Old 10-10-2007, 05:52 AM   #106
BikePilot
BikePilot's Avatar
Oddometer: 11,251
IIRC all the street models put out the same amount of power - at least the ignition rotors and such all have common pt#'s.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 10-11-2007, 07:44 PM   #107
snare
sittin and breathin
snare's Avatar
Oddometer: 283
Originally Posted by steve gs
First, we may want to differentiate between the dirt and street models and model year. So you will have to be more specific on what you have.
It has been in my sig, below.
Combat Systema - Emergency Care - Outdoor Skills
Empowering You To Explore The Wild, Beautiful World
snare is online now   Reply With Quote
Old 10-12-2007, 11:51 AM   #108
CMS
CMS's Avatar
Oddometer: 282
Trip
Steve,Have you posted your last DR200 trip ? Still looking for a 250 , with the new xt250 and the ninga 250, I'm on hold untill I can see those two models in person. CMS
DL 650,TU250X,GW250
VSRI, FSSNOC
CMS is offline   Reply With Quote
Old 10-12-2007, 12:15 PM   #109
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,978
Snare,
I happen to have a DR350 Service Manual in PDF format. I took a look thru the 1994 section DR350(R) & DR350SE(R).
Here's what's in the manual for the DR350SE(R):
Magneto no-load voltage (engine cold): More than 60 VAC @ 5000 rpm
Regulated voltage: 13.0-15.5 VAC @ 5000 rpm
Magneto Max. output: Approx. 125W @ 5000 rpm
I hope that helps - Dave.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 10-12-2007, 02:13 PM   #110
steve gs
steve gs's Avatar
Oddometer: 375
Snare;
Same as what I have.
Generally the same for all years except that the dirt DR's use a lighting coil and the DR S/SE's use a 3 phase AC "generator". Output fuses were 15A until '94 where they could have been 15 or 20A; manual (new compilation type) specs both.
CMS, I'll send you a PM.
steve gs is offline   Reply With Quote
Old 10-12-2007, 07:41 PM   #111
BikePilot
BikePilot's Avatar
Oddometer: 11,251
hmm, my setup is 30wts for grips, 60wts for the headlight, guessing 60wts for the heated vest (anyone know what they usually run? Mine is an older BMW vest, made by Widder I think, but not sure). Then its still got to power the ignition, tail light etc and you've got to account for some efficency loss in the wiring, conversion to AC and though the voltage regulator. I suspect the 125wts is a very conservative spec:)
Old 10-13-2007, 05:40 PM   #112
motojon
motojon's Avatar
Oddometer: 75
I just bought a widder vest, it's rated at 33 watts. are you planning on running all the extra's or do you have them on now? I was thinking about heated grips. I know it will handle the vest with no problem but adding the grips i don't know. let me know how it works out. thanks
motojon is offline   Reply With Quote
Old 10-13-2007, 07:25 PM   #113
Matttys
Matt the Balloon Guy
Matttys's Avatar
Oddometer: 436
Just got my tall seat in from GaThumper and went for a small test ride. It's a Ceet Seat and I love it. Between the tall seat and the bar risers riding was 100 times easier. Now I just need to get some real foot pegs!
Thanks GaT!
Now the ride pictures. . .
Of course there are pictures of the bike standing up, but those aren't as fun
www.ProTwister.com
'04 Bonneville hack, '05 DRZ134SM minimoto, '02 955i Tiger, '08 WR250R
Matttys is offline   Reply With Quote
Old 10-14-2007, 08:06 AM   #114
CBAT
occasional wanderer
CBAT's Avatar
Oddometer: 837
Nice to see they can take a little....use. Nice pics.
Bruce
2000 Suzuki DRZ400S, 2012 Yamaha Super Tenere
My Great Divide Ride 2009
Great Divide Part 2
CBAT is offline   Reply With Quote
Old 10-14-2007, 09:21 AM   #115
Helmet_Hair
Helmet_Hair's Avatar
Oddometer: 225
Looks like fun! Also looks like you've got some bar risers to go with your higher seat? I've got the same seat for mine, but took it off since most of my riding these days is on the street. It (the Ceet) sure did help in getting the weight forward and off my knees.
Helmet_Hair is offline   Reply With Quote
Old 10-14-2007, 09:38 AM   #116
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Looks like fun! I've got a tall seat as well and love it, much more comfortable and less cramped feeling. I think the stock dr was intended for someone about 5'6" or so. I want to get some bar mounts to move the bar forward and would really like to move the footpegs back a couple inches, but that's too much work.
I got some wide pegs off ebay for ~$15 that work ok. The quality is nothing like the IMS pro series or fastway pegs, but then they are also 1/6th the price. Width and design is about like my stock CR250R pegs which are pretty good. The casting was pretty rough, but so far they seem perfectly functional. For the price I'm very, very happy
Old 10-14-2007, 09:39 AM   #117
BikePilot
BikePilot's Avatar
Oddometer: 11,251
I ran the vest and grips and light on hi-beam all lastI spring with no issues at all. I used the grip heaters that stick to the bar (got them from casporttouring), I think they were made by kimpex or something like that.
Old 10-14-2007, 12:01 PM   #118
Matttys
Matttys's Avatar
Oddometer: 436
Oh man, you read my mind. Any thing that I should look for when getting wider pegs? Most all should fit the stock rubber mount DR brackets, right? Those little slivers of metal just aren't keeping me too planted when I stand.
Overall, I love the seat and bar risers. They cost about 1/10th the price of the bike, but I'm OK with that as I bought the bike with 2700 miles and nearly every performance mod possible!
www.ProTwister.com
Old 10-14-2007, 02:23 PM   #119
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Nothing special about the pegs. Just decide if you want really high quality ones for around $100 or medium-low quality ones for $20. They replace just the actual foot peg part, the bracket and its rubber mounts are unaffected.
These are the pegs I have on my DR350 (they were $12 + 8 to ship when I ordered a few months ago, but still quite a good price).
http://cgi.ebay.com/ebaymotors/SUZUK...spagenameZWDVW
As I said, they are pretty wide and a good, honda-like design, but the castings are a bit crude and they seem to be powder coated mild steel (as compared to the IMS pegs which are stainless steel). They are a huge improvement over the stock DR pegs and I'm totally happy with them. If your really picky about fit and finish the IMS pro series might be a better option for you, but if you just want something wider that works these are quite a bargin.
Old 10-14-2007, 04:24 PM   #120
Helmet_Hair
Oddometer: 225
My DR actually came with those on it from the previous owner. They WILL bend if you crash. My right one is a little bent from a get off at low speed, so they're nothing too special, but they do give a nice place for your boots to sit.
Times are GMT -7.   It's 08:16 PM.
