bearing 22x29x30 and rear axle bearings 20x47x14 are identical. Shock eye to eye length are identical. Swingarm pivot bolt part #s are slightly different: 1105281 vs 1105287. I'm unable to verify rear hub width as the part #s are also different: 11110789 vs. 11110787.
I've asked tdrrally if he would take some measurementsto compare his DR350 and DRZ250.
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter. -Ernest Hemingway
Seavoyage screwed with this post 04-26-2012 at 04:02 PM
Seavoyage is offline   Reply With Quote
Times are GMT -7.   It's 09:30 PM.
