Old 05-08-2012, 04:43 AM   #11806
Teeeeeemu
Oddometer: 104
Originally Posted by cwc View Post
If you have access to deck screws you can make a tool like this.
http://www.advrider.com/forums/showt...l#post15551028
Thats BRILLIANT
after I get the stuck one moving. And find those screws somewhere...
Teeeeeemu is offline   Reply With Quote
Old 05-08-2012, 08:27 AM   #11807
Hammerspur
Hammerspur's Avatar
Oddometer: 1,138
Been planning to do that very thing myself with a square drive screw!
Hammerspur is offline   Reply With Quote
Old 05-08-2012, 10:07 AM   #11808
O'Hooligan
Ken Dodd's dads dogs dead
O'Hooligan's Avatar
Oddometer: 634
Originally Posted by Colbycheese View Post
Thanks for the link.
Gerry
O'Hooligan is offline   Reply With Quote
Old 05-08-2012, 12:29 PM   #11809
MrPulldown
MrPulldown's Avatar
Oddometer: 3,356
Front end of the bike is in peices again. This is the final assymbly of the RM fork swap. Kind of a bitch getting all the parts of the headset and triples just right. Jsut venting. Hoping to get her done so i can ride it to work on thrusday. Maybe even go for a real ride on Friday.
As a side note, was jsut doing some reading about the helmet lock on the DR350. Really. There was a helemt lock. I see one for sale on E-bay. Where would one install such a device. Was it a Candian thing, as both the reference and the e-bay seller are Canadian.
http://www.ebay.com/itm/NOS-1990-199...b8b875&vxp=mtr
Thought I would share, as it is new to me info, and I thought I have been aroudn the DR block a few times to know about most things like this.
MrPulldown is offline   Reply With Quote
Old 05-08-2012, 02:42 PM   #11810
trailhiker
trailhiker's Avatar
Oddometer: 55
Originally Posted by MrPulldown View Post
I actaully think I do understand.
This is regards to losing the cir-clip that holds on the front sproket on.
Jamm a stick between the frame rails so that it keeps the sprocket on. The chain will rub on the stick but it is good for a while.
Hope I never have to do this, but a good trick to remember.
Yes sir,it works to bring me in to the camp where i can put a new clip on.
trailhiker is offline   Reply With Quote
Old 05-08-2012, 02:55 PM   #11811
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,068
My '92 DR350S came with one. There is a tab on the frame on the left side near the back that it bolts to - behind the stock tool holder.
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 05-08-2012, 05:20 PM   #11812
_CJ
Retrogrouch
_CJ's Avatar
Oddometer: 1,705
Anyone have a feel for how much oil it takes to get from the bottom of the safe mark to the top on the DR350 dipstick?
Access to public lands is a right, not a privilege.
_CJ is offline   Reply With Quote
Old 05-08-2012, 07:05 PM   #11813
Helmet_Hair
Helmet_Hair's Avatar
Oddometer: 225
Are you talking about over filling the bike? If so, it takes maybe 2-3 cups to overfill it. If you're talking about from the very bottom of the dipstick (low-level) to the appropriate "F" mark, the answer is the same.
Helmet_Hair is offline   Reply With Quote
Old 05-08-2012, 08:54 PM   #11814
saddlsor
my butt hurts
saddlsor's Avatar
Oddometer: 334
just did this, although it was a little below the lower mark, it took 8 oz. to the full mark.
I don't know where I'm going, not sure where I've been.
-john denver
99 dr350
78 r80
saddlsor is offline   Reply With Quote
Old 05-09-2012, 08:32 AM   #11815
_CJ
Retrogrouch
_CJ's Avatar
Oddometer: 1,705
Cool, thanks!
Old 05-09-2012, 04:55 PM   #11816
mrpopgun
Oddometer: 38
I'm second guessing parting my 96 350se out which means I would be looking for parts. I'm putting this in the sales section too, but thought I would throw this out there
1) I either need a good electric start bottom end
2) Good piston and pin
OR
1) Good crankshaft
If I can find just the crank, well then I guess I'm going to learn how to split a case
mrpopgun is offline   Reply With Quote
Old 05-09-2012, 07:36 PM   #11817
Colbycheese
Colbycheese's Avatar
Oddometer: 106
Same here on my 96.
KLR685
DR350
Colbycheese is offline   Reply With Quote
Old 05-09-2012, 09:42 PM   #11818
.tdc
b00b
.tdc's Avatar
Oddometer: 14
Laugh
yeah, the s models had em. sorry for the dark picture, but you can see the tab hanging down under the rear fender on mine, just below the turn signal (lock not present).
currently working on a mount for a bottle opener to bolt to mine.
.tdc is offline   Reply With Quote
Old 05-10-2012, 09:37 AM   #11819
mrpopgun
Oddometer: 38
Cranks
So looking at the fiche and cross-model part lookup based on a '96 350se, it appears that on the DR's, it's the same crank for every single bike, all years. Is that true? Kick vs electric? Dirt vs Street?
Edit: One other question
I found a local '92 dirt model bike for a good deal. Are the engine cases interchangeable between the older kick model and my newer electric model? I know I'd have to move over the stator and such, but not sure the cases are the same. What about the starter? If I just I just installed the whole dirt motor, could I get the lights to work for street use?
mrpopgun screwed with this post 05-10-2012 at 04:18 PM
Old 05-10-2012, 02:13 PM   #11820
Goofy Footer
Oddometer: 559
Originally Posted by Rex Nemo View Post
Yep, rebuilding the carbs might be the way to go--an air leak in there somewhere seems feasible. And I have the Clark big tank on there, with a Raptor petcock that I've verified flows fuel just fine. Rode around the 'hood a bit more, and it stopped dying, though still runs rough. I'm still just way pleased to have gotten it running at all.
Will the Raptor petcock work on the stock tank? If so which years? My petcock is leaking and I hate vacuum petcocks anyways.
Goofy Footer is offline   Reply With Quote
Times are GMT -7.   It's 08:25 PM.
