05-16-2012, 06:21 PM
#11851 | |
Oddometer: 164
any good threads on how to replace them on the 350's?
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. |
05-17-2012, 09:44 AM
#11852 |
Oddometer: 1,248
What is up with the thrust washer.
I have a little bit fo clutch drag. I can find nuetral still. But if I start the bike in gear with the cluthc pulled in, it will lurch a little bit. My clutch is grabbing fine, but I figure I should pull off the cover and check things out before a long trip out to the deseert in a few weeks. I have a clutch cover gasket already. Maybe I should change out some other consumables like teh thrust washer. Where are poeple getting theirs. Is is worth shimming out the washer with a very thin one like some inmate a couple months ago suggested?
94 DR 350 SE |
05-17-2012, 09:49 AM
#11853 | |
Oddometer: 2,066
ronayers.com for just about everything, although shipping may make small orders not cost-effective.
05-17-2012, 09:56 AM
#11854 |
Oddometer: 1,248
http://www.ronayers.com/Fiche/TypeID...2/Group/CLUTCH
Part number "2" PN# 08211-20363 Rode2NoWhere-ARe you asking the same question about the shim? Or 2nding the shimming suggestion.
94 DR 350 SE |
05-17-2012, 12:19 PM
#11855 | |
Oddometer: 2,066
, but all the same, I like the washer option if it gives the same effect. Less permanent, in case I screw it up.
05-17-2012, 01:14 PM
#11856 |
Oddometer: 1,463
What's the consensus on this, something that should be done with the chain? Can they be replaced without a teardown? It looks like the tensioner-side guide is held in with a single bolt at the top, is it accessible with the cam cover removed? There's no indication at all on the parts diagram how the guide on the opposite side is held.
05-17-2012, 02:14 PM
#11857 | |
Oddometer: 100
05-17-2012, 02:24 PM
#11858 | |
Oddometer: 1,463
05-17-2012, 04:46 PM
#11859 |
Wishing I was riding RTW
Oddometer: 2,421
New guy question
What size nut on the rear wheel so I can pull it on the trial? I'm thinking about one of those tire iron wrech combos.
My screen name is kind of long. I am the "ME" part, my name is Cory. Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..." |
05-17-2012, 09:28 PM
#11860 |
Dual Sport Addict
Oddometer: 987
The wife and I went camping last weekend. We took bikes and did some nice riding. The weather was great.
2011 DirtRoad650 http://i838.photobucket.com/albums/z...mping12182.jpg '98 DR 350 http://i838.photobucket.com/albums/z...t/Photo280.jpg '99 DR 650. Sold. |
05-18-2012, 11:16 AM
#11861 |
Oddometer: 135
05-18-2012, 11:45 AM
#11862 |
Oddometer: 2,421
05-18-2012, 04:06 PM
#11863 |
-Devo
Oddometer: 2,905
Noob with a sticky throttle
I've had my dr for about a month or two now, but on Monday the throttle decided it was going to stick. I tried to investigate but only made it worse...
I took out the two screws by the throttle handle and opened up the mechanism, seemed to be clean but I cleaned it again anyway. I disconnected the cable from the carb and the butterfly valve snaps right back so that isn't the problem. I loosened the locknut on the throttle cable adjuster and thinking maybe it needed tightened or something but that didn't do anything. I reconnected all the cables and put the cover back on by the throttle and now the throttle turns about 1/3 of the way and it isn't giving any gas. ![]() It is my commuter so dear god please give me suggestions...it's a 99 with 7.5K on the clock. Remember I'm a noob so please be gentle.
06' Wee 99' DR350 devo2002 screwed with this post 05-18-2012 at 04:26 PM |
05-18-2012, 05:09 PM
#11864 |
ADV Demo Rider
Oddometer: 1,228
Don't forget to check at the carb for grit and such.
Yes, I'd love to try What ever happens to be in the stable at the current time. H-ADV in fabrication
05-18-2012, 05:49 PM
#11865 | |
Oddometer: 164
