Old 08-07-2012, 11:57 PM   #12751
tntmo
Oddometer: 494
DR350 non-cush wheels are a direct swap, but you may need different spacers.
DRZ250 also has the same back wheel (non-cush).
DR650 rear wheel will fit but it's a 17 inch.
I'm almost positive that the DRZ400 uses the same rear wheel.
RMX250 is probably the same rear wheel also.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 08-08-2012, 11:13 AM   #12752
MrPulldown
MrPulldown's Avatar
Oddometer: 3,156
Rear wheels are hard to find cheap. Since it is only your rim that is busted it is not that hard to swap rims. Might be a bit time consuming but not that hard.
-Find a replacement rim of the same size. Since moto rims are single walled you don't really have to worry about spoke length.
-tape the old wheel and the new rim together lining up the spoke holes.
-losen all the spokes. Remove each spoke at a time and swap from the old wheel spoke hole to the new. You do not need to undo the entire spoke from the hub and mess with the lace pattern.
-true, dish, and tension. You might want a shop to do this part.
MrPulldown screwed with this post 08-08-2012 at 11:26 AM
MrPulldown is offline   Reply With Quote
Old 08-08-2012, 04:28 PM   #12753
MOTO DUDE
Rydin Dirty
MOTO DUDE's Avatar
Oddometer: 136
Extended shifter
Does anyone know of an extended shifter that is available for the DR350?
I have searched and am unable to locate one.
MOTO DUDE is online now   Reply With Quote
Old 08-08-2012, 05:30 PM   #12754
james1300
Track Dazed
james1300's Avatar
Oddometer: 162
Question Wiring diagram 1995 DR350SE~HELP Plz!
Please help me find a wiring diagram for a 1995 DR350SE (electric start)
I searched here and got this:
  1. D'oh... Our sucky search engine couldn't handle that term. Got Google?
The R/H switch on the handle bar, that runs the starter and on/off kill switch was broken internally.
I ordered and replaced it.
(This is a used bike I just got) I never tried to use the switch until I got the new switch.
Now, with the new 'kill switch' in the OFF position . The bike won't start. Thats good.
But! When the engine is running and, I try to shut it off with the kill switch, it won't shut-off.
It's like the kill switch isnt hooked up!
I hope you can help.
Jim
james1300 is offline   Reply With Quote
Old 08-08-2012, 05:39 PM   #12755
Teeeeeemu
Oddometer: 104
Thumb
Jim
Googled "dr350se wiring diagram"
5th link, clicked the link on the first post, searched dr350. TADAA!!
Teeeeeemu is offline   Reply With Quote
Old 08-08-2012, 05:41 PM   #12756
2old2Bbold
was 2bold2getold
Oddometer: 1,695
Jim
Dunno if it's the right one, but might help anyway.
http://advrider.com/forums/showpost....postcount=7490
Edit --- Oops, sorry, beat me to it.
2old2Bbold is offline   Reply With Quote
Old 08-08-2012, 05:53 PM   #12757
Barney
I reckon so
Barney's Avatar
Oddometer: 896
Thanks for the info guys.
Barney is offline   Reply With Quote
Old 08-08-2012, 05:58 PM   #12758
Teeeeeemu
Oddometer: 104
Thumb
Thats for the older/dirt ones, theres no starter.
But Ive been kinda looking for that, thanks
Old 08-09-2012, 04:05 PM   #12759
MrPulldown
MrPulldown's Avatar
Oddometer: 3,156
Cranked up the preload and the compression dampening on the shock. yesterday rode the bike. All I can say is NICE!! I can do moderate hill climbs sitting and be in total control.
Jsut wanted to share.
Old 08-11-2012, 10:21 AM   #12760
silverwasp
Silverwasp
silverwasp's Avatar
Oddometer: 19
Needed info on Valve Adjustments
Time for a tune up. Does anyone have helpful tips and tricks on adjusting the valves on a 99SE. Also anyone with link to where I might find a good deal on rear rotor and pads. also... anyone put in an after market speedo.. my original cracked right off of the plastic bottom plate of the unit and now the odometer does not work. thanks in advance
PS if you have canadian links all the better. ;-)
Disobey every day
I ride therefore I am
silverwasp is offline   Reply With Quote
Old 08-11-2012, 12:02 PM   #12761
auto
Oddometer: 83
igntion problems
I have a 92 drs 350 that has been pretty easy starting.All of suddenit became difficult to start.Fresh gas,carb cleaned.I towed it to get it started.Would not rev out clean.Pulled the plug and it was black and suty.Is there any history of igntions going bad on these bikes?In most cases they work or don't work.Not sure about this one.
Thanks for any help.
auto is offline   Reply With Quote
Old 08-11-2012, 01:55 PM   #12762
Greg Bender
Oddometer: 1,169
Here is the speedometer I fit to my dirt model. It has worked very well for me the past 1 3/4 years (10,000 + miles).
http://thisoldtractor.com/gtbender/d...-_baja_designs
Here is the rear disc and pads I fit. Disc works lovely. Pads wore out in 3000 miles (though I hear that is common for organic kevlar pads).
http://thisoldtractor.com/gtbender/d...sc_replacement
As for valve adjustment, I just set my valves to the loose end of the spec for my year. The only "trick" is to use (or make) a little tool for turning and holding the tiny square adjuster.
Pro Cycle sells the valve adjustment tool here:
http://www.procycle.us/bikepages/dr350.html
Or you can make your own with a #2 square drive screw and a short piece of dowel.
Should you need any of the commonly replaced o-rings, let me know. I can help you out with those.
Hope this helps!
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 08-11-2012, 02:04 PM   #12763
Canadian FJR
Oddometer: 128
Valve Djustment
"Time for a tune up. Does anyone have helpful tips and tricks on adjusting the valves on a 99SE. Also anyone with link to where I might find a good deal on rear rotor and pads. also... anyone put in an after market speedo.. my original cracked right off of the plastic bottom plate of the unit and now the odometer does not work. thanks in advance "
Bump for the OP, time for valve adjustment here also.
Canadian FJR
Canadian FJR is offline   Reply With Quote
Old 08-11-2012, 04:01 PM   #12764
BAD-MOD
professional fiddler
BAD-MOD's Avatar
Oddometer: 163
Chain guidingness
Hey guys do you know of any cool aftermarket chain guides ?
will a chain guide of any rm's or other models fit ????
Try it otherwise you'll never know what is possible
BAD-MOD is offline   Reply With Quote
Old 08-11-2012, 04:44 PM   #12765
silverwasp
Silverwasp
silverwasp's Avatar
Oddometer: 19
Thank you thank you... you made my day Mr Bender. cheers.
Disobey every day
Times are GMT -7.   It's 05:37 AM.
