Old 05-13-2012, 05:12 AM   #11836
Chicken Helmet
I'm A Stumper™
Chicken Helmet's Avatar
Oddometer: 5,005
Bike looks good. I gotta get me one of those headlight assemblies.
1988 KLR 650 Bare frame,swing arm & title For Sale PM for Details 2009 KLR 650 1994 DR 350
Originally Posted by WaterWheel View Post
From what I've heard, riding a DR feels just like riding a KLR except your head doesn't sway left and right constantly scanning the ditches for aluminum cans.
Chicken Helmet is offline   Reply With Quote
Old 05-13-2012, 02:05 PM   #11837
Teeeeeemu
Oddometer: 104
Any sideshots from the tank graphics? Where you got? How much?
I hdont like my white big ass tank on an otherwise black bike :(
Teeeeeemu is offline   Reply With Quote
Old 05-13-2012, 02:21 PM   #11838
mrphotoman
mrphotoman's Avatar
Oddometer: 1,207
The graphics were $39 shipped on ebay.
The headlight assembly was $59 shipped,
The fender was $23 shipped
I still have tons of decals left over, one is precut for the rear fender but I have been too lazy to put it on. The decals were for a rmz250 but all i cared about was the color and price lol
http://www.ebay.com/itm/280706897881...#ht_1239wt_905
mrphotoman is offline   Reply With Quote
Old 05-13-2012, 02:53 PM   #11839
Teeeeeemu
Oddometer: 104
I got rmz plastics on my dr, except tank. Pic a couple pages back. No wonder the texts looked so weird when you have them like that
Old 05-13-2012, 03:35 PM   #11840
FlyingWman
FlyingWman's Avatar
Oddometer: 250
KTM front fender and chopped KTM rear fender. Still needs a little tweaking .
I may have a supplier for tank decals soon... still very early in the works though, its my buddy who's got a decal/wrap operation...
___________________
2000 XR650R
1982 GS750TZ
FlyingWman is offline   Reply With Quote
Old 05-14-2012, 01:39 PM   #11841
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,489
I've got an NGK CR9EK for a spark plug I've been running. Has anybody run a spark plug that is a step hotter? Would that be a CR8? Which way is hotter?
The future is bright, fruitful, and positive.
Old 05-14-2012, 03:23 PM   #11842
Teeeeeemu
Oddometer: 104
Thats what I thought too and just checked NGks site and bigger number means colder. So 8 is hotter. Dont know how it affects the engine. I remember reading from the dr350 manual something about different heat plugs but cant remember what it was. I think it mentioned the 8. Switch to hotter plug if/when something. Try checking the manual if you bother, I dont.
Old 05-14-2012, 06:01 PM   #11843
EastBoundAndDown
EastBoundAndDown's Avatar
Oddometer: 686
Hows this. The DR350 I picked up runs great. 6K street miles, good power, good mpg, smoth runningh and idle, easy starting cold or hot.
Smokes when I first fire it up. Only for 5 seconds or so, but nothing else I own smoke like this. Is this any concern?
"The only way I knew I didn't miss a turn off was the occasional side by side tracks where you could see evidence of massive acceleration and fun." - Cobra5150
EastBoundAndDown is online now   Reply With Quote
Old 05-14-2012, 08:30 PM   #11844
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,878
They generally aren't known for smoking, so something's wrong. If it runs ok and isn't fouling plugs, however, its probably acceptable
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 05-14-2012, 08:42 PM   #11845
tkent02
Oddometer: 2,469
Likely the valve stem seals are hardened, and no longer sealing well. Common on old bikes that have sat idle for years. When the engine is shut off, oil seeps down the valve stem and builds up in the intake port, when you fire it up the oil goes into the combustion chamber and burns. It won't smoke once it's running because it seeps really slowly, not enough at once to see any smoke unless the seals have completely failed. No real concern, it will just smoke for a few seconds on startup until the seals get used to running and soften up a little. Or they may fail completely and turn into a real cloud mobile. It's fairly easy to change seals on a thumper if/when the time comes...
tkent02 is offline   Reply With Quote
Old 05-15-2012, 03:20 PM   #11846
saddlsor
my butt hurts
saddlsor's Avatar
Oddometer: 334
hey all, I'm looking for a set of stock fork springs for a 99 dr350se. I know a lot of people change them for firmer springs so hopefully someone has kept their old ones and is willing to sell them. shoot me a pm if you have some.......thanks
edit...the 98 and 99 forks appear to be the same but have different part numbers for the springs. is it because they have different spring rates and if so is there a way to find out which year would have the softer springs as that's what I want.......thanks for any info
I don't know where I'm going, not sure where I've been.
-john denver
99 dr350
78 r80
saddlsor screwed with this post 05-16-2012 at 10:40 AM
saddlsor is offline   Reply With Quote
Old 05-16-2012, 08:31 AM   #11847
juda5
juda5's Avatar
Oddometer: 124
Originally Posted by mrpopgun View Post
So looking at the fiche and cross-model part lookup based on a '96 350se, it appears that on the DR's, it's the same crank for every single bike, all years. Is that true? Kick vs electric? Dirt vs Street?
Edit: One other question
I found a local '92 dirt model bike for a good deal. Are the engine cases interchangeable between the older kick model and my newer electric model? I know I'd have to move over the stator and such, but not sure the cases are the same. What about the starter? If I just I just installed the whole dirt motor, could I get the lights to work for street use?
The cranks would be the same, as the e-start drives the stator rotor.
The left side case is different, as is the stator cover.
There is also a mount point for the starter on rear of the cylinder of the e-starts.
If you swap the stator from the e-start into the dirt motor, you will be able to power your e-start wiring harness.
juda5 is offline   Reply With Quote
Old 05-16-2012, 11:33 AM   #11848
TheOtherBart
TheOtherBart's Avatar
Oddometer: 1,951
Cam chain replacement
I've never done a cam chain replacement, and I can't find any straightforward instructions in the service manual or anywhere else. If I want to replace the chain without completely tearing down the motor I'm imagining the process will be something like:
  1. Remove the cam chain tensioner
  2. Remove right side cover and clutch basket
  3. Remove cam cover
  4. Line everything up so I won't screw up the timing when I put this back together
  5. Remove the sprocket from the cam
  6. Fish the chain off the lower sprocket and pull it up out of the top end
  7. Installation is reverse of removal
Parts-wise I'd need the chain and two gaskets. Am I anywhere close to right on how I'm thinking about this?
TheOtherBart is online now   Reply With Quote
Old 05-16-2012, 11:37 AM   #11849
MrPulldown
MrPulldown's Avatar
Oddometer: 3,256
I have never done this job either but would think that you need new slider thingyies that put the tension on the chain.
MrPulldown is online now   Reply With Quote
Old 05-16-2012, 01:57 PM   #11850
saddlsor
my butt hurts
saddlsor's Avatar
Oddometer: 334
  3. Remove cam cover
that's it mostly, but you also have to remove the oil pump sprocket as it blocks the chain from coming off around the crank gear, no biggie, jusy one extra step. overall pretty easy, just don't do what I did and break a tooth off the oil pump sprocket while trying to hold the clutch basket from turning when you tighten the nut. also check the washers on both sides of the clutch basket while your in there, if their worn it will create drag and make it harder to find neutral.
-john denver
99 dr350
78 r80
Times are GMT -7.   It's 02:54 PM.
