05-18-2012, 08:52 PM
#11866 |
Oddometer: 125
tm33 problems
I bought a used pumper carb a little while back and have had issues with the bike jumping from low to a high idle all the time and seems to lean out and pop for no reason... I pulled the carb apart and the slide seems to have a lot of play. From what I understand this seems pretty common.... It looks like the slide is worn down. Its hard to tell if the carb body is also worn. Does anyone know if you can you repair them or are they pretty much junk. I would just scrap it but I dont really have 300 dollars laying around for a replacement.
05-18-2012, 09:32 PM
#11867 | |
Oddometer: 201
___________________ 1999 DR350X 1982 GS750T |
05-18-2012, 09:36 PM
#11868 | |
Oddometer: 201
05-19-2012, 11:03 AM
#11869 |
-Devo
Oddometer: 2,901
Thanks for the tips, one cable is smooth the other doesn't move at all. Can you disassemble the cable or do you replace the whole darn thIng with a new set of cables cOmplete with rubber tubing and nuts?
06' Wee 99' DR350 |
05-19-2012, 06:01 PM
#11870 | |
Oddometer: 2,066
05-19-2012, 06:22 PM
#11871 |
Oddometer: 201
Did you try the lubricant oil on the stuck one to free it up?
05-19-2012, 06:33 PM
#11872 |
-Devo
Oddometer: 2,901
It won't budge at all, I'll cut it open to investigate once I install a fresh set, thanks guys
06' Wee 99' DR350 |
05-19-2012, 07:17 PM
#11873 |
Oddometer: 174
ok guys, 2 things i wanna look into. i consulted my service manual, but got nowhere on these questions of mine.
First Question: Camshaft Timing Chain tensioner..is it automatic or do i gotta put it at TDC and adjust? if so..how do ya do this on these bikes? i read about removing the spring, and then the whole tensioner to see if its maxed out, BUT odometer says 5k and from what ive read, 14-16k is about where the chain is stretched to its limits. Next Question: Ok..tire cupping..yah, this can be explained by about a 100 different examples and such, i understand that. but my front tire is cupping now, and i get the little "jiggle" to it..ya know, the kind that makes your head light dance but isn't really bad enough to make ya notice unless you really feel for it while driving. to be honest, i just started noticing it since i replaced my rear tire. so i'm gonna FIRST get it balanced to see if that helps. FWIW, i did remove the rim lock and i feel its useless weight added to the bike. i've never really needed one, as i dont typically ever air down my bike tires, however i do know what their used for and i agree for certain applications. one thing i DO know is that overall height of the NEW rear tire is alot higher than the tire that i took off of it. Could this theoretically throw off my frame geometry and cause to much pressure on the front forks, thus creating my little "hop" like conditions i'm experiencing? Bearings, tube, tire, and inner rubber band on REAR tire is new too btw, along with cush drive rubbers, so just maybe it DOES need balanced? its a kenda K270 50/50 tire. Let me know boys/gals, ill be watching to see what everyone has to say.
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. |
05-19-2012, 07:47 PM
#11874 |
MoTard
Oddometer: 866
Video from this afternoons ride on my 95 DR350. These bikes really are a blast! It has jesse's jet kit, suspension upgrades, jesse's header, supertrapp exhaust airbox mod etc.
XR650L & DR350
My Videos: http://www.youtube.com/user/wbedient#g/u |
05-19-2012, 08:09 PM
#11875 | |
Oddometer: 100
The tensioner is automatic. Have you been hearing the cam chain slap?
05-19-2012, 10:16 PM
#11876 |
Oddometer: 125
Yup, I read never to buy a used one right after I picked up mine off ebay... Learned my lesson.
05-20-2012, 04:37 AM
#11877 |
Oddometer: 174
either chain slap or spark knock, one or the other. happens about 5500 RPM when its loaded!! 2 ppl, uphill, get a little slap, knock noise. its not rod i know that much. i'm gonna check plug, it probably hasnt been touched in a while.
05-20-2012, 08:41 AM
#11878 | |
Oddometer: 201
05-20-2012, 11:43 AM
#11879 |
Oddometer: 339
2up...up hill. Preignition knock. Shift down. If it continues go with higher octain gas when 2 up.
05-20-2012, 06:22 PM
#11880 |
Oddometer: 174
Thats what i been doing, down a gear and get the RPM's up to a different range if i need to. i run 93 octane in it religiously. wish we had a non-eth station around here, sadly there isnt any even close to me. FWIW, i pulled the plug on it today, its running to lean. i emailed keintech with questions about suggested jetting. its all stock. i dont recall what jets are in the carb right now, but once i get a response from jesse, ill tear it down and see what i got. thats on my to do list. i figure go up a little on both sides (PJ and MJ) and then see how my plug looks. The "starting jet" has already been drilled for easier starting, and it helped from what i understand. 1 maybe 2 kicks after ya do the decomp process and tadah, you got a running power plant!
