08-23-2012, 12:13 PM
#12871 |
Oddometer: 54
Now have a shiny new sig line, thanks to the kinda-shiny-but-not-so-new 1999 DR350SE I picked up yesterday. I still need to do a full head-to-toe on it but it seems like it's in good shape and rides well. Couple of little things to dig into, but that's part of the reason I bought it anyway.
I'll post a pic when I get the time to figure out how to do so easily, but in the meanwhile imagine: '99 DR350SE (it had the correct forks, BTW) Pro Moto billet rack and rear brake shark fin, Roost deflector removed from rear fender, plate moved to under brake light Acerbis tank K&N air filter, airbox opened up Dynojet kit (not sure which jets are in, haven't dug into carb) Clutch worked on, still needs a little work but old parts came with and don't look bad Tool tube came with, but not installed - the new luggage rack blocks the old mounts (not sure if that's what I want to use anyway) Riding on good Michelin Sirac 90/10's, and came with a new set of Pirelli MT32/MT410 knobs (I forget which one is the rear) Also came with spare filters, o-rings, work stand, and a bunch of other extras ![]() Getting there was a bit of a drive, but I had to make the trip for work anyway (about five hours) and I got to see the bike in the rearview all the way home. I'll apologize to the PO here and now for the potential that I'll put it sideways in a ditch like the pics above. - Spad
___________ 06 Wee Strom 82 CM450E 99 DR350SE |
08-23-2012, 04:49 PM
#12872 |
I'm A Stumper™
Oddometer: 3,879
The other day I bought a 92 RM250 non operational. I already have the front fork swap almost done on my DR, anything else that might be worthwile in hanging onto? It has Excel wheels but obviously non cush drive. I'm going to part it out but if something is an upgrade for our bikes i'll keep it.
08-23-2012, 04:58 PM
#12873 | |
almost gnarly
Oddometer: 1,473
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
08-23-2012, 06:21 PM
#12874 | |
Rides a dirty bike
Oddometer: 1,425
Two roads diverged in a wood, and / I took the one less traveled by, / And now where the hell am I? 'Being an adult is so much better when you forget that you're supposed to be boring' (D.Corsetto, 9/7/12) |
08-23-2012, 09:12 PM
#12875 |
2 for the price of 1
Oddometer: 731
good to see ya guy
I'm riding a 96 dr350 & have a buell Ulysses now ... you'd think I had a STD when I told my buds about buying the buell.
You still cog'n? catch u at a rally sometime... Inmates-whats the best front damping improvement - rebound particularly - for my 96 dr350se? dean Young : ) |
08-23-2012, 10:43 PM
#12876 | |
Noob
Oddometer: 43
DR 350SE - Cannot Start
Go ride while you can.
08-24-2012, 02:46 AM
#12877 |
I'm A Stumper™
Oddometer: 3,879
I seem to remember reading peoples opinion was it was better/easier to box the stock swingarm than to adapt the RM swingarm. As for the shock I know some have out DR dirt shocks on their SE's, not sure how close the RM shocks are.
08-24-2012, 04:03 AM
#12878 | |
Oddometer: 10
Now, I know that the proper way is to get a pump flat carburetor, but since it's for sort of road use (albeit "hooliganic" one) and budget is tight (and will get tighter when my wife finds out about my plans) I'm contemplating to use only flat slide one. My logic is that flat slide w/o accelerator pump is still better than CV, except for fuel economy of course. Or I'm wrong? The kind of riding I (plan to) do is twisty back roads with sort of WFO out of a corner and hard breaking into the next one. Or somewhere abouts. I mean not really highway or much cruising at steady, economical pace. |
08-24-2012, 05:51 AM
#12879 | |
Oddometer: 584
Here is another option I've never tried: http://www.kientech.com/Intiminators.htm I am still looking for a fork brace. Anybody got one???? Regards, Gregory Bender |
08-24-2012, 05:55 AM
#12880 | |
Oddometer: 7,683
![]() Will be at the Fall Foliage Rally in Matamoras, PA at the end of Oct. /hijack off .
GB Young Services, LLC Garage Project: http://gbyoung2.smugmug.com/Family/G...11686385_YA8pi |
08-24-2012, 08:45 AM
#12881 |
Oddometer: 2
Brake Light install on dirt model
Hello,
I have a 1990 Dirt model with no brake light switches. I'm not sure if the stock version had any break lights at all or if the P.O. removed the switch, but I bought an OEM rear break light switch on ebay and was hoping it would be a plug and play type of installation along with a dual filamnet bulb. Am I way off on that? I looked at the bike last time I was with it and there is definitely a spot where the hydraulic banjo bolt threads in, but is there anything crazy I am missing? The bike is in Michigan and I'll be heading up there this weekend, hoping to install the break light. Thanks in advance for any info. Rob |
08-24-2012, 08:54 AM
#12882 | |
Oddometer: 584
From the factory, the rear brake light was actuated via a mechanical, spring loaded switch positioned near the rear brake pedal. Personally, I really dislike those type of brake light switches. Instead, I fit this hydraulic unit that took the place of the banjo bolt at the rear master cylinder. Hope this helps! Regards, Gregory Bender |
08-24-2012, 11:55 AM
#12883 | |
Oddometer: 490
08-24-2012, 12:22 PM
#12884 |
Oddometer: 1
Gauge LED lights
Has anyone replaced their gauge cluster lights (Neutral, turn signal indicator, speedo, tach) with LEDs?
I have a 94 DR250S and I can barely see when the lights are on during the day. It would be nice to get a brighter bulb. |
08-24-2012, 01:12 PM
#12885 | |
Oddometer: 584
