Old 05-24-2012, 01:55 AM   #11941
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,213
Yep, my $400 '95 just turned 4k yesterday. Hooray for good deals!
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 05-24-2012, 06:52 AM   #11942
tkent02
Oddometer: 2,772
Originally Posted by _CJ View Post
There's definitely a learning curve. Just starting to get the hang of mine. When I bought it, 100 kicks and major frustration followed by starting fluid was the norm. Now I'm down to about five on a good day. Adjusting the valves definitely helped.
My procedure now:
-turn petcock on (I installed a full manual petcock)
-make sure the bike is in neutral
-pull out choke
-pull clutch lever and hold
-pull decomp lever
-slowly move kicker down until the de-comp pops out.
-bring kicker back to top
-give it 1/4 throttle
-give it a full kick
-repeat
For some reason, mine won't start unless the de-comp pops back out without sticking and/or needing to move the kicker. Like I'm getting a real full cycle on it or something. I also don't have a battery, just a capacitor, so I usually hold the de-comp in and give it a few kicks until I see the neutral light and headlight start to blink with each kick. That way I know the capacitor is charged and I'm getting a good spark.
Just curious, why are you pulling the clutch lever?
tkent02 is online now   Reply With Quote
Old 05-24-2012, 07:10 AM   #11943
_CJ
Retrogrouch
_CJ's Avatar
Oddometer: 1,748
Mainly just as a safety in case I knock it into gear by accident, but it also seems to start more easily with it pulled.
Access to public lands is a right, not a privilege.
_CJ is offline   Reply With Quote
Old 05-24-2012, 07:32 AM   #11944
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,587
This may have already been asked but is it the factory carb?
You looked down here...didn't you.
MeterPig is offline   Reply With Quote
Old 05-24-2012, 07:34 AM   #11945
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,587
For comparison my new to me dr starts with no choke and little throttle pretty quick.
Old 05-24-2012, 11:38 AM   #11946
PostIt
PostIt's Avatar
Oddometer: 342
What is a fair price for a 1998 DR350 SE with 2k original miles in excellent condition? I would appreciate and help!
PostIt is offline   Reply With Quote
Old 05-24-2012, 12:03 PM   #11947
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,708
$1800 to $2500 ball park
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 05-24-2012, 12:20 PM   #11948
devo2002
-Devo
devo2002's Avatar
Oddometer: 3,924
Paid 2k for a 99se with 6k on the clock, bark-busters gel seat and rear rack and renthals. Somehow with low miles the clutch cable snapped trying to ride off from the dealer, and my throttle cable snapped and was full of brown sludge lastweek.
Still I'm looking forward to beating the hell out of it
Edit - I bought it two months ago
2014 DL650 Vstrom
devo2002 screwed with this post 05-24-2012 at 12:25 PM
devo2002 is online now   Reply With Quote
Old 05-24-2012, 12:28 PM   #11949
PostIt
PostIt's Avatar
Oddometer: 342
Thank you! I cannot wait!
Old 05-24-2012, 12:28 PM   #11950
PostIt
PostIt's Avatar
Oddometer: 342
Thank you for the comparison! How do you like it so far?
Old 05-24-2012, 01:01 PM   #11951
devo2002
-Devo
devo2002's Avatar
Oddometer: 3,924
I haven't gotten around to too much dirt yet but although a tad on the heavy side compared to my prior xt225 this bike is definitely a keeper. I'm 6' so perfect size and working on it appears pretty simple so far. I'm gonna start messing with sprocket sizes and somehow shave a tad off the a washer in the clutch basket since it doesn't like neutral.
I have every intention of riding this until it turns to dust, I highly recommend it.
2014 DL650 Vstrom
Old 05-24-2012, 01:07 PM   #11952
djchan
djchan's Avatar
Oddometer: 1,180
I have a friend with a 93 DR350. We've done some carb work and it seems to run OK, but not as smooth as I'd like. I see a vent hose hanging down which I don't remember removing when we took the carb out. It runs from the frame downward and has a sharp crook in the end, but all the vacuum ports on the carb are plugged and it has an aftermarket petcock.
Could this be the tank vent? And could a disconnected tank vent hose cause the rough running?
If so, where does it hook under the tank?
This is all made worse because we're unable to find the key for the tank - so I can't check for a vacuum situation in the tank to see if that makes it run better.
So, my second question - is there another source for the tank key?
TIA
Now own - 2007 Bandit 1250, 2002 KTM LC4E, 2007 CRF250X, 2008 WR250R
djchan is offline   Reply With Quote
Old 05-24-2012, 01:17 PM   #11953
TortillaJesus
Authentic
TortillaJesus's Avatar
Oddometer: 3,774
Thanks for the tips, fellas! The decomp lever has been demystified!
The carb has a dynojet kit installed. Once I get her started she purrs like a kitten and it is easy to start when hot, just one small kick.
TortillaJesus is online now   Reply With Quote
Old 05-24-2012, 01:51 PM   #11954
jplum1556
Oddometer: 102
So, I put a 440 kit in my dr350 and got it all put back together today and idling. The engine seems like it's extremely hot, both the clutch side cover and magneto cover are hot enough where I can't leave my hand against them for more than a few seconds. I don't remember if this is normal or not... I may need to get an oil cooler.
jplum1556 is offline   Reply With Quote
Old 05-24-2012, 02:50 PM   #11955
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,427
It will take a little while to run in so i wouldn't worry too much about the heat .
All the same how long did it take to heat up ? Was this after a ride or just from idling ?
Don't run it in on the side stand , get it moving , these are air cooled engines and require air flow to get rid of heat .
Take it for a good ride varying the throttle position and revs , you will love the 440 .
Of course you have checked the oil level?
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is online now   Reply With Quote
Times are GMT -7.   It's 08:05 PM.
