07-21-2012, 07:28 AM
#12556 |
Oddometer: 169
Well, got my graphics material i wanted...got back half of bike done, along with headlight shroud. Tank will be next, but taking a break. alot of small, fine details that had to be gone over! Ugh!
It dont look to bad...up close you can see how "strait, flat" graphics can be a pain to install onto "rounded" plastic. Its tough to make it fit on the contoured plastics!
-WagZ- '93 DR350S **WANTED**: White or Aluminum Frame Guards for DR350. Please PM with details. |
07-21-2012, 12:29 PM
#12557 |
Oddometer: 135
[QUOTE=scharfg;19153591]Hey thanks for the intel. I'll have a look for it. What exactly is being pushed out (ie: what should I be looking for/meauring, see I'm a Newb)? Any idea what the max distance it can come out so I can measure mine and compare where its at (ie: how much wear do I have)?
Found some good intel about the Cam chain tensioner and how far it should be out here: http://www.thumpertalk.com/topic/941..._fromsearch__1 |
07-21-2012, 12:53 PM
#12558 | |
Oddometer: 99
[QUOTE=scharfg;19181641]
07-21-2012, 03:18 PM
#12559 |
Love those blue pipes
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,096
Don't forget that camchain stretch/wear is not only a problem when you run out of adjustment. Before that point, the valve timing will have drifted by enough to affect performance,
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
07-21-2012, 03:24 PM
#12560 | |
1.5 Finger Discount
Oddometer: 20,079
I dunno if the cam chain has ever been replaced on ours, but even as good as it runs now, it still idles a bit rough. Especially when it's cold. Burbles a bit at idle with the occasional cough and stall.
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy "Never bring a Nerf gun to a shovel fight." - My Brother |
07-21-2012, 03:27 PM
#12561 |
Oddometer: 99
Does this cause bad starting? Valves seem to be in correct clearance, starts cold in a couple kicks but hot is sometimes impossible. Should I try with a bigger or smaller clearance? Now I have them in the middle of the suggested values.
07-21-2012, 04:17 PM
#12562 |
Oddometer: 70
lighting problems after converting dirt model to dual sport
I already started a thread for this problem but I'm hoping some dr owners recognize this problem. I just picked up a 1990 dirt model and am trying to convert it to a true dual sport. So close but still so far! I'm all set up lighting wise but now I'm having an electrical problem. FYI, I traded the factory headlight for an Acerbis Cyclops (55w), added blinkers, K&S combo switch and a keyed ignition. No battery, its a kicker
![]() So I wired everything tonight and surprisingly nailed it, having never done electrical on this level (I know, doesn't get much more simple) I was apprehensive. The bike is A/C with no battery so I used a couple of 6v batteries wired in series to test everything without having to start the bike every time I tested a new connection, even though the lights were clearly too much for the little Raovac (sp?) they were all on point! After making sure everything was working perfect I plugged the stator back into the black and yellow wires. I kicked the bike and also surprisingly it started and all lights were bright!....for 5 seconds, at which point all lights switched themselves off but the motor kept running (the ignition coil has dedicated wires from the stator, yellow and black for the lights are separate). I killed the engine with my fancy new keyed switch and then fired it back up. This time I kept the motor around 3-4k rpms and tried the lights, they stayed on closer to 15 seconds this time before turning themselves off. Does this sound familiar to anyone? I suppose I'm not getting enough power out of the stator that was originally designed for just headlight and brake lights. Still doesn't make sense that they run at full brightness and then suddenly shut off.. I was expecting dimming at low rpm's but this is a new one on me. Thanks in advance fella's! Oh, and here are before and after pics just for fun, still not all done though! |
07-21-2012, 06:40 PM
#12563 |
V-Strom explorer
Oddometer: 361
Hmm, no I'm not sure that the float level is set correctly. Perhaps the mamual explains this process. I'll check into it.
Blog of my adventures: www.BestScenicRoutes.com "When all else fails get a bigger hammer."
07-22-2012, 04:12 AM
#12564 |
Grumpy Old Bastard
Oddometer: 6,494
These bike's are a blast!!
07-22-2012, 05:09 AM
#12565 | |
Squiddly slow
Oddometer: 880
07-22-2012, 08:37 AM
#12566 |
Oddometer: 70
Correct, no battery. Just running the stock regulator. I didn't use a kit, just added blinkers, Vapor computer/speedo, and combo switch on the bars. The original wiring for headlight and tail light now run through the combo switch which also controls blinkers and horn. Again, everything works perfect when I connect a 12v battery in place of the stator to test, but when I plug the stator back in and fire it up something shuts down the circuit. Didn't see this one coming...
Here is the original wiring, pardon my very amateur diagram |
07-22-2012, 09:54 AM
#12567 | |
Oddometer: 487
07-22-2012, 10:08 AM
#12568 | |
Oddometer: 581
Regards, Gregory Bender |
07-22-2012, 10:17 AM
#12569 | |
Oddometer: 581
[QUOTE=Teeeeeemu;19181728]
In my experience (only on my 1993 DR350), even when I replaced the chain and both gears, I still didn't have many clicks left (can't recall for sure how many just now). The guides still don't appear worn much at all. My conclusion is that while Suzuki provides 25 clicks, that even when new way fewer than 25 clicks are used. Anyone else care to confirm their experience? Regards, Gregory Bender |
07-22-2012, 10:29 AM
#12570 | |
Oddometer: 100
[QUOTE=Greg Bender;19186602]
